查看: 2161|回復(fù): 9
求助單片機(jī)點(diǎn)陣顯示表情發(fā)暗原因
ID:405030 發(fā)表于 2020-8-10 21:08 | 只看該作者 回帖獎勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg52.h>
sbit a=P0^0;
sbit b=P0^1;
sbit c=P0^2;
sbit OE0=P0^3;
sbit OE1=P0^4;
sbit OE2=P0^5;
sbit KEY1=P3^2;
sbit KEY2=P3^3;
sbit KEY3=P3^4;
sbit KEY4=P3^5;
unsigned char code LedChar[7][8]={
{0xC3,0x81,0x00,0x00,0x00,0x81,0xFF,0xFF},
{0xFF,0x81,0x00,0x00,0x00,0x81,0xFF,0xFF},
{0xFF,0xFF,0x00,0x00,0x00,0xFF,0xFF,0xFF},
{0xFF,0xFF,0xFF,0x00,0xFF,0xFF,0xFF,0xFF},               //不按按鍵時(shí)
{0xEF,0xDF,0xBF,0x00,0xBF,0xDF,0xEF,0xFF},               //左轉(zhuǎn)
{0xF7,0xFB,0xFD,0x00,0xFD,0xFB,0xF7,0xFF},               //右轉(zhuǎn)
{0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x66,0x99},                //W
void buan();                                     //不按按鍵函數(shù)
void ting();                                         //剎車時(shí)函數(shù)
void you();                                          //左轉(zhuǎn)時(shí)函數(shù)
void zuo();                                          //右轉(zhuǎn)時(shí)函數(shù)
  if(KEY1==0)
   you();
  else if(KEY2==0)
   zuo();
  buan();
/*不按按鍵*/
void buan()
static unsigned char cnt1=0;
static unsigned char  d=0;
static unsigned int   tmr=0;
static unsigned char i=0;
P1=0xFF;
switch(i)
  case 0:a=0;b=0;c=0;OE0=0;OE1=1;OE2=1;i++;P1=LedChar[cnt1][0];break;
  case 1:a=0;b=0;c=1;OE0=0;OE1=1;OE2=1;i++;P1=LedChar[cnt1][1];break;
  case 2:a=0;b=1;c=0;OE0=0;OE1=1;OE2=1;i++;P1=LedChar[cnt1][2];break;
  case 3:a=0;b=1;c=1;OE0=0;OE1=1;OE2=1;i++;P1=LedChar[cnt1][3];break;
  case 4:a=1;b=0;c=0;OE0=0;OE1=1;OE2=1;i++;P1=LedChar[cnt1][4];break;
  case 5:a=1;b=0;c=1;OE0=0;OE1=1;OE2=1;i++;P1=LedChar[cnt1][5];break;
  case 6:a=1;b=1;c=0;OE0=0;OE1=1;OE2=1;i++;P1=LedChar[cnt1][6];break;
  case 7:a=1;b=1;c=1;OE0=0;OE1=1;OE2=1;i++;P1=LedChar[cnt1][7];break;
  case 8:a=0;b=0;c=0;OE0=1;OE1=0;OE2=1;i++;P1=LedChar[6][0];break;
  case 9:a=0;b=0;c=1;OE0=1;OE1=0;OE2=1;i++;P1=LedChar[6][1];break;
  case 10:a=0;b=1;c=0;OE0=1;OE1=0;OE2=1;i++;P1=LedChar[6][2];break;
  case 11:a=0;b=1;c=1;OE0=1;OE1=0;OE2=1;i++;P1=LedChar[6][3];break;
  case 12:a=1;b=0;c=0;OE0=1;OE1=0;OE2=1;i++;P1=LedChar[6][4];break;
  case 13:a=1;b=0;c=1;OE0=1;OE1=0;OE2=1;i++;P1=LedChar[6][5];break;
  case 14:a=1;b=1;c=0;OE0=1;OE1=0;OE2=1;i++;P1=LedChar[6][6];break;
  case 15:a=1;b=1;c=1;OE0=1;OE1=0;OE2=1;i++;P1=LedChar[6][7];break;
  case 16:a=0;b=0;c=0;OE0=1;OE1=1;OE2=1;i++;P1=LedChar[cnt1][0];break;
  case 17:a=0;b=0;c=1;OE0=1;OE1=1;OE2=0;i++;P1=LedChar[cnt1][1];break;
  case 18:a=0;b=1;c=0;OE0=1;OE1=1;OE2=0;i++;P1=LedChar[cnt1][2];break;
  case 19:a=0;b=1;c=1;OE0=1;OE1=1;OE2=0;i++;P1=LedChar[cnt1][3];break;
  case 20:a=1;b=0;c=0;OE0=1;OE1=1;OE2=0;i++;P1=LedChar[cnt1][4];break;
  case 21:a=1;b=0;c=1;OE0=1;OE1=1;OE2=0;i++;P1=LedChar[cnt1][5];break;
  case 22:a=1;b=1;c=0;OE0=1;OE1=1;OE2=0;i++;P1=LedChar[cnt1][6];break;
  case 23:a=1;b=1;c=1;OE0=1;OE1=1;OE2=0;i=0;P1=LedChar[cnt1][7];break;
  default:break;
for(d=0;d>50;d++);
tmr++;
if(tmr>=500)
  tmr=0;
  cnt1++;
  if(cnt1>=4)
   cnt1=0;
/*右轉(zhuǎn)*/
void you()
P1=0xFF;
switch(i)
  case 0:a=0;b=0;c=0;OE0=0;OE1=1;OE2=1;i++;P1=LedChar[5][0];break;
  case 1:a=0;b=0;c=1;OE0=0;OE1=1;OE2=1;i++;P1=LedChar[5][1];break;
  case 2:a=0;b=1;c=0;OE0=0;OE1=1;OE2=1;i++;P1=LedChar[5][2];break;
  case 3:a=0;b=1;c=1;OE0=0;OE1=1;OE2=1;i++;P1=LedChar[5][3];break;
  case 4:a=1;b=0;c=0;OE0=0;OE1=1;OE2=1;i++;P1=LedChar[5][4];break;
  case 5:a=1;b=0;c=1;OE0=0;OE1=1;OE2=1;i++;P1=LedChar[5][5];break;
  case 6:a=1;b=1;c=0;OE0=0;OE1=1;OE2=1;i++;P1=LedChar[5][6];break;
  case 7:a=1;b=1;c=1;OE0=0;OE1=1;OE2=1;i++;P1=LedChar[5][7];break;
  case 16:a=0;b=0;c=0;OE0=1;OE1=1;OE2=1;i++;P1=LedChar[5][0];break;
  case 17:a=0;b=0;c=1;OE0=1;OE1=1;OE2=0;i++;P1=LedChar[5][1];break;
  case 18:a=0;b=1;c=0;OE0=1;OE1=1;OE2=0;i++;P1=LedChar[5][2];break;
  case 19:a=0;b=1;c=1;OE0=1;OE1=1;OE2=0;i++;P1=LedChar[5][3];break;
  case 20:a=1;b=0;c=0;OE0=1;OE1=1;OE2=0;i++;P1=LedChar[5][4];break;
  case 21:a=1;b=0;c=1;OE0=1;OE1=1;OE2=0;i++;P1=LedChar[5][5];break;
  case 22:a=1;b=1;c=0;OE0=1;OE1=1;OE2=0;i++;P1=LedChar[5][6];break;
  case 23:a=1;b=1;c=1;OE0=1;OE1=1;OE2=0;i=0;P1=LedChar[5][7];break;
  default:break;
芯片使用的是74h138
只寫了一部分
ID:522756 發(fā)表于 2020-8-11 10:02 | 只看該作者
兩個(gè)點(diǎn)
①驅(qū)動電壓不足
②你程序里面刷新的時(shí)間太慢了,導(dǎo)致顯示的很暗
ID:701852 發(fā)表于 2020-8-11 15:41 | 只看該作者
刷新太快也有可能
ID:405030 發(fā)表于 2020-8-11 21:09 | 只看該作者
世界太小_ 發(fā)表于 2020-8-11 10:02
兩個(gè)點(diǎn)
①驅(qū)動電壓不足
謝謝了
ID:813417 發(fā)表于 2020-8-12 09:19 | 只看該作者
電阻減少一點(diǎn)
ID:235954 發(fā)表于 2020-8-12 11:15 | 只看該作者
刷新頻率過低,用51單片機(jī)的時(shí)候,刷新頻率給低也是會變暗
ID:813542 發(fā)表于 2020-8-12 14:40 | 只看該作者
頻率太慢了
ID:809311 發(fā)表于 2020-8-12 14:43 | 只看該作者
要寫調(diào)亮度的代碼進(jìn)去。
ID:74382 發(fā)表于 2020-8-14 21:19 | 只看該作者
有源碼和電路圖嗎
ID:74382 發(fā)表于 2020-8-14 21:24 | 只看該作者
源碼和電路圖呢
