查看: 2644|回復(fù): 0
單片機(jī)數(shù)碼管顯示閃爍程序
ID:741025 發(fā)表于 2020-10-9 22:35 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
include<reg51.h>
#include<stdio.h>
#include<string.h>
uchar code led_m[]={0x3F,0x6,0x5B,0x4F,0x66,0x6D,0x7D,0x7,0x7F,0x6F,} ;
sbit duanxuan =P2^5;
sbit weixuan =P2^6;
uchar num,num1=60,num2,shi,ge;
void Init()
        TMOD=0X01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
void delay_ms(uint xms)
        uint i,j;
        for(i=xms;i>0;i--)
        for(j=110;j>0;j--);
void shumaguan()           //?????1???
                duanxuan=0;
    weixuan=0;
                P0=led_m[shi];//?????
    duanxuan=1;
    duanxuan=0;
    P0=0x00;
    P0=0x02;
    weixuan=1;
    weixuan=0;
               delay_ms(60);
       P0=0x00;
       P0=led_m[ge];//?????
    duanxuan=1;
    duanxuan=0;
    P0=0x00;
    P0=0x01;
    weixuan=1;
    weixuan=0;
    P0=0x00;
               delay_ms(60);
{ Init();
    shumaguan();
void Timer0()interrupt 1
        num++;
        if(num==20)
                num=0;
                num1--;
                if(num1==0)
                num1=60;
                shi=num1/10;
                ge=num1%10;
