查看: 950|回復(fù): 0
關(guān)于數(shù)碼管的程序 適合天翔匯凈的板子
ID:812531 發(fā)表于 2020-9-21 20:25 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#define DataPort P0
sbit LATCH1=P2^6;
sbit LATCH2=P2^7;
unsigned char code dofly_DuanMa[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,
                                                   0x77,0x7c,0x39,0x5e,0x79,0x71};// ?????0~F
unsigned char code dofly_WeiMa[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//????????????,???
unsigned char TempData[10]; //??????????
void Display(unsigned char FirstBit,unsigned char Num);//???????
void Init_Timer0(void);//??????
void main (void)
Init_Timer0();
while (1)         //???
             TempData[0]=0x3f; // "o"
         TempData[1]=0x73; // "p"
                 //TempData[2]=0x79; // "E"
                // TempData[3]=0x54; // "n"
      static unsigned char i=0;
       LATCH1=1;     //???
       LATCH1=0;
       DataPort=dofly_WeiMa[i+FirstBit]; //???
       LATCH2=1;     //???
       LATCH2=0;
       DataPort=TempData[i]; //?????,??
       LATCH1=1;     //???
       LATCH1=0;
           i++;
      if(i==Num)
              i=0;
TMOD |= 0x01;          //????1,16????,??"|"?????????????????
//TH0=0x00;              //????
//TL0=0x00;
EA=1;            //?????
ET0=1;           //???????
TR0=1;           //???????
void Timer0_isr(void) interrupt 1
TH0=(65536-2000)/256;                  //???? 2ms
TL0=(65536-2000)%256;
Display(0,8);       // ???????
