基于MM32F103 USB Custom_HID IAP 通訊例程,基于32位 ARM Cortex M3 的MM32F103xBx8的例程,BootLoader+Application兩部分
單片機源程序如下:
- /* Includes ------------------------------------------------------------------*/
- #include "MM32F103.h"
- #include "usb_lib.h"
- #include "hw_config.h"
- #include "usbio.h"
- #include "usb_regs.h"
- #include "delay.h"
- #include "sys.h"
- #include "usb_pwr.h"
- #include "usb_desc.h"
- #include "platform_config.h"
- #include "uart.h"
- #include "bsp.h"
- #include "led.h"
- #include "pwm.h"
- #include "tim2.h"
- #include "string.h"
- /* Private typedef -----------------------------------------------------------*/
- #define PROTECT 0
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* Extern variables ----------------------------------------------------------*/
- /* Private function prototypes -----------------------------------------------*/
- void Delay(__IO uint32_t nCount);
- /* Private functions ---------------------------------------------------------*/
- // MM32F103RBT6 Application 0x08002000 -- 0x08020000 120K byte flash
- //#define ApplicationAddress 0x08002000 //APP addrress
- //#define VECTOR_SIZE 0xC0 //48*4=192 = 0xC0
- extern uint8_t Flag_Receive;
- extern u32 SystemCoreClock;
- extern u8 Flag_over;
- extern u8 count;
- * Function Name : main.
- * Description : main routine.
- * Input : None.
- * Output : None.
- * Return : None.
- int main(void)
- u16 data1, data2; //
- u8 t;
- SCB->VTOR = FLASH_BASE | FLASH_VTOR_OFFSET; /* Vector Table Relocation in Internal FLASH.*/
- __enable_irq();
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); // 設置中斷優(yōu)先級分組2
- uart_initwBaudRate(115200);
- #if PROTECT //是否開啟讀保護功能
- data1 = *(u32 *)0x1ffe0000; //地址Address必須是2的整數(shù)倍
- data2 = *(u32 *)0x1ffe0002; //地址Address必須是2的整數(shù)倍
- printf("\r\n Data1=%x,Data2=%x \r\n", data1, data2);
- if ((data1 != 0x7F80) || (data2 != 0xFF00))
- printf("Pro1\r\n");
- FLASH_Unlock();
- FLASH_EnableReadOutProtection();
- FLASH_UserOptionByteConfig(OB_IWDG_HW, OB_STOP_NoRST, OB_STDBY_NoRST);
- FLASH_Lock();
- #endif
- delay_init(); //延時函數(shù)初始化
- Set_System();
- LED_Init();
- USB_Interrupts_Config();
- Set_USBClock();
- USB_Init();
- TIM1_PWM_Init(1000 - 1, 96 - 1);
- Tim2_UPCount_test(500 - 1, 96 - 1);
- while (1)
- if (bDeviceState == CONFIGURED) //USB初始化完成
- if (Flag_Receive)
- APP_Program();
- Flag_Receive = 0;
- if (Flag_over) //將UART1 收到的數(shù)據重新發(fā)回去
- Flag_over = 0;
- for (t = 0; t < count; t++)
- while ((UART1->CSR & UART_IT_TXIEN) == 0)
- ; //等待發(fā)送結束
- UART1->TDR = UART_RX_BUF[t]; //TDR=buff[t];//
- ; //等待發(fā)送結束
- count = 0;
- * Function Name : Delay
- * Description : Inserts a delay time.
- * Input : nCount: specifies the delay time length.
- * Output : None
- * Return : None
- for (; nCount != 0; nCount--)
- #ifdef USE_FULL_ASSERT
- * Function Name : assert_failed
- * Description : Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * Input : - file: pointer to the source file name
- * - line: assert_param error line source number
- * Output : None
- * Return : None
- void assert_failed(uint8_t *file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while (1)
- #endif
- /******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
復制代碼
MM32F103_USB_IAP_Protect.7z
(175.46 KB, 下載次數(shù): 55)
2020-7-30 16:41 上傳
點擊文件名下載附件
USB IAP 下載積分: 黑幣 -5
