#include "REG51.h"
#ifndef __OLED_H
#define __OLED_H
//#include "sys.h"
//#include "stdlib.h"
#define u8 unsigned char
#define u32 unsigned int
#define OLED_CMD 0 //寫(xiě)命令
#define OLED_DATA 1 //寫(xiě)數(shù)據(jù)
#define OLED_MODE 0
sbit OLED_SCL=P1^0;//時(shí)鐘 D0(SCLK?
sbit OLED_SDIN=P1^1;//D1(MOSI) 數(shù)據(jù)
#define OLED_CS_Clr() OLED_CS=0
#define OLED_CS_Set() OLED_CS=1
#define OLED_RST_Clr() OLED_RST=0
#define OLED_RST_Set() OLED_RST=1
#define OLED_DC_Clr() OLED_DC=0
#define OLED_DC_Set() OLED_DC=1
#define OLED_SCLK_Clr() OLED_SCL=0
#define OLED_SCLK_Set() OLED_SCL=1
#define OLED_SDIN_Clr() OLED_SDIN=0
#define OLED_SDIN_Set() OLED_SDIN=1
//OLED模式設(shè)置
//0:4線串行模式
//1:并行8080模式
#define SIZE 16
#define XLevelL 0x02
#define XLevelH 0x10
#define Max_Column 128
#define Max_Row 64
#define Brightness 0xFF
#define X_WIDTH 128
#define Y_WIDTH 64
//-----------------OLED端口定義----------------
void delay_ms(unsigned int ms);
//OLED控制用函數(shù)
void OLED_WR_Byte(unsigned dat,unsigned cmd); //
void OLED_Display_On(void);
void OLED_Display_Off(void);
void OLED_Init(void); //OLED初始化
void OLED_Clear(void); //OLED清屏
void OLED_DrawPoint(u8 x,u8 y,u8 t);
void OLED_Fill(u8 x1,u8 y1,u8 x2,u8 y2,u8 dot);
void OLED_ShowChar(u8 x,u8 y,u8 chr,u8 Char_Size); //顯示ASCII字符`
void OLED_ShowNum(u8 x,u8 y,u32 num,u8 len,u8 size); //顯示數(shù)字
void OLED_ShowString(u8 x,u8 y, u8 *p,u8 Char_Size); ////第一個(gè)是開(kāi)始的列,第二個(gè)是開(kāi)始的行,第三個(gè)是字符,第四個(gè)是字符的大小,注意字符是需要用引號(hào)表示為字符串的。
void OLED_Set_Pos(unsigned char x, unsigned char y);
void OLED_ShowCHinese(u8 x,u8 y,u8 no); //第一個(gè)是列的起始點(diǎn)(每次增加18),第二個(gè)是page的選取,第三個(gè)是數(shù)組后面漢字標(biāo)注的數(shù)
void OLED_DrawBMP(unsigned char x0, unsigned char y0,unsigned char x1, unsigned char y1,unsigned char BMP[]);
void Delay_50ms(unsigned int Del_50ms); //延時(shí)
void Delay_1ms(unsigned int Del_1ms); //延時(shí)
void fill_picture(unsigned char fill_Data);
void Picture();
void IIC_Start(); //iic開(kāi)始信號(hào)
void IIC_Stop(); //iic停止信號(hào)
void Write_IIC_Command(unsigned char IIC_Command); //iic寫(xiě)命令
void Write_IIC_Data(unsigned char IIC_Data); //iic寫(xiě)數(shù)據(jù)
void Write_IIC_Byte(unsigned char IIC_Byte); //主機(jī)發(fā)送一個(gè)字節(jié)的數(shù)據(jù),從高位開(kāi)始發(fā)送 SCL高電平的時(shí)候數(shù)據(jù)保持穩(wěn)定,SCL組織數(shù)據(jù),SCL高電平發(fā)送數(shù)據(jù)或者接受數(shù)據(jù)
void IIC_Wait_Ack(); //應(yīng)答信號(hào)
#endif
OLED終結(jié)者.7z
2020-10-4 04:22 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
4.12 MB, 下載次數(shù): 15, 下載積分: 黑幣 -5
