查看: 1153|回復(fù): 0
lcd shift text from top to bottom
ID:805239 發(fā)表于 2020-7-18 20:51 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
_______________________________________
$regfile = "m8def.dat"
$crystal = 1000000
$baud = 9600
$hwstack = 40
$swstack = 16
$framesize = 32
Dim Txt As String * 20
Dim Txt_1 As String * 20
Dim Time_txt As Word
Dim A As Byte
Dim B As Byte
Dim C As Byte
Dim E As Byte
Config Lcd = 16x2
Config Lcdpin = Pin, Db4 = Portb.3, Db5 = Portb.2, _
Db6 = Portb.1, Db7 = Portb. 0, E = Portb.4, Rs = Portb.5
Cursor Off
Cls
Input "SEND TXT:", Txt
Input "SEND TIME(MS):", Time_txt
Print
Print
Print "# ####### #"
Print "# # # # #"
Print "# # # # #"
Print "##### # ### ######"
Print "# # # # # # #"
Print "# # ### ### # #"
A = Len(txt)
C = 17-A
Do
    For B = 1 To 17
        Cls
        Locate 1, B
        Lcd Txt
        If B> C Then
            E = BC
            Txt_1 = Right(txt, E)
            Locate 2, 1
            Lcd Txt_1
        End If
        Waitms Time_txt
    Next
    For B = 1 To 17
        Cls
        Locate 2, B
        Lcd Txt
        If B>C Then
            E = BC
            Locate 1, 1
            Lcd Txt_1
        End If
        Waitms Time_txt
    Next
Loop
End
enjoy it
