查看: 4679|回復: 12
怎樣把數(shù)碼管的小數(shù)點加上去,而且左移移動小數(shù)點位,不影響數(shù)碼管正常動態(tài)掃描顯示?
ID:792404 發(fā)表于 2020-8-3 08:57 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
10黑幣
#include"stc8g.h"
#include "intrins.h"
#define key_S 50
#define key_L key_S*120
#define key_I key_S*100
unsigned char T0RH=0;  //T0重載值的高字節(jié)
unsigned char T0RL=0;  //T0重載值的低字節(jié)
unsigned char i=0;         //數(shù)碼管位緩沖變量
unsigned char j1=0;         //數(shù)碼管位的顯示值
unsigned char j2=0;
unsigned char j3=0;
unsigned char j4=0;
unsigned char x=0;         //按鍵按下次數(shù)
unsigned char x1=0;         //計數(shù)值變量,定時器用
unsigned char x2=0;         //標志位
unsigned int  x3=0;
unsigned int  x4=0;
unsigned char x5=0;
unsigned int js=0;         //數(shù)碼管顯示的值
unsigned int js1=0;
//unsigned int js2=0;
unsigned char js3=0;
unsigned char code duan[16]={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15};
bit q1=1;
bit q2=1;
//bit q3=1;
bit q4=1;
sbit out=P3^3;        //out 輸出
sbit pa=P1^0;        //a 數(shù)碼管段
sbit pb=P1^1;        //b
sbit pc=P1^2;        //c
sbit pd=P1^3;        //d
sbit pe=P1^4;        //e
sbit pf=P1^5;        //f
sbit pg=P1^6;        //g
sbit ph=P1^7;        //.
sbit p1=P3^4;        //1         數(shù)碼管位
sbit p2=P3^5;        //2
sbit p3=P3^6;        //3
sbit p4=P3^7;        //4
sbit ru=P5^4;
sbit sw1=P5^5;  //按鍵接口
sbit sw2=P3^1;
sbit sw3=P3^0;
sbit sw4=P3^2;
void s0();
void s1();
void s2();
void s3();
void s4();
void s5();
void s6();
void s7();
void s8();
void s9();
void s10();
void s11();
void s12();
void s13();
void s14();
void s15();
void ssmg();
void xuaze(unsigned char j);
void xianshi1(unsigned int);
void keyaction();
void cun();
/*掉電存儲*/
void IapIdle();
char IapRead(int addr);
void IapProgram(int addr,char dat);
void IapErase(int addr);
void delayms(unsigned int k)
        unsigned int i,j;
        for(i=k;i>0;i--)
                for(j=110;j>0;j--);
void ConfigTimer0(unsigned int ms)
    unsigned long tmp;  //臨時變量
    tmp=11059200/12;      //定時器計數(shù)頻率
    tmp=(tmp*ms)/1000;  //計算所需的計數(shù)值
    tmp=65536-tmp;        //計算定時器重載值
    tmp=tmp+2;           //補償中斷響應延時造成的誤差
    T0RH=(unsigned char)(tmp>>8);  //定時器重載值拆分為高低字節(jié)
    T0RL=(unsigned char)tmp;
        TMOD&=0xf0;        //清零T0的控制位
        TMOD|=0x01;        //配置T0為模式1
    TH0=T0RH;     //加載T0重載值
    TL0=T0RL;
    ET0=1;        //使能T0中斷
    TR0=1;        //啟動T0
void QL()
                                 if(js<=1)js=1;
                                 if(js1<=1)js1=1;
                                 if(js3>=33) js3=0;
void tm0_isr() interrupt 1 using 1
    TH0=T0RH;  //重新加載重載值
    TL0=T0RL;
    ssmg();
    x4++;
         switch(js3)
                case 0:if(ru==0)out=0;else out=1;break;
                case 1:if(ru==0){out=~out;}break;
               /* case 2:if(x1==0){x1=1;j1=duan[14];j2=duan[14];j3=duan[14];j4=duan[14];QL();}
                       if(x1==1){x1=2;js3=IapRead(3);QL();}
                       if(x1==2){if(x4>=1000){x4=0;js--;if(js==0)
                                        {js=0;x4=0;x1=5;out=0;js=IapRead(1);QL();}}}
                                                        break;
                case 3:if(x1==0){x1=1;j1=duan[14];j2=duan[14];j3=duan[14];j4=duan[14];QL();}
                       if(x1==2){if(x4>=1000){x4=0;js--; if(js==0)
                                        {js=0;x4=0;x1=3;out=0;js=IapRead(1);QL();}}}
                   if(x1==3){if(x4>=1000){x4=0;js1--;if(js1==0)
                                        {js1=0;x4=0;x1=0;out=1;js1=IapRead(2);QL();}}}
                                                         break;          */
void keyscan()
        static unsigned int time=0;
        if(!sw1||!sw2||!sw3)
                time++;
                if(time>key_L)//長按有效
                        time=key_I;//連+/-間隔
                if(time==key_S)//短按消抖
                        if(!sw1){x1++;if(x1>3){x1=0;if(x1==0)cun();}}
                if(time==key_S||time==key_L)//短按消抖或長按連+/-
                        if(!sw2 && x1!=0){if(x1==1){js3=(js3+1)%33;}
                                          if(x1==2){js=(js+1)%1000;}
                                          if(x1==3){js1=(js1+1)%1000;}}
                        if(!sw3 && x1!=0){if(x1==1){js3--;if(js3==-1)js3=32;}
                                          if(x1==2){if(js>0){js--;if(js==0)js=1;}}
                                          if(x1==3){if(js1>0){js1--;if(js1==0)js1=1;}}}
                        if((!sw2)&&(!sw3)&&(x1!=0)){js=5;js1=5;js3=0;}
        else time=0;
void cun()
{                                         if(js<=1) js=1;
                                         if(js1<=1) js1=1;
                                         if(js3>=33) js3=0;
                                         IapErase(0);
                                         IapProgram(1,js);
                                         IapProgram(2,js1);
                                         IapProgram(3,js3);
        EA=1;
        ConfigTimer0(1);
        P1M0=0x00;
        P1M1=0x00;
        P3M0=0xff;
        P3M1=0x00;
        P5M0=0x00;
        P5M1=0x00;
        js=IapRead(1);
        js1=IapRead(2);
        js3=IapRead(3);
        QL();
            keyscan();
                if(x1==0){j1=duan[14];j2=duan[14];j3=duan[14];j4=duan[14];}
                if(x1==1){xianshi1(js3);j3=duan[14];j4=duan[15];}
                if(x1==2){xianshi1(js);j4=duan[11];}
                if(x1==3){xianshi1(js1);j4=duan[12];}
            delayms(1);
void IapIdle()
   IAP_CONTR=0;
   IAP_CMD=0;
   IAP_TRIG=0;
   IAP_ADDRH=0x80;
   IAP_ADDRL=0;
   char dat;
   IAP_CONTR=0x80;
   IAP_TPS=12;
   IAP_CMD=1;
   IAP_ADDRL=addr;
   IAP_ADDRH=addr>>8;
   IAP_TRIG=0x5a;
   IAP_TRIG=0xa5;
   _nop_();
   dat=IAP_DATA;
   IapIdle();
   return dat;
   IAP_CONTR=0x80;
   IAP_TPS=12;
   IAP_CMD=2;
   IAP_ADDRL=addr;
   IAP_ADDRH=addr>>8;
   IAP_DATA=dat;
   IAP_TRIG=0x5a;
   IAP_TRIG=0xa5;
   _nop_();
   IapIdle();
   IAP_CONTR=0x80;
   IAP_TPS=12;
   IAP_CMD=3;
   IAP_ADDRL=addr;
   IAP_ADDRH=addr>>8;
   IAP_TRIG=0x5a;
   IAP_TRIG=0xa5;
   _nop_();
   IapIdle();
void s0(){pa=0;pb=0;pc=0;pd=0;pe=0;pf=0;pg=1;}
void s1(){pb=0;pc=0;pa=1;pg=1;pd=1;pe=1;pf=1;}
void s2(){pa=0;pb=0;pg=0;pe=0;pd=0;pf=1;pc=1;}
void s3(){pa=0;pb=0;pg=0;pc=0;pd=0;pf=1;pe=1;}
void s4(){pb=0;pg=0;pc=0;pf=0;pa=1;pd=1;pe=1;}
void s5(){pa=0;pg=0;pc=0;pd=0;pf=0;pe=1;pb=1;}
void s6(){pa=0;pg=0;pc=0;pd=0;pf=0;pe=0;pb=1;}
void s7(){pa=0;pb=0;pc=0;pf=1;pe=1;pd=1;pg=1;}
void s8(){pa=0;pb=0;pg=0;pc=0;pd=0;pf=0;pe=0;}
void s9(){pa=0;pb=0;pg=0;pc=0;pd=0;pf=0;pe=1;}
void s10(){pa=1;pb=1;pc=1;pf=1;pe=1;pd=1;pg=1;}
void s11(){pa=1;pb=1;pc=0;pf=0;pe=0;pd=0;pg=0;ph=1;}
void s12(){pa=1;pb=1;pc=1;pf=1;pe=0;pd=0;pg=0;ph=1;}
void s13(){pa=1;pb=1;pc=1;pf=1;pe=1;pd=1;pg=1;ph=0;}
void s14(){pa=1;pb=1;pc=1;pf=1;pe=1;pd=1;pg=0;ph=1;}
void s15(){pa=0;pb=0;pc=1;pf=0;pe=0;pd=1;pg=0;ph=1;}
        if(j==0){s0();}
        else if(j==1){s1();}
        else if(j==2){s2();}
        else if(j==3){s3();}
        else if(j==4){s4();}
        else if(j==5){s5();}
        else if(j==6){s6();}
        else if(j==7){s7();}
        else if(j==8){s8();}
        else if(j==9){s9();}
        else if(j==10){s10();}
        else if(j==11){s11();}
        else if(j==12){s12();}
        else if(j==13){s13();}
        else if(j==14){s14();}
        else if(j==15){s15();}
/*數(shù)碼管顯示函數(shù),調(diào)用在主函數(shù)中*/
void xianshi1(unsigned int sec)
        j1=duan[sec%10];
        j2=duan[sec/10%10];
        j3=duan[sec/100%10];
/*數(shù)碼管掃描函數(shù),放到中斷中,中斷時間要是1ms*/
void ssmg()
    s10();
    switch(i)
              case 0:p1=1;p2=0;p3=0;p4=0;i++;s10();xuaze(j1);break;
           case 1:p1=0;p2=1;p3=0;p4=0;i++;s10();xuaze(j2);break;
           case 2:p1=0;p2=0;p3=1;p4=0;i++;s10();xuaze(j3);break;
           case 3:p1=0;p2=0;p3=0;p4=1;i=0;s10();xuaze(j4);break;
           default:break;
最佳答案
查看完整內(nèi)容
回帖中的附件《數(shù)碼管時鐘》有處理小數(shù)點在不同位置出現(xiàn)的方法。 http://www.torrancerestoration.com/bbs/dpj-193732-1.html
收藏收藏3 分享淘帖 頂 踩
ID:213173 發(fā)表于 2020-8-3 08:57 | 只看該作者
ID:331263 發(fā)表于 2020-8-3 11:09 | 只看該作者
本帖最后由 dingpeng1980 于 2020-8-3 11:12 編輯
在個位加個或運算共陰極  P1 = P1 | 0x80    共陽極  P1 = P1 & 0x7F
ID:331263 發(fā)表于 2020-8-3 11:10 | 只看該作者
在個位加一個語句 共陰極  P1 = P1 | 0x80 共陽極  P1 = P1 | 0x7F
ID:792404 發(fā)表于 2020-8-3 13:36 | 只看該作者
dingpeng1980 發(fā)表于 2020-8-3 11:10
試過了,還是不顯示,正常來說在某一位后面加上&0x7f會顯示的,但是沒用的。不知道是哪里出了問題
ID:807712 發(fā)表于 2020-8-3 13:55 | 只看該作者
小數(shù)點在初始化時直接加進去就好,后面也不會再動得了他,就是一個固定的顯示
ID:792404 發(fā)表于 2020-8-3 14:13 | 只看該作者
這是一個倒計時的程序代碼,還有個問題就是倒計時沒開始,先加減鍵設置好時間后,程序開始運行,倒計時時間運行過程中,為什么按加減鍵還會增加或減小數(shù)字?正常情況下,倒計時運行過程中,只有按設置鍵(就是程序中sw1)才會使倒計時停止并進入設置狀態(tài),其他按鍵不起作用才對的。請各位大俠指點一下,問題出在哪個地方了。
ID:792404 發(fā)表于 2020-8-3 14:19 | 只看該作者
塞北江南 發(fā)表于 2020-8-3 13:55
我是直接用一個獨立按鍵控制4位數(shù)碼管的小數(shù)點循環(huán)點亮,以達到個位小數(shù)點亮,以秒倒計時,十位小數(shù)點亮,以0.1秒倒計時,百位小數(shù)點亮,以0.01秒倒計時的效果,初始化時直接加進去不合適。
ID:275826 發(fā)表于 2020-8-3 19:04 | 只看該作者
程序結(jié)構(gòu)不清晰
ID:190577 發(fā)表于 2020-8-3 20:27 | 只看該作者
       j1=duan[sec%10];
        j2=duan[sec/10%10];
        j3=duan[sec/100%10];   這個位置加
ID:792404 發(fā)表于 2020-8-3 21:30 | 只看該作者
bbxyliyang 發(fā)表于 2020-8-3 20:27
j1=duan[sec%10];
        j2=duan[sec/10%10];
        j1=duan[sec%10];
        j2=duan[sec/10%10];
        j3=duan[sec/100%10]&0x7f;
這樣子加嗎?試過了,小數(shù)點不顯示。
        j1=duan[sec%10];
        j2=duan[sec/10%10];
       P1=P1&0x7f;
這樣子加,3位都會顯示小數(shù)點,但是不符合我的設計要求,我要求用一個獨立按鍵控制3位數(shù)碼管的小數(shù)點循環(huán)點亮,以達到個位小數(shù)點亮,以秒倒計時,十位小數(shù)點亮,以0.1秒倒計時,百位小數(shù)點亮,以0.01秒倒計時的效果
ID:462827 發(fā)表于 2020-8-4 00:44 | 只看該作者
你要哪個位置的數(shù)加就小數(shù)就只改它的段碼就行,如果是共陰的|0x80就加上小數(shù)點了,共陽的&0x7f就可以。
ID:792404 發(fā)表于 2020-8-4 07:05 | 只看該作者
wulin 發(fā)表于 2020-8-3 08:57
http://www.torrancerestoration.com/bbs/dpj-193732-1. ...
這個方法可以,現(xiàn)在正常了,謝謝師傅
