#include<intrins.h>
#include<string.h>
#include<stdio.h>
#define _Nop() _nop_()
typedef unsigned char unint8;
typedef unsigned char unint16;
sbit TRH=P3^7;
unsigned char str1[]={" /RH"};
unsigned char str2[]={" 'C"};
extern unsigned char wddata,sddata;
unint8 TH_data,TL_data,RH_data,RL_data,CK_data;
unint8 TH_temp,TL_temp,RH_temp,RL_temp,CK_temp;
unint8 com_data,untemp,temp;
unint8 respond;
// 毫秒級延時子程序
void delay_ms1(unsigned char ms)
unsigned char i;
while(ms--)
for(i = 0; i< 150; i++)
_nop_();
_nop_();
_nop_();
_nop_();
//5us級延時程序
void delay_us_dht11()
unint8 i;
i--;
i--;
i--;
i--;
i--;
i--;
//收發(fā)信號檢測,數(shù)據(jù)讀取
char receive()
unint8 i;
com_data=0;
for(i=0;i<=7;i++)
respond=2;
while((!TRH)&&respond++);
delay_us_dht11();
delay_us_dht11();
delay_us_dht11();
if(TRH)
temp=1;
respond=2;
while((TRH)&&respond++);
temp=0;
com_data<<=1;
com_data|=temp;
return(com_data);
//濕度讀取子程序
//溫度高8位== TL_data
//溫度低8位== TH_data
//濕度高8位== RH_data
//濕度低8位== RH_data
//校驗 8位 == CK_data
//調(diào)用的程序有 delay();, Delay_5us();,RECEIVE();
void read_TRH()
//主機拉低18ms
TRH=0;
delay_ms1(18);
TRH=1;
//DATA總線由上拉電阻拉高 主機延時20us
delay_us_dht11();
delay_us_dht11();
delay_us_dht11();
delay_us_dht11();
//delay_us_dht11();
//delay_us_dht11();delay_us_dht11();delay_us_dht11();delay_us();
//主機設(shè)為輸入 判斷從機響應(yīng)信號
TRH=1;
//判斷DHT11是否有低電平響應(yīng)信號 如不響應(yīng)則跳出,響應(yīng)則向下運行
if(!TRH)
respond=2;
//判斷DHT11發(fā)出 80us 的低電平響應(yīng)信號是否結(jié)束
while((!TRH)&& respond++);
respond=2;
//判斷從機是否發(fā)出 80us 的高電平,如發(fā)出則進入數(shù)據(jù)接收狀態(tài)
while(TRH && respond++);
//數(shù)據(jù)接收狀態(tài)
RH_temp = receive();
RL_temp = receive();
TH_temp = receive();
TL_temp = receive();
CK_temp = receive();
TRH=1;
//數(shù)據(jù)校驗
untemp=(RH_temp+RL_temp+TH_temp+TL_temp);
if(untemp==CK_temp)
RH_data = RH_temp;
RL_data = RL_temp;
TH_data = TH_temp;
TL_data = TL_temp;
CK_data = CK_temp;
//濕度整數(shù)部分
str1[0] = (char)(0X30+RH_data/10);
str1[1] = (char)(0X30+RH_data%10);
//溫度整數(shù)部分
str2[0] = (char)(0X30+TH_data/10);
str2[1] = (char)(0X30+TH_data%10);
sddata=RH_data;
wddata=TH_data;
