基于上篇分享(STC單片機帶CRC校驗(查表法)的串口收發(fā)程序 http://www.torrancerestoration.com/bbs/dpj-191041-1.html (出處: http://www.torrancerestoration.com/bbs/))做出一定拓展。附件里包含STC89、STC12及STC15三個版本的CRC串口校驗程序,均進(jìn)行試驗驗證且通過。各實際測試單片機型號分別為STC89C52RC、STC12C5A32S2和STC15W408AS(這系列單片機沒有定時器1)。手頭暫無STC8的板子未作測試,但只需修改相應(yīng)波特率初始化函數(shù)即可使用。
單片機源程序如下:
- #include <reg52.h>
- #include<intrins.h>
- typedef unsigned char uchar8;
- typedef unsigned short uint16;
- typedef unsigned long uint32;
- bit Bee_flag = 0;
- bit Rx_start_flag;
- bit Rx_stop_flag;
- bit crc_flag = 0;
- uchar8 Rx_BUF[20];
- uchar8 Rx_count;
- uint32 crcData;
- uint32 crcData_temp;
- uchar8 Rx_data_buf[20];
- uchar8 Tx_data_buf[20];
- uchar8 Tx_crc_data_buf[20];
- /******CRC 高位字節(jié)值表******/
- uchar8 code auchCRCHi[256] =
- 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
- 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
- 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
- 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
- 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
- 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
- 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
- 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40,
- 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
- 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
- 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
- /******CRC低位字節(jié)值表******/
- uchar8 code auchCRCLo[256] =
- 0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06,
- 0x07, 0xC7, 0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD,
- 0x0F, 0xCF, 0xCE, 0x0E, 0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09,
- 0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9, 0x1B, 0xDB, 0xDA, 0x1A,
- 0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC, 0x14, 0xD4,
- 0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
- 0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3,
- 0xF2, 0x32, 0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4,
- 0x3C, 0xFC, 0xFD, 0x3D, 0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A,
- 0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38, 0x28, 0xE8, 0xE9, 0x29,
- 0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF, 0x2D, 0xED,
- 0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
- 0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60,
- 0x61, 0xA1, 0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67,
- 0xA5, 0x65, 0x64, 0xA4, 0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F,
- 0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB, 0x69, 0xA9, 0xA8, 0x68,
- 0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA, 0xBE, 0x7E,
- 0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
- 0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71,
- 0x70, 0xB0, 0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92,
- 0x96, 0x56, 0x57, 0x97, 0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C,
- 0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E, 0x5A, 0x9A, 0x9B, 0x5B,
- 0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89, 0x4B, 0x8B,
- 0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
- 0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42,
- 0x43, 0x83, 0x41, 0x81, 0x80, 0x40
- void Uart1_Init( )
- PCON &= 0x7F; //波特率不倍速
- SCON = 0x50; //8位數(shù)據(jù),可變波特率
- TMOD &= 0x0F; //清除定時器1模式位
- TMOD |= 0x20; //設(shè)定定時器1為8位自動重裝方式
- TL1 = 0xFD; //設(shè)定定時初值
- TH1 = 0xFD; //設(shè)定定時器重裝值
- ET1 = 0; //禁止定時器1中斷
- TR1 = 1; //啟動定時器1
- ES=1;
- EX0=1; //開外部中斷0
- IT0=1; //負(fù)跳變觸發(fā)
- EA=1;
- unsigned int crc16(unsigned char *puchMsg, unsigned int usDataLen)//CRC計算函數(shù)(查表法)
- unsigned char uchCRCHi = 0xFF; //高CRC字節(jié)初始化
- unsigned char uchCRCLo = 0xFF; //低CRC 字節(jié)初始化
- long uIndex; //CRC循環(huán)中的索引
- while (usDataLen--)
- uIndex = uchCRCHi ^ *puchMsg ++; //計算CRC
- uchCRCHi = uchCRCLo ^ auchCRCHi[uIndex];
- uchCRCLo = auchCRCLo[uIndex];
- return (uchCRCHi << 8 | uchCRCLo);
- /************************主函數(shù)************************/
- void main(void)
- uchar8 i, sdb_counter;
- Uart1_Init( );
- Tx_data_buf[6] = 0x00;
- P12 = 1;
- P16 = 0;
- while(1)
- if(Rx_stop_flag)
- if(Rx_BUF[0] == 0xfe)//判斷第二個包頭0xfe
- crc_flag = 1;
- for(i = 0; i < 5; i ++)//丟掉包頭包尾,只保存數(shù)據(jù)和CRC校驗和
- Rx_data_buf[i] = Rx_BUF[i + 1];
- Rx_stop_flag = 0;
- if(Rx_data_buf[2] == 0x07 && crc_flag == 1)//查詢計數(shù)
- crcData = crc16(Rx_data_buf, 3);
- crcData_temp = Rx_data_buf[3];
- crcData_temp = crcData_temp << 8;
- crcData_temp = crcData_temp + Rx_data_buf[4];
- if(crcData == crcData_temp)//驗證CRC檢驗值
- Tx_data_buf[0] = 0xef;
- Tx_data_buf[1] = 0xfe;
- Tx_data_buf[2] = 0x06;
- Tx_data_buf[3] = 0x08;
- Tx_data_buf[4] = 0x08;
- Tx_data_buf[5] = 0x00;
- Tx_data_buf[7] = 0xff;
- Tx_data_buf[8] = 0xff;
- Tx_data_buf[11] = 0xfd;
- Tx_data_buf[12] = 0xea;
- Tx_crc_data_buf[0] = Tx_data_buf[2];
- Tx_crc_data_buf[1] = Tx_data_buf[3];
- Tx_crc_data_buf[2] = Tx_data_buf[4];
- Tx_crc_data_buf[3] = Tx_data_buf[5];
- Tx_crc_data_buf[4] = Tx_data_buf[6];
- Tx_crc_data_buf[5] = Tx_data_buf[7];
- Tx_crc_data_buf[6] = Tx_data_buf[8];
- crcData = crc16(Tx_crc_data_buf, 7);
- Tx_data_buf[9] = crcData >> 8;
- Tx_data_buf[10] = crcData & 0x00ff;
- for(sdb_counter = 0; sdb_counter < 13; sdb_counter ++)
- SBUF = Tx_data_buf[sdb_counter]; //0H
- while(!TI);
- TI = 0;
- crc_flag = 0;
- void UART1_Routine(void) interrupt 4
- uchar8 i;
- if(RI)
- i = SBUF;
- RI = 0;
- if(Rx_stop_flag == 0)
- if(Rx_start_flag)
- Rx_BUF[Rx_count] = i;
- if((Rx_count > 4) && (Rx_BUF[Rx_count - 1] == 0xfd) && (Rx_BUF[Rx_count] == 0xea))//判斷包尾(0xfd, 0xea)同時判斷是否有數(shù)據(jù)(包頭包尾占4個)
- Rx_stop_flag = 1;
- Rx_start_flag = 0;
- Rx_count ++;
- if(!Rx_start_flag && (i == 0xef))//判斷第一個包頭0xef
- Rx_start_flag = 1;
- Rx_count = 0;
下載:
多版本STC單片機的CRC串口程序.zip
(1.63 MB, 下載次數(shù): 84)
2020-8-27 11:32 上傳
點擊文件名下載附件
