查看: 4184|回復(fù): 3
單片機(jī)+MCP3201顯示 測(cè)量電壓表源程序,仿真
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #include <oled.h>
  4. #define uint unsigned int
  5. #define uchar unsigned char
  6. #define delay4us() {_nop_();_nop_();_nop_();_nop_();}
  7. //mep3201的引腳
  8. sbit CS_MCP3201  =P3^2;
  9. sbit DO_MCP3201  =P3^3;
  10. sbit CLK_MCP3201 =P3^4;
  11. //輸入選擇的引腳
  12. sbit SR1  =P0^5;
  13. sbit SR2  =P0^4;
  14. sbit SR3  =P0^3;
  15. sbit SR4  =P0^2;
  16. sbit SR5  =P0^1;
  17. sbit SR6  =P0^0;
  18. //LED選擇的引腳
  19. sbit LED1 =P2^0;
  20. sbit LED2 =P2^1;
  21. sbit LED3 =P2^2;
  22. sbit LED4 =P2^3;
  23. sbit LED5 =P2^4;
  24. sbit LED6 =P2^5;
  25. sbit LED7 =P2^6;
  26. sbit LED8 =P2^7;
  27. //報(bào)警選擇的引腳
  28. sbit BEEP =P1^7;
  29. uchar Display_Buffek[] = "STC89C52 MEP3201";
  30. uchar Display_Buffer[] = "Flow      00.00V\r\n";
  31. void DelayMS(uint ms)
  32. {
  33.          uchar i;
  34.         while(ms--)
  35.         {
  36.                  for(i=0;i<120;i++);
  37.         }
  38. }
  39. void putc_to_SerialPort(uchar c)
  40. {
  41.          SBUF = c;
  42.         while(TI == 0);
  43.         TI = 0;
  44. }
  45. void puts_to_SerialPort(uchar *s)
  46. {
  47.          while(*s != '\0')
  48.         {
  49.                  putc_to_SerialPort(*s);
  50.                 s++;
  51.                 DelayMS(5);
  52.         }
  53. }
  54. uint  AD3201()
  55. {
  56.         uint temp;
  57.         uchar k;
  58. //        TRISC=OB000100;
  59.         CLK_MCP3201=0;
  60.         CS_MCP3201=0;
  61.         CLK_MCP3201=1;
  62.         delay4us();
  63.         CLK_MCP3201=0;
  64.         delay4us();
  65.         CLK_MCP3201=1;
  66.         delay4us();
  67.         CLK_MCP3201=0;
  68.         delay4us();
  69.         for(k=0;k<12;k++)
  70.         {
  71.         CLK_MCP3201=1;
  72.         delay4us();
  73.         CLK_MCP3201=0;
  74.         if(DO_MCP3201==0)temp=temp*2;
  75.         else temp=temp*2+1;
  76.         }
  77.         CS_MCP3201=1;
  78.         return temp;
  79. }
  80. void main()
  81. {
  82.         int dw;
  83.         uint d;
  84.         uint d2,l=0;
  85.         SCON = 0x40;  //設(shè)置波特率
  86.         TMOD = 0x20;
  87.         PCON = 0x00;
  88.         TH1  = 0xfd;
  89.         TL1  = 0xfd;
  90.         TI   = 0;
  91.         TR1  = 1;          //ok
  92.         DelayMS(10);
  93.         Initial_LY096BG30();
  94.         fill_picture(0x00);
  95.         Picture_1();
  96.
  97.         while(1)
  98.         {
  99.                 l++;
  100.                 if(l%50==0)
  101.                 {
  102.                         d=AD3201();//
  103.                          if(SR1==0)d2 =d/6,dw=1;
  104.                          if(SR2==0)d2 =d/3,dw=2;
  105.                          if(SR3==0)d2 =d/2,dw=3;
  106.                          if(SR4==0)d2 =d/1.5,dw=4;
  107.                          if(SR5==0)d2 =d/1.2,dw=5;
  108.                          if(SR6==0)d2 =d,dw=6;
  109.                         Display_Buffer[10]=d2/1000+'0';
  110.                         Display_Buffer[11]=d2/100%10+'0';
  111.                         Display_Buffer[12]='.';
  112.                         Display_Buffer[13]=d2/10%10+'0';
  113.                         Display_Buffer[14]=d2%10+'0';
  114.                         Display_Buffer[15]='V';
  115.                         Display_Buffer[5]=d/1000+'0';
  116.                         Display_Buffer[6]=d/100%10+'0';
  117.                         Display_Buffer[7]=d/10%10+'0';
  118.                         Display_Buffer[8]=d%10+'0';
  119.                 }
  120.                 P2=P0;
  121.                 if(SR6==0&&d2>3000)        BEEP=1;
  122.                 else  BEEP=0;
  123.                 xssz(2,3,Display_Buffer[10]-'0');
  124.                 xssz(2,4,Display_Buffer[11]-'0');
  125.                 xssz(2,5,10);
  126.                 xssz(2,6,Display_Buffer[13]-'0');
  127.                 xssz(3,6,dw);
  128.                 if(l==100)
  129.                 {
  130.                         l=0;
  131.                         puts_to_SerialPort("STC89C52 MEP3201\r\n");
  132.                         DelayMS(50);
  133.                         puts_to_SerialPort(Display_Buffer);
  134.                 }
  135.         }
  136. }
#include <reg52.h>
#define high 1
#define low 0
//oled引腳定義
sbit SCL = P3^5;
sbit SDA = P3^6;
void Initial_LY096BG30();
void fill_picture(unsigned char fill_Data);
void Picture_1();
void IIC_Start();
void IIC_Stop();
void Write_IIC_Command(unsigned char IIC_Command);
void Write_IIC_Data(unsigned char IIC_Data);
void Write_IIC_Byte(unsigned char IIC_Byte);
/***********************Initial code*********************/
        Write_IIC_Command(0xAE);   //display off
        Write_IIC_Command(0x20);        //Set Memory Addressing Mode
        Write_IIC_Command(0x10);        //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
        Write_IIC_Command(0xb0);        //Set Page Start Address for Page Addressing Mode,0-7
        Write_IIC_Command(0xc8);        //Set COM Output Scan Direction
        Write_IIC_Command(0x02);//---set low column address
        Write_IIC_Command(0x10);//---set high column address
        Write_IIC_Command(0x40);//--set start line address
        Write_IIC_Command(0x81);//--set contrast control register
        Write_IIC_Command(0x7f);
        Write_IIC_Command(0xa1);//--set segment re-map 0 to 127
        Write_IIC_Command(0xa6);//--set normal display
        Write_IIC_Command(0xa8);//--set multiplex ratio(1 to 64)
        Write_IIC_Command(0x3F);//
        Write_IIC_Command(0xa4);//0xa4,Output follows RAM content;0xa5,Output ignores RAM content
        Write_IIC_Command(0xd3);//-set display offset
        Write_IIC_Command(0x00);//-not offset
        Write_IIC_Command(0xd5);//--set display clock divide ratio/oscillator frequency
        Write_IIC_Command(0xf0);//--set divide ratio
        Write_IIC_Command(0xd9);//--set pre-charge period
        Write_IIC_Command(0x22); //
        Write_IIC_Command(0xda);//--set com pins hardware configuration
        Write_IIC_Command(0x12);
        Write_IIC_Command(0xdb);//--set vcomh
        Write_IIC_Command(0x20);//0x20,0.77xVcc
        Write_IIC_Command(0x8d);//--set DC-DC enable
        Write_IIC_Command(0x14);//
        Write_IIC_Command(0xaf);//--turn on oled panel
/***********************Picture Code**************************/
unsigned char code show1[]=
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x90,0x52,0x34,0x10,0xFF,0x10,0x34,0x52,0x80,0x70,0x8F,0x08,0x08,0xF8,0x08,0x00,
0x82,0x9A,0x56,0x63,0x22,0x52,0x8E,0x00,0x80,0x40,0x33,0x0C,0x33,0x40,0x80,0x00,/*"數(shù)",0*/
0x10,0x0C,0x04,0x24,0x24,0x24,0x25,0x26,0xA4,0x64,0x24,0x04,0x04,0x14,0x0C,0x00,
0x02,0x02,0x02,0x02,0x02,0x42,0x82,0x7F,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x00,/*"字",1*/
0x00,0x00,0xF8,0x88,0x88,0x88,0x88,0xFF,0x88,0x88,0x88,0x88,0xF8,0x00,0x00,0x00,
0x00,0x00,0x1F,0x08,0x08,0x08,0x08,0x7F,0x88,0x88,0x88,0x88,0x9F,0x80,0xF0,0x00,/*"電",2*/
0x00,0x00,0xFE,0x02,0x82,0x82,0x82,0x82,0xFA,0x82,0x82,0x82,0x82,0x82,0x02,0x00,
0x80,0x60,0x1F,0x40,0x40,0x40,0x40,0x40,0x7F,0x40,0x40,0x44,0x58,0x40,0x40,0x00,/*"壓",3*/
0x00,0x04,0x24,0x24,0x24,0x24,0x24,0xFF,0x24,0x24,0x24,0x24,0x24,0x04,0x00,0x00,
0x21,0x21,0x11,0x09,0xFD,0x83,0x41,0x23,0x05,0x09,0x11,0x29,0x25,0x41,0x41,0x00,/*"表",4*/
0x08,0x38,0xC8,0x00,0xC8,0x38,0x08,0x00,0x00,0x70,0x88,0x08,0x08,0x08,0x38,0x00,/*"Y",0*/
0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,0x00,0x38,0x20,0x21,0x21,0x22,0x1C,0x00,/*"S",1*/
0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"5",0*/
0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",1*/
0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,/*"1",2*/
0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,/*"0",3*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,/*" ",4*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,/*"1",5*/
0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"5",6*/
0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",7*/
0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,/*"2",8*/
0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,/*"0",9*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,/*" ",10*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,/*"2",11*/
0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"5",12*/
0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",13*/
0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,/*"3",14*/
0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,/*"0",15*/
0x00,0x00,0x00,0xF8,0x88,0x88,0x88,0x88,0xFF,0x88,0x88,0x88,0x88,0xF8,0x00,0x00,
0x00,0x00,0x00,0x1F,0x08,0x08,0x08,0x08,0x7F,0x88,0x88,0x88,0x88,0x9F,0x80,0xF0,/*"電"*/
0x00,0x00,0x00,0xFE,0x02,0x82,0x82,0x82,0x82,0xFA,0x82,0x82,0x82,0x82,0x82,0x02,
0x00,0x80,0x60,0x1F,0x40,0x40,0x40,0x40,0x40,0x7F,0x40,0x40,0x44,0x58,0x40,0x40,/*"壓"*/
0x00,0x00,0x00,0x36,0x36,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*":"*/
0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"V"*/
0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x40,0x42,0x44,0x58,0x40,0x40,0x7F,0x40,0x40,0x50,0x48,0xC6,0x00,0x00,0x00,
0x00,0x40,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0xFF,0x00,0x00,0x00,/*"當(dāng)",0*/
0x08,0x08,0xE8,0x29,0x2E,0x28,0xE8,0x08,0x08,0xC8,0x0C,0x0B,0xE8,0x08,0x08,0x00,
0x00,0x00,0xFF,0x09,0x49,0x89,0x7F,0x00,0x00,0x0F,0x40,0x80,0x7F,0x00,0x00,0x00,/*"前",1*/
0x10,0x10,0xD0,0xFF,0x90,0x10,0x40,0x42,0x5C,0x40,0x7F,0x40,0x50,0xCE,0x00,0x00,
0x04,0x03,0x00,0xFF,0x00,0x01,0x40,0x44,0x44,0x44,0x44,0x44,0x44,0xFF,0x00,0x00,/*"檔",2*/
0x00,0x80,0x60,0xF8,0x07,0x10,0x90,0x10,0x11,0x16,0x10,0x10,0xD0,0x10,0x00,0x00,
0x01,0x00,0x00,0xFF,0x40,0x40,0x41,0x5E,0x40,0x40,0x70,0x4E,0x41,0x40,0x40,0x00,/*"位",3*/
0x00,0x00,0x36,0x36,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*":",4*/
0x04,0x03,0x00,0xFF,0x00,0x01,0x40,0x44,0x44,0x44,0x44,0x44,0x44,0xFF,0x00,0x00,/*"檔",7*/
unsigned char code show2[]=
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,/*"0"*/
0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,/*"1"*/
0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,/*"2"*/
0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,/*"3"*/
0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,/*"4"*/
0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,/*"5"*/
0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,/*"6"*/
0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,/*"7"*/
0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,/*"8"*/
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,/*"9"*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,/*"."*/
//IIC Start
void IIC_Start()
   SCL = high;
   SDA = high;
   SDA = low;
   SCL = low;
//IIC Stop
void IIC_Stop()
   SCL = low;
   SDA = low;
   SCL = high;
   SDA = high;
// IIC Write byte
        unsigned char i;
        for(i=0;i<8;i++)
                if(IIC_Byte & 0x80)                //1?0?
                SDA=high;
                SDA=low;
                SCL=high;
                SCL=low;
                IIC_Byte<<=1;                        //loop
        SDA=1;
        SCL=1;
        SCL=0;
// IIC Write Command
   IIC_Start();
   Write_IIC_Byte(0x78);            //Slave address,SA0=0
   Write_IIC_Byte(0x00);                        //write command
   Write_IIC_Byte(IIC_Command);
   IIC_Stop();
// IIC Write Data
   IIC_Start();
   Write_IIC_Byte(0x40);                        //write data
   Write_IIC_Byte(IIC_Data);
   IIC_Stop();
// fill_Picture
        unsigned char m,n;
        for(m=0;m<8;m++)
                Write_IIC_Command(0xb0+m);                //page0-page1
                Write_IIC_Command(0x00);                //low column start address
                Write_IIC_Command(0x10);                //high column start address
                for(n=0;n<130;n++)
                                Write_IIC_Data(fill_Data);
// picture
void picture_1()
        unsigned char x,y,z,k;
        unsigned int i=0;
        for(k=0;k<4;k++)
                for(z=0;z<8;z++)
                        for(y=2*k;y<2*(k+1);y++)
                                Write_IIC_Command(0xb0+y);
                                Write_IIC_Command(0x10+z);
                                for(x=0;x<16;x++)
                                        Write_IIC_Data(show1[i++]);
void xssz(int k,int z,int sz)          //k=行; z=個(gè);
  unsigned char x,y;
  unsigned int i=sz*16;
      for(x=0;x<8;x++)
          Write_IIC_Data(show2[i++]);
全部資料51hei下載地址(帶液晶屏的仿真目前 暫不分享):
MCP3201 oled ly.rar (100.23 KB, 下載次數(shù): 48)
ID:149799 發(fā)表于 2020-9-10 21:48 | 只看該作者
謝謝分享,先收藏。
ID:102963 發(fā)表于 2020-9-13 17:54 | 只看該作者
發(fā)的資料,跟描述對(duì)應(yīng)不起來。樓主是來騙分的嗎
ID:337109 發(fā)表于 2020-10-6 18:23 | 只看該作者
songxia8013 發(fā)表于 2020-9-13 17:54
一模一樣
