近期制作了一個計數(shù)器,想增加eeprom來掉電存儲。但是發(fā)現(xiàn)數(shù)碼管數(shù)字增加一次就不再增加(從512跳到2),不知是何故,求指教
#include <reg52.h>
#include <intrins.h>
float c=2;
uchar duan[]={
0x3f, /*0*/
0x06, /*1*/
0x5b, /*2*/
0x4f, /*3*/
0x66, /*4*/
0x6d, /*5*/
0x7d, /*6*/
0x07, /*7*/
0x7f, /*8*/
0x6f, /*9*/
0x00 //ximie
sbit key=P3^2;//霍爾傳感器
sbit nnn=P1^7;//小數(shù)點dp控制位
unsigned long jishu=4294967295;
double meterd;
unsigned long meter;<font color="#ff0000">//在此以上是原來的,無誤</font>
/*eeprom<font color="#ff0000">(這些是復(fù)制的stc示例程序)</font>*/
/*Declare SFR associated with the IAP */
sfr IAP_DATA = 0xE2; //Flash data register
sfr IAP_ADDRH = 0xE3; //Flash address HIGH
sfr IAP_ADDRL = 0xE4; //Flash address LOW
sfr IAP_CMD = 0xE5; //Flash command register
sfr IAP_TRIG = 0xE6; //Flash command trigger
sfr IAP_CONTR = 0xE7; //Flash control register
/*Define ISP/IAP/EEPROM command*/
#define CMD_IDLE 0 //Stand-By
#define CMD_READ 1 //Byte-Read
#define CMD_PROGRAM 2 //Byte-Program
#define CMD_ERASE 3 //Sector-Erase
/*Define ISP/IAP/EEPROM operation const for IAP_CONTR*/
#define ENABLE_IAP 0x81 //if SYSCLK<20MHz
//Start address for STC89C58xx EEPROM
#define IAP_ADDRESS 0x2000<font color="#ff0000">//這里已經(jīng)改成89c52的eeprom地址</font>
/*MCU初始設(shè)置<font color="#ff0000">(開中斷)</font>*/
void init_MCU(void)
EX0=1;
IT0=1;
EA=1;
/*1ms delay*/
void delayms(uint xms)
uint timems;
for(;xms>0;xms--)
for(timems=115;timems>0;timems--);
/*顯示*/
void display(uint dat)
uchar ge,shi,bai,qian;
ge=dat%1000%100%10;
shi=dat%1000%100/10;
bai=dat%1000/100;
qian=dat/1000;
P2=0XF7;//個位
P1=duan[ge];
delayms(3);
P2=0XFB;//十位
P1=duan[shi];
delayms(3);
P2=0XFD;//百位
P1=duan[bai];
delayms(3);
P2=0XFE;//千位
P1=duan[qian];
delayms(3);
/*eeprom(<font color="#ff0000">也是示例程序</font>)*/
Disable ISP/IAP/EEPROM function
Make MCU in a safe state
void IapIdle()
IAP_CONTR = 0; //Close IAP function
IAP_CMD = 0; //Clear command to standby
IAP_TRIG = 0; //Clear trigger register
IAP_ADDRH = 0x80; //Data ptr point to non-EEPROM area
IAP_ADDRL = 0; //Clear IAP address to prevent misuse
Read one byte from ISP/IAP/EEPROM area
Input: addr (ISP/IAP/EEPROM address)
Output:Flash data
uchar IapReadByte(uint addr)
uchar dat; //Data buffer
IAP_CONTR = ENABLE_IAP; //Open IAP function, and set wait time
IAP_CMD = CMD_READ; //Set ISP/IAP/EEPROM READ command
IAP_ADDRL = addr; //Set ISP/IAP/EEPROM address low
IAP_ADDRH = addr >> 8; //Set ISP/IAP/EEPROM address high
IAP_TRIG = 0x46; //Send trigger command1 (0x46)
IAP_TRIG = 0xb9; //Send trigger command2 (0xb9)
_nop_(); //MCU will hold here until ISP/IAP/EEPROM operation complete
dat = IAP_DATA; //Read ISP/IAP/EEPROM data
IapIdle(); //Close ISP/IAP/EEPROM function
return dat; //Return Flash data
Program one byte to ISP/IAP/EEPROM area
dat (ISP/IAP/EEPROM data)
Output:-
void IapProgramByte(uint addr, uchar dat)
IAP_CMD = CMD_PROGRAM; //Set ISP/IAP/EEPROM PROGRAM command
IAP_DATA = dat; //Write ISP/IAP/EEPROM data
IapIdle();
Erase one sector area
Output:-
void IapEraseSector(uint addr)
IAP_CMD = CMD_ERASE; //Set ISP/IAP/EEPROM ERASE command
IapIdle();
/*主程序(和原來一樣)*/
uint i;
init_MCU();
meterd=jishu*c;
meter=meterd;
if (meter<10000)
P1=0X00;
P2=0XFE;
nnn=1;
delayms(3);
P2=0XFF;
display (meter);
P1=0X00;
P2=0XFD;
nnn=1;
delayms(3);
P2=0XFF;
display(meter/10);
void Int0() interrupt 0<font color="#ff0000">//這里面改了
delayms(50);
if(key==0)
jishu=IapReadByte(IAP_ADDRESS);
jishu++;
IapProgramByte(IAP_ADDRESS,jishu);
