查看: 1863|回復(fù): 1
LCD1602A電子時(shí)鐘 分秒可調(diào)
ID:593787 發(fā)表于 2020-10-11 01:04 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <reg51.h>
uchar num=0,AN=0,e;
char fen=0,miao=0;
sbit rs=P2^0;
sbit rw=P2^1;
sbit E=P2^2;
sbit beef=P1^5;
sbit key1=P3^2;         //選擇時(shí)間
sbit key2=P3^3;         //增加時(shí)間
sbit key3=P3^4;         //減少時(shí)間
void delay_50us(uchar i)
        uchar j;
        for( ;i>0;i--)
        for(j=100;j>0;j--);
void write_com(uchar com)
        rs=0;
        rw=0;
        E=0;
        P0=com;
        delay_50us(10);
        E=1;
        delay_50us(20);
        E=0;
void write_data(uchar dat)
        rs=1;
        rw=0;
        E=0;
        P0=dat;
        delay_50us(10);
        E=1;
        delay_50us(20);
        E=0;
void write_shu(uchar add,uchar date)
        uchar ge,shi;
        shi=date/10;
        ge=date%10;
        write_com(0x80+0x40+add);
        write_data(0x30+shi);
        write_data(0x30+ge);
void init(void)
        delay_50us(300);
        write_com(0x38);
        delay_50us(10);
        write_com(0x38);
        delay_50us(10);
        write_com(0x38);
        write_com(0x38);
        write_com(0x08);
        write_com(0x01);
        write_com(0x06);
        write_com(0x0c);
        write_com(0x80);
        write_com(0x80+0x46);
        write_data(':');
        delay_50us(10);
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
void key_scan()
        if(key1==0)
        delay_50us(100);
        if(key1==0)
                TR0=0;
                AN++;
                while(!key1);
                if(AN==1)
                        write_com(0x80+0x40+8);
                        write_com(0x0f);
            if(key2==0)
            delay_50us(100);
            if(key2==0)
                   while(!key2);
                    miao++;
                    if(miao==60)
                           beef=~beef;
                                        delay_50us(10);
                     miao=0;
                     fen++;
                                        if(fen==60)
                                                fen=0;
                           write_shu(4,fen);
                    write_shu(7,miao);
                if(AN==2)
                        write_com(0x80+0x40+5);
                        write_com(0x0f);
            if(key2==0)
            delay_50us(100);
            if(key2==0)
                   while(!key2);
                           fen++;
                                if(fen==60)
                     fen=0;
                    write_shu(4,fen);
                 if(AN==1)
                        write_com(0x0f);
            if(key3==0)
            delay_50us(100);
            if(key3==0)
                   while(!key3);
                    miao--;
                    if(miao==60)
                           beef=~beef;
                                        delay_50us(10);
                     miao=0;
                     fen++;
                                        if(fen==60)
                                                fen=0;
                           write_shu(4,fen);
                    write_shu(7,miao);
                if(AN==2)
                        write_com(0x0f);
            if(key3==0)
            delay_50us(100);
            if(key3==0)
                   while(!key3);
                           fen--;
                                if(fen==60)
                     fen=0;
                    write_shu(4,fen);
           if(AN==3)
                         TR0=1;
                         AN=0;
                         write_com(0x0c);
詳細(xì)程序請(qǐng)下載壓縮包
LCD1602A電子時(shí)鐘.zip
33.26 KB, 下載次數(shù): 39, 下載積分: 黑幣 -5
ID:853104 發(fā)表于 2020-12-19 09:24 | 只看該作者
沒有原理圖?
