//紅外解碼,實(shí)驗(yàn)板測試正常,8位數(shù)碼管顯示遙控編碼(用戶碼,用戶反碼,右邊3位數(shù)碼管顯示PWM值),
//兩片74hc573驅(qū)動8位共陰數(shù)碼管
//CH-鍵短按開關(guān)燈,+鍵長按調(diào)光,數(shù)碼管顯示鍵值;長按調(diào)光的解碼程序目前網(wǎng)上很難找到,我琢磨了很久才把程序調(diào)通//壓縮包里有完整的程序代碼,有邏輯分析儀測試的連發(fā)碼的波形
- #include "INC\STC89C52RC.H"
- #include "INC\MY_SET.H"
- #include "INC\IR_NEC.H" //調(diào)用NEC解碼頭文件
- #define DIGI_PORT P0 // 宏定義數(shù)碼管端口,如果端口改變,只需修改這一句即可
- #define DIGI_NUM 8 // 宏定義數(shù)碼管個(gè)數(shù)
- unsigned char digiBuf[DIGI_NUM]; //數(shù)碼管緩沖區(qū)
- sfr SE = 0x80; //數(shù)碼管段選 P0:0x80 P1:0x90
- sbit wela = P2^7; //位選
- sbit dula = P2^6; //段選
- sbit led = P1^2;
- uint8 PWM_Val=200; //占空比 變量
- uint8 flag; //開關(guān)燈標(biāo)志
- uint8 flag1;//調(diào)光方向標(biāo)志
- uint8 count;
- uint8 flag2; //
- uint8 num,pwm;
- // 0 1 2 3 4 5 6 7 8 9 A B C D E F 不顯 -
- uint8 code d[]={ 0x3F,0x06,0x5B,0x4F,0x66, 0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71,0x00,0x40}; //數(shù)碼管段碼 共陰不帶小數(shù)點(diǎn)段碼
- void KZ0(); //短按處理
- //void KZ1(); //長按處理
- /***************** 主函數(shù) ********************/
- void main(void)
- IR_Init(); //紅外線解碼初始化
- while(1)
- //遙控檢測
- if(IR_BT==2)
- KZ0(); //短按處理
- IR_BT =0; //清有效標(biāo)志
- //更新顯示
- digiBuf[0] = NEC[0]/16; //用戶碼
- digiBuf[1] = NEC[0]%16;
- digiBuf[2] = NEC[1]/16; //用戶反碼
- digiBuf[3] = NEC[1]%16;
- // digiBuf[4] = NEC[2]/16; //數(shù)據(jù)碼
- // digiBuf[5] = NEC[2]%16;
- // digiBuf[6] = NEC[3]/16; //數(shù)據(jù)反碼
- // digiBuf[7] = NEC[3]%16;
- digiBuf[4] = 16; //不顯
- digiBuf[5] = PWM_Val/100; //顯示pwm值
- digiBuf[6] = PWM_Val%100/10;
- digiBuf[7] = PWM_Val%10;
- if(IR_BT==3 && KeyUpDownFlag==0 ) //長按調(diào)光,松手停止調(diào)光
- switch(NEC[2])
- { //長按接收的是連發(fā)碼,97.11ms高電平,10.15ms低電平
- case 0x15: if(IR==1) //if(IR==0)
- KeyUpDownFlag=1; //如果按鍵抬起,松手標(biāo)志置1
- if(flag1==1 && flag==0) // 開燈狀態(tài) +鍵 長按連加 亮度加
- if(PWM_Val<200)
- PWM_Val++; // if(IR==1)用這句
- // PWM_Val += 5; //if(IR==0)用這句 加5 燈亮度變化才明顯
- if(PWM_Val==200)
- flag1=0;
- if(flag1==0 && flag==0) //開燈狀態(tài) +鍵 長按連減 亮度 減
- if(PWM_Val>0)
- // PWM_Val -= 5;
- PWM_Val--;
- if(PWM_Val==0)
- flag1=1;
- } break;
- case 0x07:break;
- default:break;
- if(flag==0) //開燈
- for(pwm=200;pwm>0;pwm--)
- if(PWM_Val<pwm)
- led=1;
- else
- led=0;
- else
- led=1; //關(guān)燈
全部資料51hei下載地址:
紅外線NEC解碼(任意腳接收,短按開關(guān),長按調(diào)光).rar
(329.78 KB, 下載次數(shù): 191)
2020-9-2 15:32 上傳
點(diǎn)擊文件名下載附件
