查看: 2895|回復: 0
ATMEL Samc21 ADC 采集程序
ID:301613 發(fā)表于 2020-8-12 14:40 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
采用的是12位的內(nèi)部ADC采集程序經(jīng)過測試可用。
  1. /*
  2. * Systick_timer.c
  3. *
  4. * Created: 2019/4/22 17:41:05
  5. *  Author: autonav
  6. */
  7. #include "Systick_timer.h"
  8. volatile uint32_t systick_ms;
  9. volatile Flag_TypeDef systick_flag;
  10. volatile uint32_t systick_ms;
  11. volatile Flag_TypeDef systick_flag;
  12. void SysTick_Handler(void)
  13. {
  14.         systick_ms++;
  15.
  16.         systick_flag.flag_1ms++;
  17.         systick_flag.flag_2ms++;
  18.         systick_flag.flag_5ms++;
  19.
  20.         systick_flag.flag_10ms++;
  21.         systick_flag.flag_20ms++;
  22.         systick_flag.flag_50ms++;
  23.
  24.         systick_flag.flag_100ms++;
  25.         systick_flag.flag_200ms++;
  26.
  27. }
  28. void SysTick_TimerStart()
  29. {
  30.         if (SysTick_Config(SystemCoreClock / 1000))   //配置1ms SysTick中斷
  31.         {
  32.                 while (1)
  33.                 {
  34.
  35.                 }
  36.         }
  37. }
  38. float64_t SysTick_GetCurrentTime()
  39. {
  40.         volatile uint32_t load = SysTick->LOAD;
  41.         volatile uint32_t val = SysTick->VAL;
  42.         return( (systick_ms+(float64_t)(load-val)/(load+1)) / 1000);
  43. }
  44. float64_t get_dT(float64_t *last_time)
  45. {
  46.         float64_t current_time = SysTick_GetCurrentTime();
  47.         float64_t dt = current_time - *last_time;
  48.         *last_time = current_time;
  49.         return(dt);
  50. }
  51. void Delay(uint32_t x)
  52. {
  53.         while(x--);
  54. }
復制代碼
Adc.7z
1.27 MB, 下載次數(shù): 13, 下載積分: 黑幣 -5
