查看: 6596|回復(fù): 0
Proteus8.9 VSM Studio GCC編譯器仿真RtThread RealTime STM32F401VE_系列001_跑馬燈
一,打開(kāi)文件(可以隨文下載放置在文檔中打開(kāi))。(如下圖1所示)
圖1
二,調(diào)整原理圖大小,適合可視,另存工程文件。(如下圖2,3,4所示)
圖2
圖3
圖4
三,點(diǎn)擊Source Code標(biāo)簽。(如下圖5所示)
圖5
四,編輯main.c Proteus8.9 VSM Studio GCC編譯器仿真RtThread RealTime STM32F401VE_系列001_跑馬燈 (如下圖6所示)
五,Main.c 代碼:
/* Main.c file generated by New Project wizard
* Author:   Ziegler Yin
* Created:   周四 一月 16 2020
* Processor: STM32F407ZGT6ZGT6
* Compiler:  GCC for ARM
#include "mfuncs.h"
#include "delay.h"
#include "usart.h"
#include "sys.h"
#include <rtthread.h>
#define LED0 PCout(0)
#define LED1 PCout(1)
#define LED2 PCout(2)
        static struct rt_thread led_thread;
        static char led_thread_stack[256];
static void MX_GPIO_Init(void)
          GPIO_InitTypeDef  GPIO_InitStructure;
          RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);//使能GPIOF時(shí)鐘
          //GPIOF9,F10初始化設(shè)置
          GPIO_InitStructure.GPIO_Pin= GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2;//LED對(duì)應(yīng)引腳
          GPIO_InitStructure.GPIO_Mode= GPIO_Mode_OUT;//普通輸出模式
          GPIO_InitStructure.GPIO_OType= GPIO_OType_PP;//推挽輸出
          GPIO_InitStructure.GPIO_Speed= GPIO_Speed_100MHz;//100MHz
          GPIO_InitStructure.GPIO_PuPd= GPIO_PuPd_UP;//上拉
          GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化
                LED0= 0;
                LED1= 1;
static void led_thread_entry(void * parameter) {
        while(1) {
                LED0= ~LED0;
                LED1= ~LED1;
                uprint("控制芯片STM32F401VE_RtThread RealTime_跑馬燈仿真開(kāi)始了。\r\n");
                rt_thread_mdelay(500);
int main(void)
        delay_init(84);  //初始化延時(shí)函數(shù)
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置系統(tǒng)中斷優(yōu)先級(jí)分組2
        uart_init(9600);//初始化串口波特率為115200
        MX_GPIO_Init();
        rt_thread_mdelay(30);
        rt_err_t rst;
        rst= rt_thread_init(&led_thread,
        "ledshine",
        led_thread_entry,
        RT_NULL,
        &led_thread_stack[0],
        sizeof(led_thread_stack),
        RT_THREAD_PRIORITY_MAX - 2,
        20);
        if(rst== RT_EOK) {
                rt_thread_startup(&led_thread);
   while(1) //實(shí)現(xiàn)比較值從0-300遞增,到300后從300-0遞減,循環(huán)
                rt_thread_mdelay(100);
六,點(diǎn)擊構(gòu)建工程按鈕,編譯工程。(如下圖6所示)
圖6
七,點(diǎn)擊窗口左下方仿真按鈕,可見(jiàn)虛擬LED顯示。 (如下圖7,8,9所示)
圖7
圖8
圖9
八,選擇release,點(diǎn)擊構(gòu)建工程按鈕,編譯工程生成Hex文件。(如下圖10所示)
圖10
附件Proteus8.9 VSM Studio GCC編譯器仿真RtThread RealTime STM32F401VE_系列001_跑馬燈在已安裝Proteus8.9的計(jì)算機(jī)文件夾中打開(kāi)即可
需要進(jìn)一步了解,請(qǐng)加入QQ群:976235464
RtThread_Keil_F401_001_跑馬燈12pt.rar
447.42 KB, 下載次數(shù): 27, 下載積分: 黑幣 -5
