查看: 3480|回復(fù): 6
51單片機控制DM542c驅(qū)動器
回帖獎勵 100 黑幣 回復(fù)本帖可獲得 10 黑幣獎勵! 每人限 1 次(中獎概率 50%)
ID:411723 發(fā)表于 2020-9-4 21:35 | 顯示全部樓層 |閱讀模式
額,不知道為啥寫的代碼沒有脈沖輸出過去,求大佬 寫一個可以輸出脈沖的   主要就是stepCW和StepCCw那塊函數(shù) 如何實現(xiàn) ,謝謝了 如果能對框架優(yōu)化就更好了
#include <reg52.h>
#include <stdio.h>
#include <math.h>
///////硬件設(shè)置////////
sbit FLASH = P3 ^ 4;
sbit kk=P1^4;
sbit PUL1 = P1 ^ 0;
sbit DIR1 = P1 ^ 1;
sbit ENA1 = P1 ^ 2;
sbit PUL2 = P1 ^ 5;
sbit DIR2 = P1 ^ 6;
sbit ENA2 = P1 ^ 7;
sbit PUL3 = P2 ^ 0;
sbit DIR3 = P2 ^ 1;
sbit ENA3 = P2 ^ 2;
sbit IN0 = P0 ^ 0;
sbit IN1 = P0 ^ 1;
sbit IN2 = P0 ^ 2;
sbit IN3 = P0 ^ 3;//輸入口 gpios
#define IN P0
sbit OUT0 = P0 ^ 4;
sbit OUT1 = P0 ^ 5;
sbit OUT2 = P0 ^ 6;
sbit OUT3 = P0 ^ 7;
////////////基本函數(shù)////////////
void Delay(unsigned int m)//延時
        unsigned int i, j;
        for (i = 0; i < m; i++)
                for (j = 0; j < 100; j++);
void Flash(unsigned int m)//閃爍測試
        FLASH = 0;
        Delay(m);
        FLASH = 1;
////軟件數(shù)據(jù)存儲/////
#define HMAX 20
code unsigned int mStep[20]= { 100,90,80,70,60,50,40,38,35,33,30,28,25,23,20,18,16,14,10,8 };
char SPM[9][1];
//////////軟件架構(gòu)函數(shù)///////
void InitTask()//電機初始化/////////////test    ok
        kk=1;
        PUL1 = 1;
  ENA1 = 1;
  PUL2 = 1;
  ENA2 = 1;
  PUL3 = 1;
  ENA3 = 1;
void StepCW(unsigned int m,char p)//正傳1.8///test  ok
        unsigned int mm = m >> 1;
        //switch (p)
                //case 0x1:
            DIR1 = 1;
                        PUL1 = 0;
                        Delay(mm);
                        PUL1 = 1;
                        Delay(mm);
                        //break;
                /*case 0x2:
                        DIR2 = 1;
                        PUL2 = 0;
                        Delay(mm);
                        PUL2 = 1;
                        Delay(mm);
                        break;
                case 0x3:
                        DIR3 = 1;
                        PUL3 = 0;
                        Delay(mm);
                        PUL3 = 1;
                        Delay(mm);
                        break;*/
void StepCCW(unsigned int m, char p)//反轉(zhuǎn)1.8//test   ok
        switch (p)
                case 0x1:
                        DIR1 = 0;
                        PUL1 = 0;
                        Delay(mm);
                        PUL1 = 1;
                        Delay(mm);
                        break;
                case 0x2:
                        DIR2 = 0;
                        PUL2 = 0;
                        Delay(mm);
                        PUL2 = 1;
                        Delay(mm);
                        break;
                case 0x3:
                        DIR3 = 0;
                        PUL3 = 0;
                        Delay(mm);
                        PUL3 = 1;
                        Delay(mm);
                        break;
void USP2P(int n, unsigned int m,char p) /////test ok
        int i;
        if (n >= 0)
                for (i = 0; i < n; i++) StepCW(m,p);
                for (i = 0; i < -n; i++) StepCCW(m,p);
/*void UDP2P1(unsigned int n,unsigned int n1,char p)//啟動減速運行函數(shù)
        int i;
        unsigned int n01,n02,n03;
        if (n < n1)for (i = 0; i < n; i++) StepCW(mStep[0],p);
        else if (n < 2 * n1)
                if (n % 2 == 0) n01 = n02 = n / 2;
                else{n01 = n / 2 + 1; n02 = n / 2;}
                for (i = 0; i < n01;i++)StepCW(mStep[i],p);
                for (i = n02 - 1; i >= 0; i--)StepCW(mStep[i],p);
                n03 = n - 2 * n1;
                for (i = 0; i < n1; i++)StepCW(mStep[i],p);
                for (i = 0; i < n03; i++)StepCW(mStep[n1-1],p);
                for (i = n1-1; i >=0; i--)StepCW(mStep[i],p);
void UDP2P2(unsigned int n, unsigned int n1, char p)//啟動減速運行函數(shù)
        int i;
        unsigned int n01, n02, n03;
        if (n < n1)
    StepCCW(mStep[0], p);
                else {n01 = n / 2 + 1; n02 = n / 2;}
                for (i = 0; i < n01;i++) StepCCW(mStep[i], p);
                for (i = n02 - 1; i >= 0; i--)StepCCW(mStep[i], p);
                n03 = n - 2 * n1;
                for (i = 0; i < n1; i++)StepCCW(mStep[i], p);
                for (i = 0; i < n03; i++)StepCCW(mStep[n1 - 1], p);
                for (i = n1 - 1; i >= 0; i--)StepCCW(mStep[i], p);
void XuanZhe(int n, unsigned int m, char p) /////////////正反判斷函數(shù)
        unsigned int nn = abs(n);
        if (n >= 0)
                UDP2P1(nn, m, p);
          UDP2P2(nn, m, p);
void SAVE2(int n,int m) /////test   ok ////////儲存坐標2函數(shù)
  int xx;
  SPM[xx][0] = n;
  SPM[xx][1] = m;
  xx++;
        if(xx>=9){xx=0;}
void Line1(int x,int y,int m)////左上運動
        int N;
        int i=0,F=0;
        N=abs(x)+abs(y);
        for(i=0;i<N;i++)
                 if(F>=0)
                 StepCW(m,0x1);
                 F=F-x;
           StepCW(m,0x2);
                 F=F+x;
void Line2(int x,int y,int m)////右上運動
        int N;
        int i=0,F=0;
        N=abs(x)+abs(y);
        for(i=0;i<N;i++)
                 if(F<0)
                 StepCCW(m,0x1);
                 F=F+y;
           StepCW(m,0x2);
                 F=F+x;
void Line3(int x,int y,int m)/////右下運動
        int N;
        int i=0,F=0;
        N=abs(x)+abs(y);
        for(i=0;i<N;i++)
                 if(F>0)
                 StepCCW(m,0x1);
                 F=F+y;
           StepCCW(m,0x2);
                 F=F-x;
void Line4(int x,int y,int m)////左下運動
        int N;
        int i=0,F=0;
        N=abs(x)+abs(y);
        for(i=0;i<N;i++)
                 if(F<0)
                 StepCW(m,0x1);
                 F=F-y;
           StepCCW(m,0x2);
                 F=F-x;
void Line(int x,int y,int m)////直線插補
        int k;
        if(x==0)
        if(y>0) for(k=0;k<y;k++)  StepCW(m,0x2);
        else  for(k=0;k<-y;k++)  StepCCW(m,0x2);
        return;
  if(y==0)
        if(x>0) for(k=0;k<x;k++)  StepCW(m,0x1);
        else  for(k=0;k<-x;k++)  StepCCW(m,0x1);
        return;
if(x>0)
        if(y>0) Line1(x,y,m);
        else Line4(x,y,m);
        if(y>0) Line2(x,y,m);
        else Line3(x,y,m);
void Resetre()/////復(fù)位函數(shù)/////
        int i;
        int res[1];
        for(i=0;i<9;i++)
        res[0]=res[0]+SPM[i][0];
        res[1]=res[1]+SPM[i][1];
        USP2P(res[0], 200,0x1);
        USP2P(res[1], 200,0x2);
/////串口構(gòu)架
sbit ENTXD = P3^6;
#define ENABLETXD  {ENTXD=0;}
#define DISABLETXD {ENTXD=1;}
void InitCom(void)/////////////////tesk     ok
        //EA=1;
         //ES=1;
         //ET1=1;
        TMOD = 0x20;//定時器1中斷允許
        PCON = 0x00;//smod=0
        SCON = 0x50;//方式1 ,定時器控制
        TH1 = 0Xfd;//波特率9600
        TL1 = 0Xfd;
        TR1 = 1;  //開定時器T1運行控制位
void comSendByte(unsigned char ch)///////tesk   ok
        TI = 0;
        SBUF = ch;
        while (!TI);
void comSendCMD(unsigned char node, unsigned char cmd, unsigned char low, unsigned char hi)
        ENABLETXD
        comSendByte(0xff);
        comSendByte(0xff);
        comSendByte(node);
        comSendByte(cmd);
        comSendByte(02);
        comSendByte(low);
        comSendByte(hi);
        DISABLETXD
unsigned char cmdBuFF[10];
unsigned char iCmdByte = 0;
        unsigned char ch;
        unsigned char nodeID, cmdID, nParaBytes, ParaLow, ParaHi;
        unsigned int para;
        unsigned int ii;
        InitCom();
        InitTask();
        while (1)
                if (RI)
                        ch = SBUF;
                        RI = 0;
                comSendByte(ch);
                cmdBuFF[iCmdByte] = ch;
                iCmdByte++;
                 if (iCmdByte >= 7)
                        iCmdByte = 0;
                        if (cmdBuFF[0] != 0xff || cmdBuFF[1] != 0xff)
                                        continue;
                                        // byte0     1      2       3      4         5         6
                                        // 0xFF  0xFF   NODE#  CMDID          PARALEN   PARALOW   PARAHI
                                        nodeID = cmdBuFF[2];
                                        cmdID = cmdBuFF[3];
                                        nParaBytes = cmdBuFF[4];
                                        ParaLow = cmdBuFF[5];
                                        ParaHi = cmdBuFF[6];
                                        para = ParaHi;
                                        para <<= 8;
                                        para |= ParaLow;
                                        switch (cmdID)
                                        case 0x0:
                                                Flash(200);
                                    ENABLETXD
                                                break;
                                        case 0x2:
                                          StepCW((char)ParaLow,nodeID);
                                                break;
                                        case 0x3:
                                          USP2P(500, 100, 0x1);
                                                break;
                                        case 0x4:
                                                SAVE2((int)ParaLow, (int)ParaHi);
                                                break;
                                        case 0x5:
                                                for(ii=0;ii<9;ii++)
                                           Line(SPM[ii][0],SPM[ii][1],(int)ParaHi);
                                                break;
                                        case 0x6:
                                                break;
                                        case 0x80:
                                                break;
                                        case 0x82:
                                                break;
                                        case 0x84:
                                                break;
ID:235954 發(fā)表于 2020-9-5 09:17 | 顯示全部樓層
需要什么,PWM程序,還是串口通信程序
ID:411723 發(fā)表于 2020-9-5 09:39 | 顯示全部樓層
梁廷明 發(fā)表于 2020-9-5 09:17
需要什么,PWM程序,還是串口通信程序
好了 不是程序的問題 ,是步進電機電源問題, 控制信號電平太低了 ,換成5v的就可以控制了,謝謝
ID:832425 發(fā)表于 2020-11-24 14:42 | 顯示全部樓層
看上去不錯,沒有共享出來大家學(xué)習(xí)一下嗎
ID:475858 發(fā)表于 2020-11-27 15:46 | 顯示全部樓層
控制信號和步進電機之間應(yīng)該有驅(qū)動芯片
ID:899124 發(fā)表于 2021-4-1 14:52 | 顯示全部樓層
你好,我想請教一下,這個程序,我需要怎樣接電路啊?
ID:899124 發(fā)表于 2021-4-2 16:01 | 顯示全部樓層
你好,我想請教一下單片機與DM542之間怎么接線呢?是共用5V接正極還是怎么接線?
