查看: 2349|回復(fù): 0
基于NV32F100 MCU的OLED屏RTC計(jì)時(shí)器
OLED屏是一種小巧的顯示器件,特別是I2C接口的OLED 屏更能節(jié)省I/O口資源。本次使用的是一款0.91'的單色OLED屏,它比常規(guī)的OLED屏要長且窄,故更適于顯示信息和參數(shù),也更適于用在便攜裝置上。
1. OLED屏顯示
1)OLED屏與NV32F100的連接關(guān)系如下:
SCL  --- PE1
SDA  ---  PE0
2)為進(jìn)行顯示定義引腳輸出高低電平的語句為:
#defineOLED_SCLK_Clr() GPIO_PinClear(GPIO_PTE1);
#defineOLED_SCLK_Set() GPIO_PinSet(GPIO_PTE1);
#defineOLED_SDIN_Clr() GPIO_PinClear(GPIO_PTE0);
#defineOLED_SDIN_Set() GPIO_PinSet(GPIO_PTE0);
3)OLED屏初始化函數(shù)為:
  1. void OLED_Init(void)
  2. {
  3.         Delay_1ms(800);
  4.         OLED_WR_Byte(0xAE,OLED_CMD);//--display off
  5.         OLED_WR_Byte(0x40,OLED_CMD);//--set start line address
  6.         OLED_WR_Byte(0xB0,OLED_CMD);//--set page address
  7.
  8.         OLED_WR_Byte(0xC8,OLED_CMD);//Com scan direction
  9.
  10.         OLED_WR_Byte(0x81,OLED_CMD); // contract control
  11.         OLED_WR_Byte(0xFF,OLED_CMD);//--128
  12.
  13.         OLED_WR_Byte(0xA1,OLED_CMD);//set segment remap
  14.
  15.         OLED_WR_Byte(0xA6,OLED_CMD);//--normal / reverse
  16.         OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
  17.         OLED_WR_Byte(0x1F,OLED_CMD);//--1/32 duty
  18.
  19.         OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset
  20.         OLED_WR_Byte(0x00,OLED_CMD);
  21.
  22.         OLED_WR_Byte(0xD5,OLED_CMD);//set osc division
  23.         OLED_WR_Byte(0xF0,OLED_CMD);
  24.
  25.         OLED_WR_Byte(0xD9,OLED_CMD);//Set Pre-Charge Period
  26.         OLED_WR_Byte(0x22,OLED_CMD);
  27.
  28.         OLED_WR_Byte(0xDA,OLED_CMD);//set com pin configuartion
  29.         OLED_WR_Byte(0x02,OLED_CMD);
  30.
  31.         OLED_WR_Byte(0xDB,OLED_CMD);//set Vcomh
  32.         OLED_WR_Byte(0x49,OLED_CMD);//30
  33.
  34.         OLED_WR_Byte(0x8D,OLED_CMD);//set charge pump enable
  35.         OLED_WR_Byte(0x14,OLED_CMD);
  36.
  37.         OLED_WR_Byte(0xAF,OLED_CMD);//--turn on oled panel
  38.         OLED_Clear();
  39. }
  40. 4)字符串顯示函數(shù)為:
  41. void OLED_ShowChar(unsigned char x,unsigned char y,unsigned char chr,unsigned char Char_Size)
  42. {
  43.         unsigned char c=0,i=0;
  44.         c=chr-' ';
  45.         if(x>Max_Column-1){x=0;y=y+2;}
  46.         if(Char_Size ==16)
  47.         {
  48.                  OLED_Set_Pos(x,y);
  49.                  for(i=0;i<8;i++)
  50.                  OLED_WR_Byte(F8X16[c*16+i],OLED_DATA);
  51.                  OLED_Set_Pos(x,y+1);
  52.                  for(i=0;i<8;i++)
  53.                  OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);
  54.         }
  55.         else
  56.         {
  57.                  OLED_Set_Pos(x,y);
  58.                  for(i=0;i<6;i++)
  59.                  OLED_WR_Byte(F6x8[c][i],OLED_DATA);
  60.         }
  61. }
2. RTC計(jì)時(shí)
NV32F100提供了RTC計(jì)時(shí)器,但并未提供相關(guān)的寄存器進(jìn)行計(jì)時(shí)的進(jìn)制控制。為此。我們可以RTC提供的基準(zhǔn)計(jì)時(shí)信號(hào)來自行構(gòu)建進(jìn)制處理。
1)以RTC進(jìn)行秒計(jì)時(shí),并利用變量ss來進(jìn)行計(jì)時(shí),所用的函數(shù)如下:
  1. void RTC_Task(void)
  2. {
  3.     GPIO_Toggle(GPIOB, GPIO_PTE7_MASK);
  4.     ss++;
  5. }
2)進(jìn)制處理,采用如下代碼:
  1.                      if(ss==60)
  2.                      {
  3.                             ss=0;
  4.                             mm=mm+1;
  5.                      }
  6.                      if(mm==60)
  7.                      {
  8.                             mm=0;
  9.                             hh=hh+1;
  10.                      }
  11.                      if(hh==24)
  12.                      {
  13.                           hh=0;
  14.                      }
3)RTC計(jì)時(shí)主程序,其代碼如下:
  1. int main (void)
  2. {
  3.     sysinit();
  4.     cpu_identify();
  5.     RTC_ConfigType  sRTCConfig;
  6.     RTC_ConfigType  *pRTCConfig = &sRTCConfig;
  7.     pRTCConfig->u16ModuloValue = 9;
  8.     pRTCConfig->bInterruptEn   = RTC_INTERRUPT_ENABLE;
  9.     pRTCConfig->bClockSource   = RTC_CLKSRC_1KHZ;
  10.     pRTCConfig->bClockPresaler = RTC_CLK_PRESCALER_100;
  11.
  12.     RTC_SetCallback(RTC_Task);
  13.     RTC_Init(pRTCConfig);
  14.     GPIO_Init(GPIOB, GPIO_PTE7_MASK, GPIO_PinOutput);
  15.     GPIO_Init(GPIOB, GPIO_PTE7_MASK, GPIO_PinOutput);
  16.     GPIO_Init(GPIOB, GPIO_PTE0_MASK, GPIO_PinOutput);
  17.     GPIO_Init(GPIOB, GPIO_PTE1_MASK, GPIO_PinOutput);
  18.     OLED_Init();
  19.     OLED_Clear();
  20.     cd ();
  21.     while (1)
  22.     {
  23.                      OLED_ShowNum(24,2,hh,2,16);
  24.                      OLED_ShowChar(40,2,':',16);
  25.                      OLED_ShowNum(48,2,mm,2,16);
  26.                      OLED_ShowChar(64,2,':',16);
  27.                      OLED_ShowNum(72,2,ss,2,16);
  28.                      if(ss==60)
  29.                      {
  30.                             ss=0;
  31.                             mm=mm+1;
  32.                      }
  33.                      if(mm==60)
  34.                      {
  35.                             mm=0;
  36.                             hh=hh+1;
  37.                      }
  38.                      if(hh==24)
  39.                      {
  40.                            hh=0;
  41.                      }
  42.        }
  43. }
4)運(yùn)行效果如圖所示
運(yùn)行效果圖
