TIME4控制4路PWM C程序
#include "pwm1.h"
#include "led.h"
//TIM4 PWM部分初始化
//PWM輸出初始化
//arr:自動(dòng)重裝值
//psc:時(shí)鐘預(yù)分頻數(shù)
//定時(shí)器3中斷服務(wù)程序
void TIM4_IRQHandler(void) //TIM4中斷
if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET) //檢查TIM4更新中斷發(fā)生與否
TIM_ClearITPendingBit(TIM4, TIM_IT_Update ); //清除TIMx更新中斷標(biāo)志
LED1=!LED1;
void TIM4_PWM_Init(u32 arr,u32 psc)
//此部分需手動(dòng)修改IO口設(shè)置
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
// NVIC_InitTypeDef NVIC_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4,ENABLE); //TIM4時(shí)鐘使能
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE); //使能PORTC時(shí)鐘
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9; //GPIOB6
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; //復(fù)用功能
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; //速度100MHz
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽復(fù)用輸出
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; //上拉
GPIO_Init(GPIOB,&GPIO_InitStructure); //初始化PC6
//設(shè)置該引腳為復(fù)用輸出功能,輸出TIM4 CH1的PWM脈沖波形GPIOB.6
GPIO_PinAFConfig(GPIOB,GPIO_PinSource6,GPIO_AF_TIM4); //GPIOB6復(fù)用為定時(shí)器3
GPIO_PinAFConfig(GPIOB,GPIO_PinSource7,GPIO_AF_TIM4);
GPIO_PinAFConfig(GPIOB,GPIO_PinSource8,GPIO_AF_TIM4);
GPIO_PinAFConfig(GPIOB,GPIO_PinSource9,GPIO_AF_TIM4);
TIM_TimeBaseStructure.TIM_Prescaler=psc; //定時(shí)器分頻
TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up; //向上計(jì)數(shù)模式
TIM_TimeBaseStructure.TIM_Period=arr; //自動(dòng)重裝載值
TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
TIM_TimeBaseInit(TIM4,&TIM_TimeBaseStructure);//初始化定時(shí)器3
//初始化TIM4 Channel PWM模式
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //選擇定時(shí)器模式:TIM脈沖寬度調(diào)制模式2
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比較輸出使能
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; //輸出極性:TIM輸出比較極性低
TIM_OC1Init(TIM4, &TIM_OCInitStructure); //根據(jù)T指定的參數(shù)初始化外設(shè)TIM4OC1
TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable); //使能TIM4在CCR1上的預(yù)裝載寄存器
TIM_OC2Init(TIM4, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM4, TIM_OCPreload_Enable);
TIM_OC3Init(TIM4, &TIM_OCInitStructure);
TIM_OC3PreloadConfig(TIM4, TIM_OCPreload_Enable);
TIM_OC4Init(TIM4, &TIM_OCInitStructure);
TIM_OC4PreloadConfig(TIM4, TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM4,ENABLE);//ARPE使能
TIM_Cmd(TIM4, ENABLE); //使能TIM4
全部程序51hei下載地址:
PWM -20200919.7z
(345.67 KB, 下載次數(shù): 105)
2020-9-22 14:51 上傳
點(diǎn)擊文件名下載附件
PWM 下載積分: 黑幣 -5
