查看: 1197|回復(fù): 0
貪吃蛇獨立鍵盤控制上下左右,矩陣鍵盤控制一次蛇的速度
ID:805121 發(fā)表于 2020-7-18 14:58 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
void Keypros()
char a=0;
press=0x0f;
if (press!=0x0f)
  delay(1000);
  if (press!=0x0f)
   press=0x0f;
   switch (press)
    case (0x07):num=0;break;
    case (0x0b):num=1;break;
    case (0x0d):num=2;break;
    case (0x0e):num=3;break;
   press=0xf0;
   switch (press)
    case (0x70):num=num;break;
    case (0xb0):num=num+4;break;
    case (0xd0):num=num+8;break;
    case (0xe0):num=num+12;break;
while ((press!=0xf0)&&(a<50))
  //delay(10);
  a++;
if(up==0)
  delay(1000);
  if(up==0)
    if(direction==3|direction==4)
    direction=1;
  while(!up);
if(down==0)
  delay(1000);
  if(down==0)
  { if(direction==3|direction==4)
   direction=2;
  while(!down);
if(lt==0)
  delay(100);
  if(lt==0)
      if(direction==1|direction==2)
   direction=3;
  while(!lt);
if(rt==0)
  delay(1000);
  if(rt==0)
     direction=4;
  while(!rt);
