查看: 3755|回復(fù): 6
求教Keil軟件編譯 有四個(gè)語法錯(cuò)誤
ID:51357 發(fā)表于 2013-6-28 21:55 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
Keil軟件編譯 有四個(gè)語法錯(cuò)誤  剛剛進(jìn)入這個(gè)領(lǐng)域 求教“前輩”
#include "at89x52.h"
#include "stdio.h"
#include "intrins.h"
#include "ctype.h"
sbit rdy=P3^2;
sbit vpp=P3^3;
sbit p26=P3^4;
sbit p27=P3^5;
sbit p36=P3^6;
sbit p37=P3^7;
sbit prog=P2^7;
void init_serial()
SCON=0x50; /*mode 1*/
TMOD=0x20;
TH1=0xfd;
PCON=0x80;  /*38400bps*/
TR1=1;   /*load tmr1*/
TI=1;
ES=1;}
void init_pro()
p26=0;
p27=0;
p36=0;
p37=0;
vpp=1;
prog=1;
void sendbyte(unsigned char da)        /*send a byte*/
while(!TI);
TI=0;
SBUF=da;}
unsigned char IntToAscii(unsigned char a)     /*change DEC to ASCII HEX code*/
if(a<10) return a+48;
if(a>9) return a+55;}
unsigned int getadr()                        /*get 5 diti  DEC adr*/
unsigned char i,a[5];
for(i=0;i<5;i++)
  while(!RI);
  RI=0;
  a[i]=SBUF-48;
return a[0]*10000+a[1]*1000+a[2]*100+a[3]*10+a[4];}
unsigned char getdata()                     /*get 2 diti  HEX data*/
unsigned char d1,d2;
while(!RI);
RI=0;
d1=toint(SBUF);
while(!RI);
RI=0;
d2=toint(SBUF);
return d1*16+d2;}
unsigned int detchip(int adr)
P0=0xff;
P1=adr%256;P2=adr/256;
init_pro();
_nop_();_nop_();_nop_();_nop_();_nop_();  /*delay 10 us*/
return P0;}
void read()
unsigned int adr,maxadr;
unsigned char h,l;
P0=0xff;
maxadr=getadr();
for(adr=0;adr {
   p26=0;
   p27=0;
   p36=1;
   p37=1;
   vpp=1;
   prog=1;
   h=IntToAscii(P0/16);
   sendbyte(h);
   l=IntToAscii(P0%16);
   sendbyte(l);}
init_pro();}
unsigned int test(unsigned int nn)
unsigned int adr,counter=0;
P0=0xff;
for(adr=0;adr {
  p26=0;
  p27=0;
  p36=1;
  p37=1;
  vpp=1;
  prog=1;
  if(P0!=0xff) counter++;}
  init_pro();
  return counter;}
unsigned char erase(unsigned int nn,unsigned int p)
unsigned int i;
P0=0xff;
p26=1;
p27=0;
p36=0;
p37=0;
vpp=0;
prog=1;
for(i=0;i<50000;i++) _nop_();
switch(p)
  case 0 : prog=0;
           prog=1;
           break;
  case 1 : prog=0;
           _nop_();
           prog=1;
           break;
  case 2 : prog=0;
           _nop_();_nop_();
           prog=1;
           break;
  case 3 : prog=0;
           prog=1;
           break;
  case 4 : prog=0;
           prog=1;
           break;
  case 5 : prog=0;
           prog=1;
           break;
  case 6 : prog=0;
           _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
           prog=1;
           break;
  case 7 : prog=0;
           _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
           prog=1;
           break;
  case 8 : prog=0;
           _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
           prog=1;
           break;
  default: prog=0;
           for(i=0;i           prog=1;
           break;}
vpp=1;
for(i=0;i if(test(nn)==0) return 's';
else return 'f';}
unsigned char write()
unsigned int adr,d,i;
p26=0;
p27=1;
p36=1;
p37=1;
vpp=0;
prog=1;
for(i=0;i<4000;i++) _nop_();
adr=getadr();
d=getdata();
  if(adr>50000) break;
  P1=adr%256;P2=(adr/256)|0x80;
  P0=d;
  TI=0;
  SBUF='s';
  prog=0;
  prog=1;
  adr=getadr();
  d=getdata();
  while(!rdy);}
  init_pro();
  return 'f';}
unsigned char lock(unsigned char level)
unsigned int i;
vpp=0;
if(level==1) {p26=1;p27=1;p36=1;p37=1;}
if(level==2) {p26=1;p27=1;p36=0;p37=0;}
if(level==3) {p26=1;p27=0;p36=1;p37=0;}
prog=1;
prog=0;
prog=1;
while(!rdy);
init_pro();
return 'o';}
unsigned char data c;
unsigned int data adr,l,dx;
init_pro();
init_serial();
  init_pro();
  scanf("%c",&c);
  switch(c)
   case 'c' : printf("%c",'o');
              break;
   case 'd' : scanf("%x",&adr);
              printf("%x",detchip(adr));
              break;
   case 't' : scanf("%u",&dx);
              printf("%u",test(dx));
              break;
   case 'r' : read();
              break;
   case 'e' : scanf("%u,%u",&adr,&dx);
              printf("%c",erase(adr,dx));
              break;
   case 'w' : printf("%c",write());
              break;
   case 'l' : scanf("%u",&l);
              printf("%c",lock(l));
              break;
   case 'h' : printf("**********Er6y Programmer Help Window***********\n");
              break;
    default : break;}
ID:51357 發(fā)表于 2013-6-29 12:44 | 只看該作者
游客 110.205.64.x 發(fā)表于 2013-6-28 22:44
很明顯 for(adr=0;adr {  是錯(cuò)的啊 都沒有括號(hào)收
先感謝一下  請(qǐng)你幫忙改正一下
ID:51381 發(fā)表于 2013-6-29 18:19 | 只看該作者
for 循環(huán)不對(duì) 那里用括號(hào)  擴(kuò)一下!
ID:7485 發(fā)表于 2013-7-2 07:19 | 只看該作者
本帖最后由 ahshmj 于 2013-7-2 07:31 編輯
for(adr=0;adr****;adr****** )//紅字部分前面一個(gè)adr是終止循環(huán)的條件,后面一個(gè)adr是步長(zhǎng),你自己根據(jù)需要設(shè)置。這是一般形式。
  p26=0;
  p27=0;
  p36=1;
  p37=1;
  vpp=1;
  prog=1;
  init_pro();
  return counter;}
還是先從基礎(chǔ)學(xué)起吧。
幫助,是對(duì)有一定基礎(chǔ),遇到問題的情況。也是點(diǎn)到即可。像上面告訴你少了一個(gè)“括號(hào)”,你仍然不能理解,即便像我這樣給你改過來,對(duì)你有何用呢??
ID:51357 發(fā)表于 2013-7-3 18:48 | 只看該作者
ahshmj 發(fā)表于 2013-7-2 07:19
for(adr=0;adr****;adr****** )//紅字部分前面一個(gè)adr是終止循環(huán)的條件,后面一個(gè)adr是步長(zhǎng),你自己根據(jù)需 ...
十分感謝
ID:153199 發(fā)表于 2017-1-7 14:00 | 只看該作者
