查看: 5109|回復(fù): 5
STM32F103C8T6驅(qū)動(dòng)WS2812B源程序
ID:98798 發(fā)表于 2020-7-30 08:44 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
void Timer2_init(void)
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_OCInitTypeDef  TIM_OCInitStructure;
  DMA_InitTypeDef DMA_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
        /* GPIOA Configuration: TIM2 Channel 1 as alternate function push-pull */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
        /* Compute the prescaler value */
        //PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;
        /* Time base configuration */
        TIM_TimeBaseStructure.TIM_Period = 90-1; // 800kHz
        TIM_TimeBaseStructure.TIM_Prescaler = 0;
        TIM_TimeBaseStructure.TIM_ClockDivision = 0;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
        /* PWM1 Mode configuration: Channel1 */
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_Pulse = 0;
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
        TIM_OC1Init(TIM2, &TIM_OCInitStructure);
        /* configure DMA */
        /* DMA clock enable */
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
        /* DMA1 Channel6 Config */
        DMA_DeInit(DMA1_Channel2);
        DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)TIM2_CCR1_Address;        // physical address of Timer 3 CCR1
        DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)LED_BYTE_Buffer;                // this is the buffer memory
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;                                                // data shifted from memory to peripheral
        DMA_InitStructure.DMA_BufferSize = 42;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                                        // automatically increase buffer index
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;                                                        // stop DMA feed after buffer size is reached
        DMA_InitStructure.DMA_Priority = DMA_Priority_High;
        DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
        DMA_Init(DMA1_Channel2, &DMA_InitStructure);
                /* TIM3 CC1 DMA Request enable */
        TIM_DMACmd(TIM2, TIM_DMA_Update, ENABLE);
void WS2812_send(uint8_t (*color)[3], uint16_t len)
        uint8_t i;
        uint16_t memaddr;
        uint16_t buffersize;
        buffersize = (len*24)+43;        // number of bytes needed is #LEDs * 24 bytes + 42 trailing bytes
        memaddr = 0;                                // reset buffer memory index
        while (len)
                                for(i=0; i<8; i++) // GREEN data
                                        LED_BYTE_Buffer[memaddr] = ((color[0][1]<<i) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
                                        memaddr++;
                        for(i=0; i<8; i++) // RED
                                        LED_BYTE_Buffer[memaddr] = ((color[0][0]<<i) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
                                        memaddr++;
                        for(i=0; i<8; i++) // BLUE
                                        LED_BYTE_Buffer[memaddr] = ((color[0][2]<<i) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
                                        memaddr++;
                  len--;
//bug:最后一個(gè)周期波形不知道為什么全是高電平,故增加一個(gè)波形
          LED_BYTE_Buffer[memaddr] = ((color[0][2]<<8) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
          memaddr++;
                while(memaddr < buffersize)
                        LED_BYTE_Buffer[memaddr] = 0;
                        memaddr++;
                DMA_SetCurrDataCounter(DMA1_Channel2, buffersize);         // load number of bytes to be transferred
                DMA_Cmd(DMA1_Channel2, ENABLE);                         // enable DMA channel 6
                TIM_Cmd(TIM2, ENABLE);                                                 // enable Timer 3
                while(!DMA_GetFlagStatus(DMA1_FLAG_TC2)) ;         // wait until transfer complete
                TIM_Cmd(TIM2, DISABLE);         // disable Timer 3
                DMA_Cmd(DMA1_Channel2, DISABLE);                         // disable DMA channel 6
                DMA_ClearFlag(DMA1_FLAG_TC2);                                 // clear DMA1 Channel 6 transfer complete flag
int main(void)
        delay_init();            //延時(shí)函數(shù)初始化
        LED_Init();                          //初始化與LED連接的硬件接口
  Timer2_init();
                WS2812_send(r,10);
                delay_ms(1000);
                WS2812_send(g,10);
                delay_ms(1000);
                WS2812_send(b,10);
                delay_ms(1000);
STM32F103C8T6驅(qū)動(dòng)WS2812B.7z
184.38 KB, 下載次數(shù): 240, 下載積分: 黑幣 -5
收藏收藏5 分享淘帖 頂 踩
ID:87063 發(fā)表于 2021-6-5 14:00 | 只看該作者
親測(cè)   這個(gè)程序有個(gè)bug 只能驅(qū)動(dòng)61個(gè)led 再多一個(gè)就不行了
ID:455905 發(fā)表于 2021-6-24 09:01 | 只看該作者
PA0為什么是DMA通道2,定時(shí)器TM2_CH1不是DMA通道5嗎
ID:455905 發(fā)表于 2021-6-24 09:03 | 只看該作者
為什么是DMA通道2,TIM2_CH1對(duì)應(yīng)不是DMA通道5嗎
ID:986209 發(fā)表于 2021-11-30 00:42 | 只看該作者
親測(cè)可以點(diǎn)亮燈珠uint16_t len設(shè)置成60,只有30個(gè)燈珠亮,不知道為什么
ID:1041297 發(fā)表于 2025-4-9 15:55 | 只看該作者
小魚(yú)仔1111 發(fā)表于 2021-6-24 09:01
我也很奇怪,換個(gè)IO口就配不出來(lái)了
