- /* USER CODE END Header */
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- /* Private includes ----------------------------------------------------------*/
- /* USER CODE BEGIN Includes */
- #include "dwt_stm32_delay.h"
- #include "i2c-lcd.h"
- /* USER CODE END Includes */
- /* Private typedef -----------------------------------------------------------*/
- /* USER CODE BEGIN PTD */
- /* USER CODE END PTD */
- /* Private define ------------------------------------------------------------*/
- /* USER CODE BEGIN PD */
- /* USER CODE END PD */
- /* Private macro -------------------------------------------------------------*/
- /* USER CODE BEGIN PM */
- /* USER CODE END PM */
- /* Private variables ---------------------------------------------------------*/
- I2C_HandleTypeDef hi2c1;
- /* USER CODE BEGIN PV */
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- static void MX_GPIO_Init(void);
- static void MX_I2C1_Init(void);
- /* USER CODE BEGIN PFP */
- /* USER CODE END PFP */
- /* Private user code ---------------------------------------------------------*/
- /* USER CODE BEGIN 0 */
- uint32_t data;
- uint8_t count;
- uint32_t receive_data (void)
- uint32_t code=0;
- /* The START Sequence begin here
- * there will be a pulse of 9ms LOW and
- * than 4.5 ms space (HIGH)
- while (!(HAL_GPIO_ReadPin (GPIOA, GPIO_PIN_1))); // wait for the pin to go high.. 9ms LOW
- while ((HAL_GPIO_ReadPin (GPIOA, GPIO_PIN_1))); // wait for the pin to go low.. 4.5ms HIGH
- /* START of FRAME ends here*/
- /* DATA Reception
- * We are only going to check the SPACE after 562.5us pulse
- * if the space is 562.5us, the bit indicates '0'
- * if the space is around 1.6ms, the bit is '1'
- for (int i=0; i<32; i++)
- count=0;
- while (!(HAL_GPIO_ReadPin (GPIOA, GPIO_PIN_1))); // wait for pin to go high.. this is 562.5us LOW
- while ((HAL_GPIO_ReadPin (GPIOA, GPIO_PIN_1))) // count the space length while the pin is high
- count++;
- DWT_Delay_us(100);
- if (count > 12) // if the space is more than 1.2 ms
- code |= (1UL << (31-i)); // write 1
- else code &= ~(1UL << (31-i)); // write 0
- return code;
- void convert_code (uint32_t code)
- switch (code)
- case (0xFFA25D):
- lcd_send_cmd (0x86);
- lcd_send_data ('1');
- break;
- case (0xFF629D):
- lcd_send_data ('2');
- break;
- case (0xFFE21D):
- lcd_send_data ('3');
- break;
- case (0xFF22DD):
- lcd_send_data ('4');
- break;
- case (0xFF02FD):
- lcd_send_data ('5');
- break;
- case (0xFFC23D):
- lcd_send_data ('6');
- break;
- case (0xFFE01F):
- lcd_send_data ('7');
- break;
- case (0xFFA857):
- lcd_send_data ('8');
- break;
- case (0xFF906F):
- lcd_send_data ('9');
- break;
- case (0xFFB04F):
- lcd_send_data ('#');
- break;
- case (0XFF6897):
- lcd_send_data ('*');
- break;
- case (0xFF9867):
- lcd_send_data ('0');
- break;
- case (0xFF38C7):
- lcd_send_data ('K');
- break;
- case (0xFF18E7):
- lcd_send_data ('^');
- break;
- case (0xFF10EF):
- lcd_send_data ('<');
- break;
- case (0xFF5AA5):
- lcd_send_data ('>');
- break;
- case (0xFF4AB5):
- lcd_send_data ('u');
- break;
- default :
- break;
- /* USER CODE END 0 */
- * @brief The application entry point.
- * @retval int
- int main(void)
- /* USER CODE BEGIN 1 */
- /* USER CODE END 1 */
- /* MCU Configuration--------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_I2C1_Init();
- /* USER CODE BEGIN 2 */
- DWT_Delay_Init ();
- lcd_init ();
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- while (HAL_GPIO_ReadPin (GPIOA, GPIO_PIN_1)); // wait for the pin to go low
- data = receive_data ();
- convert_code (data);
- HAL_Delay (200);
- /* USER CODE END 3 */
- * @brief System Clock Configuration
- * @retval None
- RCC_OscInitTypeDef RCC_OscInitStruct = {0};
- RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
- /**Initializes the CPU, AHB and APB busses clocks
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStruct.HSEState = RCC_HSE_ON;
- RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
- RCC_OscInitStruct.HSIState = RCC_HSI_ON;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
- RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- Error_Handler();
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
- Error_Handler();
- * @brief I2C1 Initialization Function
- * @param None
- * @retval None
- /* USER CODE BEGIN I2C1_Init 0 */
- /* USER CODE END I2C1_Init 0 */
- /* USER CODE BEGIN I2C1_Init 1 */
- /* USER CODE END I2C1_Init 1 */
- hi2c1.Instance = I2C1;
- hi2c1.Init.ClockSpeed = 100000;
- hi2c1.Init.DutyCycle = I2C_DUTYCYCLE_2;
- hi2c1.Init.OwnAddress1 = 0;
- hi2c1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
- hi2c1.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
- hi2c1.Init.OwnAddress2 = 0;
- hi2c1.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
- hi2c1.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
- if (HAL_I2C_Init(&hi2c1) != HAL_OK)
- Error_Handler();
- /* USER CODE BEGIN I2C1_Init 2 */
- /* USER CODE END I2C1_Init 2 */
- * @brief GPIO Initialization Function
- * @param None
- * @retval None
- GPIO_InitTypeDef GPIO_InitStruct = {0};
- /* GPIO Ports Clock Enable */
- __HAL_RCC_GPIOD_CLK_ENABLE();
- __HAL_RCC_GPIOA_CLK_ENABLE();
- __HAL_RCC_GPIOB_CLK_ENABLE();
- /*Configure GPIO pin : PA1 */
- GPIO_InitStruct.Pin = GPIO_PIN_1;
ir-remote.7z
2020-8-3 18:19 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
2.89 MB, 下載次數(shù): 6, 下載積分: 黑幣 -5
