查看: 6370|回復(fù): 9
4KW LLC教程教學(xué)數(shù)字開關(guān)電源 LLC設(shè)計(jì)步驟,關(guān)鍵元器件計(jì)算書
4KW  LLC教程教學(xué)數(shù)字開關(guān)電源、 LLC設(shè)計(jì)步驟 、關(guān)鍵元器件計(jì)算書、全過程就是逐步指導(dǎo) 變壓器詳細(xì)設(shè)計(jì)資料 原理圖和pcblayout
資料文件太多分成3個(gè)壓縮包
// FILE:   Example_2803xAdcSoc.c
// TITLE:  ADC Start of Conversion example
//! \addtogroup f2803x_example_list
//! <h1> ADC Start of Conversion (adc_soc)</h1>
//! This ADC example uses ePWM1 to generate a periodic ADC SOC - ADCINT1.
//! Two channels are converted, ADCINA4 and ADCINA2.
//! \b Watch \b Variables \n
//! - Voltage1[10]    - Last 10 ADCRESULT0 values
//! - Voltage2[10]    - Last 10 ADCRESULT1 values
//! - ConversionCount - Current result number 0-9
//! - LoopCount       - Idle loop counter
// $TI Release: F2803x Support Library v2.01.00.00 $
// $Release Date: Mon May 22 15:41:40 CDT 2017 $
// $Copyright:
// Copyright (C) 2009-2017 Texas Instruments Incorporated - wwwticom
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
//   Redistributions of source code must retain the above copyright
//   notice, this list of conditions and the following disclaimer.
//   Redistributions in binary form must reproduce the above copyright
//   notice, this list of conditions and the following disclaimer in the
//   documentation and/or other materials provided with the
//   distribution.
//   Neither the name of Texas Instruments Incorporated nor the names of
//   its contributors may be used to endorse or promote products derived
//   from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "DSP28x_Project.h"     // Device Headerfile and Examples Include File
#include "ISR_50kHz.h"
#include <string.h>
#include <stdint.h>
// Function Prototypes
__interrupt void adc_isr(void);
void Adc_Config(void);
void EPWM1and2_Init(void);//LLC driver  may be used in interleaving LLC
void EPWM3_Init(void);//50kHz AD_ISR triggle
void EPWM4_Init(void);//50kHz AD_ISR triggle
void EPWM5_Init(void);//DAC0 and DAC1
void ADC_Init(void);//ADC init
void GPIO_Init(void);
Uint16 LoopCount;
Uint16 ConversionCount;
Uint16 Voltage1[10];
Uint16 Voltage2[10];
extern Uint16 RamfuncsLoadStart;
extern Uint16 RamfuncsLoadSize;
extern Uint16 RamfuncsRunStart;
void MemCopy(Uint16 *SourceAddr, Uint16* SourceEndAddr, Uint16* DestAddr)
    while(SourceAddr < SourceEndAddr)
       *DestAddr++ = *SourceAddr++;
    return;
// Main
void main(void)
    InitSysCtrl();
    DINT;
    InitPieCtrl();
    IER = 0x0000;
    IFR = 0x0000;
    EALLOW;
        InitPieVectTable();
       EDIS;
    EALLOW;             // This is needed to write to EALLOW protected register
    PieVectTable.EPWM4_INT = &adc_isr;
    EDIS;    // This is needed to disable write to EALLOW protected registers
    memcpy((uint16_t *)&RamfuncsRunStart,(uint16_t *)&RamfuncsLoadStart,
            (unsigned long)&RamfuncsLoadSize);
    GPIO_Init();
    InitFlash();
    InitSciGpio();
    InitAdc();  // For this example, init the ADC
    AdcOffsetSelfCal();
    EALLOW;
    SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1;     // enable TBCLK within the ePWM
    EDIS;
    IER |= M_INT3;                     // Enable CPU Interrupt 1
    IER |= M_INT9;                     // Enable CPU Interrupt 9
   //    PieCtrlRegs.PIEIER1.bit.INTx1 = 1; // Enable INT 1.1 in the PIE
    PieCtrlRegs.PIEIER3.bit.INTx4 = 1;//enable EPWM4 INterrput
    PieCtrlRegs.PIEIER9.bit.INTx1=1;// Enable INT 9.1 in the PIE SCIRX interrupt
    EINT;                              // Enable Global interrupt INTM
    ERTM;                              // Enable Global realtime interrupt DBGM
    EPWM1and2_Init();
           EPWM3_Init();
           EPWM4_Init();
           EPWM5_Init();
           ADC_Init();
     ID2DCalValueInit();
     ID2DTime100us.TimebaseDebug1minCnt=0;
     ID2DTime100us.TimebaseStateMachine5msCnt=0;
    for(;;)
        if(ISR_10KHzCnt>=4)
            ISR_10KHzCnt=0;
               ISR_10kHz();
    EALLOW;
    // EPWM Module 1 config
    EPwm1Regs.TBPRD = 600; // Period = 300 TBCLK counts  60M/100k=600
    EPwm1Regs.TBPHS.half.TBPHS = 0; // Set Phase register to zero
    EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; // Symmetrical mode
    EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Master module
    EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW;
    EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO; // Sync down-stream module
    EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_DISABLE; // Sync down-stream module
    EPwm1Regs.TBCTL.bit.CLKDIV=TB_DIV1;
    EPwm1Regs.TBCTL.bit.HSPCLKDIV=TB_DIV1;
    EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
    EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
    EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_PRD; // load on CTR=Zero
    EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_PRD; // load on CTR=Zero
    EPwm1Regs.AQCTLA.bit.ZRO = AQ_SET; // set actions for EPWM1A
    EPwm1Regs.AQCTLA.bit.CAU = AQ_CLEAR;
    EPwm1Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE; // enable Dead-band module  DBA_ALL
    EPwm1Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; // Active Hi complementary
    EPwm1Regs.DBFED = 270; // FED = 270 TBCLKs
    EPwm1Regs.DBRED = 270; // RED = 270 TBCLKs
//    EPwm1Regs.ETSEL.bit.SOCAEN  = 1;    // Enable SOC on A group
//    EPwm1Regs.ETSEL.bit.SOCASEL = ET_CTR_ZERO;    // Select SOC from from zero on upcount
//    EPwm1Regs.ETPS.bit.SOCAPRD  = 1;    // Generate pulse on 1st event
    EPwm1Regs.TZSEL.bit.OSHT1=1;//TZ1 will be one shot signal for EPWM1
    EPwm2Regs.TZSEL.bit.OSHT1=1;//TZ1 will be one shot signal for EPWM2
    EPwm1Regs.TZSEL.bit.OSHT2=1;//TZ2 will be one shot signal for EPWM1
    EPwm2Regs.TZSEL.bit.OSHT2=1;//TZ2 will be one shot signal for EPWM2
    EPwm1Regs.TZSEL.bit.OSHT3=1;//TZ3 will be one shot signal for EPWM1
    EPwm2Regs.TZSEL.bit.OSHT3=1;//TZ3 will be one shot signal for EPWM2
    EPwm1Regs.TZCTL.bit.TZA=2;//TZ will Force EPWM1A to a low state
    EPwm1Regs.TZCTL.bit.TZB=2;//TZ will Force EPWM1B to a low state
    EPwm2Regs.TZCTL.bit.TZA=2;//TZ will Force EPWM2A to a low state
    EPwm2Regs.TZCTL.bit.TZB=2;//TZ will Force EPWM2B to a low state
    // EPWM Module 2 config
    EPwm2Regs.TBPRD = 600; // Period = 600 TBCLK counts
    EPwm2Regs.TBPHS.half.TBPHS = 150; // Phase = 150/600 * 360 = 90 deg
    EPwm2Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; // Symmetrical mode
    EPwm2Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Slave module
    EPwm2Regs.TBCTL.bit.PHSDIR = TB_DOWN; // Count DOWN on sync (=90 deg)
    EPwm2Regs.TBCTL.bit.PRDLD = TB_SHADOW;
    EPwm2Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN; // sync flow-through
    EPwm2Regs.TBCTL.bit.CLKDIV=TB_DIV1;
    EPwm2Regs.TBCTL.bit.HSPCLKDIV=TB_DIV1;
    EPwm2Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
    EPwm2Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
    EPwm2Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // load on CTR=Zero
    EPwm2Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; // load on CTR=Zero
    EPwm2Regs.AQCTLA.bit.ZRO = AQ_SET; // set actions for EPWM2A
    EPwm2Regs.AQCTLA.bit.CAU = AQ_CLEAR;
    EPwm2Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE; // enable Dead-band module
    EPwm2Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; // Active Hi Complementary
    EPwm2Regs.DBFED = 270; // FED = 20 TBCLKs
    EPwm2Regs.DBRED = 270; // RED = 20 TBCLKs
    EDIS;
        // Assumes ePWM3 clock is already enabled in InitSysCtrl();
    EALLOW;
        EPwm3Regs.TBPHS.half.TBPHS = 0; // Phase = 150/600 * 360 = 90 deg
        EPwm3Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; // Symmetrical mode
        EPwm3Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Slave module
        EPwm3Regs.TBCTL.bit.PHSDIR = TB_DOWN; // Count DOWN on sync (=90 deg)
        EPwm3Regs.TBCTL.bit.PRDLD = TB_SHADOW;
        EPwm3Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN; // sync flow-through
        EPwm3Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // TBCLK = SYSCLK
        EPwm3Regs.TBCTL.bit.CLKDIV = TB_DIV1;
        EPwm3Regs.ETSEL.bit.SOCAEN  = 1;    // Enable SOC on A group
        EPwm3Regs.ETSEL.bit.SOCASEL = ET_CTR_ZERO;    // Select SOC from from zero on upcount
        EPwm3Regs.ETPS.bit.SOCAPRD  = ET_1ST;    // Generate pulse on 1st event
        EPwm3Regs.CMPA.half.CMPA    = 150;       // Set compare A value
        EPwm3Regs.TBPRD             = 600;   // Set period for ePWM3
        EPwm3Regs.TBCTL.bit.CTRMODE     = TB_COUNT_UP;        // count up and start
        EPwm3Regs.AQCTLA.bit.ZRO = AQ_SET;
        EPwm3Regs.AQCTLA.bit.CAU = AQ_CLEAR;
        EDIS;
        // Assumes ePWM4 clock is already enabled in InitSysCtrl();
    EALLOW;
        EPwm4Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Phase loading disabled
        EPwm4Regs.TBCTL.bit.PRDLD = TB_SHADOW;
        EPwm4Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_DISABLE;
        EPwm4Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // TBCLK = SYSCLK
        EPwm4Regs.TBCTL.bit.CLKDIV = TB_DIV1;
        EPwm4Regs.CMPA.half.CMPA    = 0;       // Set compare A value
        EPwm4Regs.TBPRD             = 1500;   // Set period for ePWM3    60M/40k=1500
        EPwm4Regs.TBCTL.bit.CTRMODE     = TB_COUNT_UP;        // count up and start
        EPwm4Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO;      // Enable INT on Zero event
        EPwm4Regs.ETSEL.bit.INTEN = 1;   // Enable INT
        EPwm4Regs.ETPS.bit.INTPRD = ET_1ST;            // Generate INT on 1th event
        EPwm4Regs.AQCTLA.bit.ZRO = AQ_SET;
        EPwm4Regs.AQCTLA.bit.CAU = AQ_CLEAR;
EDIS;
//use as DA output
    EALLOW;
    EPwm5Regs.TBPRD = 1024; // Period = 1024 TBCLK counts
    EPwm5Regs.CMPA.half.CMPA = 0; // Compare A = 350 TBCLK counts
    EPwm5Regs.CMPB = 0; // Compare B = 200 TBCLK counts
    EPwm5Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP;
    EPwm5Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Phase loading disabled
    EPwm5Regs.TBCTL.bit.PRDLD = TB_SHADOW;
    EPwm5Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_DISABLE;
    EPwm5Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // TBCLK = SYSCLK
    EPwm5Regs.TBCTL.bit.CLKDIV = TB_DIV1;
    EPwm5Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
    EPwm5Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
    EPwm5Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // load on CTR = Zero
    EPwm5Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; // load on CTR = Zero
    EPwm5Regs.AQCTLA.bit.ZRO = AQ_SET;
    EPwm5Regs.AQCTLA.bit.CAU = AQ_CLEAR;
    EPwm5Regs.AQCTLB.bit.ZRO = AQ_SET;
    EPwm5Regs.AQCTLB.bit.CBU = AQ_CLEAR;
    EDIS;
void ADC_Init(void)
    EALLOW;
    AdcRegs.ADCCTL2.bit.ADCNONOVERLAP=1;//AD no overlap ADCNONOVERLAP
    AdcRegs.ADCCTL2.bit.CLKDIV2EN=0;    //CLKDIV2EN
    AdcRegs.ADCSAMPLEMODE.bit.SIMULEN0=1;
    AdcRegs.ADCSAMPLEMODE.bit.SIMULEN2=1;
    AdcRegs.ADCSAMPLEMODE.bit.SIMULEN4=1;
    AdcRegs.ADCSAMPLEMODE.bit.SIMULEN6=1;
    AdcRegs.ADCSAMPLEMODE.bit.SIMULEN8=1;
    AdcRegs.ADCSAMPLEMODE.bit.SIMULEN10=1;
    AdcRegs.ADCSAMPLEMODE.bit.SIMULEN12=1;
    AdcRegs.ADCSOC0CTL.bit.CHSEL    = 3;    //set SOC0 channel select to ADCINA0 ADCINB0
    AdcRegs.ADCSOC2CTL.bit.CHSEL    = 0;    //set SOC2 channel select to ADCINA0 ADCINB0
    AdcRegs.ADCSOC4CTL.bit.CHSEL    = 1;    //set SOC4 channel select to ADCINA1 ADCINB1
    AdcRegs.ADCSOC6CTL.bit.CHSEL    = 3;    //set SOC6 channel select to ADCINA3 ADCINB3
    AdcRegs.ADCSOC8CTL.bit.CHSEL    = 5;    //set SOC8 channel select to ADCINA5 ADCINB5
    AdcRegs.ADCSOC10CTL.bit.CHSEL   = 7;    //set SOC10 channel select to ADCINA7 ADCINB7
    AdcRegs.ADCSOC12CTL.bit.CHSEL   = 7;    //set SOC12 channel select to ADCINA7 ADCINB7
    // set SOC0 start trigger on EPWM3A,
    AdcRegs.ADCSOC0CTL.bit.TRIGSEL  = 0x09;
//   AdcRegs.ADCSOC1CTL.bit.TRIGSEL  = 0x0A;
    AdcRegs.ADCSOC2CTL.bit.TRIGSEL  = 0x09;
//    AdcRegs.ADCSOC3CTL.bit.TRIGSEL  = 0x0A;
    AdcRegs.ADCSOC4CTL.bit.TRIGSEL  = 0x09;
//   AdcRegs.ADCSOC5CTL.bit.TRIGSEL  = 0x0A;
    AdcRegs.ADCSOC6CTL.bit.TRIGSEL  = 0x09;
//    AdcRegs.ADCSOC7CTL.bit.TRIGSEL  = 0x0A;
    AdcRegs.ADCSOC8CTL.bit.TRIGSEL  = 0x09;
//    AdcRegs.ADCSOC9CTL.bit.TRIGSEL  = 0x0A;
    AdcRegs.ADCSOC10CTL.bit.TRIGSEL  = 0x09;
//    AdcRegs.ADCSOC11CTL.bit.TRIGSEL  = 0x0A;
    AdcRegs.ADCSOC12CTL.bit.TRIGSEL  = 0x09;
//    AdcRegs.ADCSOC13CTL.bit.TRIGSEL  = 0x0A;
    // set SOC0 S/H Window to 9 ADC Clock Cycles, (8 ACQPS plus 1)
    AdcRegs.ADCSOC0CTL.bit.ACQPS    = 8;
    // set SOC1 S/H Window to 9 ADC Clock Cycles, (8 ACQPS plus 1)
    AdcRegs.ADCSOC1CTL.bit.ACQPS    = 8;
    // set SOC2 S/H Window to 9 ADC Clock Cycles, (8 ACQPS plus 1)
    AdcRegs.ADCSOC2CTL.bit.ACQPS    = 8;
    // set SOC3 S/H Window to 9 ADC Clock Cycles, (8 ACQPS plus 1)
    AdcRegs.ADCSOC3CTL.bit.ACQPS    = 8;
    // set SOC4 S/H Window to 9 ADC Clock Cycles, (8 ACQPS plus 1)
    AdcRegs.ADCSOC4CTL.bit.ACQPS    = 8;
    // set SOC5 S/H Window to 9 ADC Clock Cycles, (8 ACQPS plus 1)
    AdcRegs.ADCSOC5CTL.bit.ACQPS    = 8;
    // set SOC6 S/H Window to 9 ADC Clock Cycles, (8 ACQPS plus 1)
    AdcRegs.ADCSOC6CTL.bit.ACQPS    = 8;
    // set SOC7 S/H Window to 9 ADC Clock Cycles, (8 ACQPS plus 1)
    AdcRegs.ADCSOC7CTL.bit.ACQPS    = 8;
    // set SOC8 S/H Window to 9 ADC Clock Cycles, (8 ACQPS plus 1)
    AdcRegs.ADCSOC8CTL.bit.ACQPS    = 8;
    // set SOC9 S/H Window to 9 ADC Clock Cycles, (8 ACQPS plus 1)
    AdcRegs.ADCSOC9CTL.bit.ACQPS    = 8;
     // set SOC10 S/H Window to 9 ADC Clock Cycles, (8 ACQPS plus 1)
    AdcRegs.ADCSOC10CTL.bit.ACQPS    = 8;
    // set SOC11 S/H Window to 9 ADC Clock Cycles, (8 ACQPS plus 1)
    AdcRegs.ADCSOC11CTL.bit.ACQPS    = 8;
    AdcRegs.ADCSOC12CTL.bit.ACQPS    = 8;
    AdcRegs.ADCSOC13CTL.bit.ACQPS    = 8;
    EDIS;
    EALLOW;
            GpioCtrlRegs.GPAMUX1.bit.GPIO0=0; //PWM1A->GPIO0
            GpioCtrlRegs.GPAMUX1.bit.GPIO1=0; //PWM1B GPIO1
            GpioCtrlRegs.GPAMUX1.bit.GPIO2=0; //PWM2A GPIO2
            GpioCtrlRegs.GPAMUX1.bit.GPIO3=0; //PWM2B->GPIO3
            GpioCtrlRegs.GPADIR.bit.GPIO0=1;//GPIO0->output
            GpioCtrlRegs.GPADIR.bit.GPIO1=1;//GPIO1->output
            GpioCtrlRegs.GPADIR.bit.GPIO2=1;//GPIO2->output
            GpioCtrlRegs.GPADIR.bit.GPIO3=1;//GPIO3->output
            GpioDataRegs.GPACLEAR.bit.GPIO0=1;
            GpioDataRegs.GPACLEAR.bit.GPIO1=1;
            GpioDataRegs.GPACLEAR.bit.GPIO2=1;
            GpioDataRegs.GPACLEAR.bit.GPIO3=1;
//Set LED_Green Yellow RED
    GpioCtrlRegs.GPAMUX2.bit.GPIO22=0; //GPIO22->LED_RED  output
    GpioCtrlRegs.GPADIR.bit.GPIO22=1;//GPIO22->LED_RED  output
    GpioCtrlRegs.GPBMUX1.bit.GPIO32=0; //GPIO32->LED_Green  output
    GpioCtrlRegs.GPBDIR.bit.GPIO32=1;//GPIO32->LED_Green  output
    GpioCtrlRegs.GPBMUX1.bit.GPIO33=0; //GPIO33->LED_Yellow  output
    GpioCtrlRegs.GPBDIR.bit.GPIO33=1;//GPIO33->LED_Yellow  output
//Set AIO2/4/6/10/12/14  need to be configured chenmi 0908
    GpioCtrlRegs.AIOMUX1.bit.AIO2 = 2;    // AIO2 for CMP1A operation (AIO2=2 or 3 both used as ANA2 or COMP1A)
    GpioCtrlRegs.GPBMUX1.bit.GPIO42=3; //GPIO42->COMP1_out
    Comp1Regs.COMPCTL.bit.SYNCSEL = 1;
    Comp1Regs.COMPCTL.bit.QUALSEL = 0x0001;
    Comp1Regs.COMPCTL.bit.COMPSOURCE=0;//Inverting input of comparator connected to internal DAC
    Comp1Regs.COMPCTL.bit.COMPDACEN=1;
    Comp1Regs.COMPCTL.bit.CMPINV=1;//Inverted output of comparator is passed
    Comp1Regs.DACCTL.bit.DACSOURCE=0;//DAC controlled by DACVAL
    Comp1Regs.DACVAL.bit.DACVAL=620;//40A/66*1024=620  HW_OCP recoverable
    GpioCtrlRegs.GPAMUX2.bit.GPIO17 = 3;//set GPIO17 AS TZ3
    GpioCtrlRegs.GPAMUX1.bit.GPIO13 = 1;//set GPIO13 AS TZ2
    GpioCtrlRegs.GPAMUX1.bit.GPIO15 = 1;//set GPIO15 AS TZ1
    GpioCtrlRegs.GPAQSEL1.bit.GPIO13 = 3;  // Asynch input GPIO13 (TZ2)
    GpioCtrlRegs.GPAQSEL1.bit.GPIO15 = 3;  // Asynch input GPIO15 (TZ1)
    GpioCtrlRegs.GPAQSEL2.bit.GPIO17 = 3;  // Asynch input GPIO17 (TZ3)
    GpioCtrlRegs.GPAPUD.bit.GPIO15 = 0;    // Enable pull-up on GPIO15 (TZ1)
    GpioCtrlRegs.GPAPUD.bit.GPIO13 = 0;    // Enable pull-up on GPIO13 (TZ2)
    GpioCtrlRegs.GPAPUD.bit.GPIO17 = 0;    // Enable pull-up on GPIO17 (TZ3)
EDIS;
4kW 數(shù)字LLC設(shè)計(jì)資料.rar
4.86 MB, 下載次數(shù): 262, 下載積分: 黑幣 -5
LLC設(shè)計(jì)參考資料1.rar
12.78 MB, 下載次數(shù): 247, 下載積分: 黑幣 -5
LLC設(shè)計(jì)參考資料2.rar
16.5 MB, 下載次數(shù): 250, 下載積分: 黑幣 -5
收藏收藏11 分享淘帖 頂1 踩
ID:624729 發(fā)表于 2020-9-24 14:53 | 只看該作者
很好,多謝樓主。
ID:620337 發(fā)表于 2020-9-26 08:50 | 只看該作者
技術(shù)真牛啊,,,,我才剛剛開始學(xué)習(xí),舉步維艱
ID:827232 發(fā)表于 2020-10-9 14:00 | 只看該作者
是啊,太難了,向大佬學(xué)習(xí)。!
ID:137526 發(fā)表于 2021-2-15 18:11 | 只看該作者
Keil uVision5 打不開工程文件 求指教
ID:128989 發(fā)表于 2021-4-3 23:41 | 只看該作者
LLC比較難的
ID:940268 發(fā)表于 2021-6-19 09:24 | 只看該作者
謝謝樓主,感謝提供資料
ID:409179 發(fā)表于 2021-10-25 08:59 | 只看該作者
感謝提供的資料,學(xué)習(xí)學(xué)習(xí)
ID:491881 發(fā)表于 2022-5-25 09:12 | 只看該作者
好東西要一起學(xué)習(xí)。謝謝
ID:1047370 發(fā)表于 2022-10-12 09:18 來自觸屏版 | 只看該作者
有沒有半橋的設(shè)計(jì)?
