查看: 2100|回復(fù): 2
萌新求問(wèn)關(guān)于基于51單片機(jī)門(mén)禁程序的問(wèn)題,有幾個(gè)定義不太懂
ID:784145 發(fā)表于 2020-7-16 18:34 | 顯示全部樓層 |閱讀模式
圖上這幾個(gè)定義的有的不是很懂,有的能夠猜出來(lái)。還望大佬解答這幾個(gè)定義的是什么
完成程序如下
#include "reg52.h"
#include "main.h"
#include "mfrc522.h"
#include <string.h>
#include "LCD1602.h"
#include "DS1302.h"
#include "STCEEPROM.h"
#define uint  unsigned int
sbit Speak = P2^7;
sbit RED      = P3^3;
sbit GREEN = P3^4;
sbit Relay = P3^2;
sbit KEY1 = P1^3;
sbit KEY2 = P1^4;
sbit KEY3 = P1^5;
sbit KEY4 = P1^6;
sbit KEY5 = P1^7;
unsigned char idata RevBuffer[30];
unsigned char Card_Num;
void iccardcode();
//系統(tǒng)初始化
void InitializeSystem()
     PcdReset();
     PcdAntennaOff();
     PcdAntennaOn();
     M500PcdConfigISOType( 'A' );
unsigned char idata UID[4],Temp[4];
unsigned char Table[3];
unsigned char Num;
unsigned char Count,Countf,Count1,Count2,Count3,Count4,Count5,C_flag;
void Auto_Reader(void)
    if(PcdRequest(0x52,Temp)==0)
      if(PcdAnticoll(UID)==0)
                Speak=0;delay_10ms(20);Speak=1;
            Table[0]=UID[0]/100+0x30;
            Table[1]=UID[0]/10%10+0x30;
            Table[2]=UID[0]%10+0x30;
            LCD1602_Disp_ZF(0x80+0x40,"Num:            ",16);
            LCD1602_Disp_ZF(0x84+0x40,Table,3);
            Count =  UID[0];
            if((Count==Count1)||(Count==Count2)||(Count==Count3)||(Count==Count4)||(Count==Count5))
                LCD1602_Disp_ZF(0x8a+0x40,"OK   ",5);
                GREEN = 0;Relay=0;delay_10ms(200);Relay=1;GREEN = 1;
                C_flag=1;
                LCD1602_Disp_ZF(0x8a+0x40,"Error",5);
                RED = 0;delay_10ms(200);RED = 1;
                C_flag=2;
            delay_10ms(200);
               LCD1602_Disp_ZF(0x80+0x40,"Please Swipecard",16);
uchar DS1302_Table[7]={0};    //讀取時(shí)間值
void Display_LCD2(uchar Dis_Hour,uchar Dis_Min,uchar Dis_Sec)
    uchar Dis_Table[8]="11:22:33";
    Dis_Table[0] = Dis_Hour/10+0x30;
    Dis_Table[1] = Dis_Hour%10+0x30;
    Dis_Table[3] = Dis_Min/10+0x30;
    Dis_Table[4] = Dis_Min%10+0x30;
    Dis_Table[6] = Dis_Sec/10+0x30;
    Dis_Table[7] = Dis_Sec%10+0x30;
    LCD1602_Disp_ZF(0x85,Dis_Table,8);
* 名稱(chēng) : Run_DS1302(void)
* 功能 : 讀出DS1302中的數(shù)據(jù),并進(jìn)行顯示
* 輸入 : 無(wú)
* 輸出 : 無(wú)
void Run_DS1302(void)
    uchar sec, min, hour, day, month, week, year;
        v_W1302(0x8f, 0);
        sec = bcdtodec(uc_R1302(0x61));       //讀出DS1302中的秒
        v_W1302(0x8f, 0);
        min = bcdtodec(uc_R1302(0x73));       //讀出DS1302中的分
        v_W1302(0x8f, 0);
        hour = bcdtodec(uc_R1302(0x85));   //讀出DS1302中的小時(shí)
        v_W1302(0x8f, 0);
        day = bcdtodec(uc_R1302(0x87));       //讀出DS1302中的日
        v_W1302(0x8f, 0);
        month = bcdtodec(uc_R1302(0x89));  //讀出DS1302中的月
        v_W1302(0x8f, 0);
        week = bcdtodec(uc_R1302(0x8b));  //讀出DS1302中的星期
        v_W1302(0x8f, 0);
        year = bcdtodec(uc_R1302(0x8d));   //讀出DS1302中的年
       DS1302_Table[0]=year;
       DS1302_Table[1]=month;
       DS1302_Table[2]=day;
       DS1302_Table[3]=week;
       DS1302_Table[4]=hour;
       DS1302_Table[5]=min;
       DS1302_Table[6]=sec;
        Display_LCD2(DS1302_Table[4],DS1302_Table[5],DS1302_Table[6]);
void main(void)
    InitializeSystem();
    LCD1602_init();
    LCD1602_Disp_ZF(0x80,"Time:",5);
                             //0123456789abcdef
    Countf=ISP_READ(0x2c00);
    Count1=ISP_READ(0x2c01);
    Count2=ISP_READ(0x2c02);
    Count3=ISP_READ(0x2c04);
    Count4=ISP_READ(0x2c06);
    Count5=ISP_READ(0x2c08);
    while (1)
        iccardcode();
        Auto_Reader();
        Run_DS1302();
        if(!KEY1)
            delay_10ms(50);
            if(!KEY1)
            DS1302_Table[4]++;
            Write_DS1302Init(0,0,0,0,DS1302_Table[4],DS1302_Table[5],0);
        if(!KEY2)
            delay_10ms(50);
            if(!KEY2)
            DS1302_Table[4]--;
        if(!KEY3)
            delay_10ms(50);
            if(!KEY3)
            DS1302_Table[5]++;
        if(!KEY4)
            delay_10ms(50);
            if(!KEY4)
            DS1302_Table[5]--;
        if(!KEY5)
            delay_10ms(50);
            if(!KEY5)
                if(C_flag==2)
                                             //0123456789abcdef
                    LCD1602_Disp_ZF(0x80+0x40," Register Card! ",12);
                    Countf++;
                    if(Countf==6)Countf=1;
                    if(Countf==1) Count1 = Count;
                    if(Countf==2) Count2 = Count;
                    if(Countf==3) Count3 = Count;
                    if(Countf==4) Count4 = Count;
                    if(Countf==5) Count5 = Count;
                if(C_flag==1)
                                             //0123456789abcdef
                    LCD1602_Disp_ZF(0x80+0x40,"  Clean Card!   ",11);
                    if(Count==Count1)Count1=0;
                    if(Count==Count2)Count2=0;
                    if(Count==Count3)Count3=0;
                    if(Count==Count4)Count4=0;
                    if(Count==Count5)Count5=0;
                Speak=0;delay_10ms(200);Speak=1;
                LCD1602_Disp_ZF(0x80+0x40,"Please Swipecard",10);
                ISP_ERASE(0x2c00);        //注意:字節(jié)編程時(shí)必須要先要擦除整個(gè)扇區(qū)
                ISP_PROGRAM(0x2c00, Countf);
                ISP_PROGRAM(0x2c01, Count1);
                ISP_PROGRAM(0x2c02, Count2);
                ISP_PROGRAM(0x2c03, Count3);
                ISP_PROGRAM(0x2c04, Count4);
                ISP_PROGRAM(0x2c05, Count5);
                C_flag =0;
                while(!KEY5);
void iccardcode()
      unsigned char cmd;
    unsigned char status;
    cmd = RevBuffer[0];
    switch(cmd)
        case 1:     // Halt the card     //終止卡的操作
            status= PcdHalt();;
            RevBuffer[0]=1;
            RevBuffer[1]=status;
            break;
        case 2:     // Request,Anticoll,Select,return CardType(2 bytes)+CardSerialNo(4 bytes)
                    // 尋卡,防沖突,選擇卡    返回卡類(lèi)型(2 bytes)+ 卡系列號(hào)(4 bytes)
            status= PcdRequest(RevBuffer[1],&RevBuffer[2]);
            if(status!=0)
                if(status!=0)
                    RevBuffer[0]=1;
                    break;
            RevBuffer[0]=3;
            break;
        case 3:                         // 防沖突 讀卡的系列號(hào) MLastSelectedSnr
            status = PcdAnticoll(&RevBuffer[1]);
            if(status!=0)
                RevBuffer[0]=1;
                break;
            //memcpy(MLastSelectedSnr,&RevBuffer[2],4);
            RevBuffer[0]=5;
            break;
        case 4:                            // 選擇卡 Select Card
            //status=PcdSelect(MLastSelectedSnr);
            if(status!=MI_OK)
                RevBuffer[0]=2;
                break;
            RevBuffer[0]=3;
            break;
        case 5:        // Key loading into the MF RC500's EEPROM
            //status = PcdAuthState(RevBuffer[1], RevBuffer[3], DefaultKey, MLastSelectedSnr);// 校驗(yàn)卡密碼
            RevBuffer[0]=34;
            break;
        case 6:
            RevBuffer[0]=1;
            break;
        case 7:
            RevBuffer[0]=1;
            break;
        case 8:     // Read the mifare card
                    // 讀卡
            status=PcdRead(RevBuffer[1],&RevBuffer[2]);
            if(status==0)
            {RevBuffer[0]=17;}
            {RevBuffer[0]=1;}
            break;
        case 9:     // Write the mifare card
                    // 寫(xiě)卡  下載密碼
            status=PcdWrite(RevBuffer[1],&RevBuffer[2]);
            RevBuffer[0]=1;
            break;
        case 10:
            PcdValue(RevBuffer[1],RevBuffer[7],&RevBuffer[3]);
            RevBuffer[0]=1;
            break;
        case 12:    // 參數(shù)設(shè)置
            PcdBakValue(RevBuffer[1], RevBuffer[2]);
            RevBuffer[0]=1;    //contact
            RevBuffer[1]=0;
            break;
ID:471889 發(fā)表于 2020-7-17 08:15 | 顯示全部樓層
不要被別人取的名字迷惑,你想象成一般數(shù)組與變量就好了
ID:1013634 發(fā)表于 2022-3-28 16:32 | 顯示全部樓層
只是定義而已,隨便什么名稱(chēng)都一樣的
