軟件延時
void Delay(BYTE n)
WORD x;
while (n--)
x = 0;
while (++x);
關(guān)閉IAP
void IapIdle()
IAP_CONTR = 0; //關(guān)閉IAP功能
IAP_CMD = 0; //清除命令寄存器
IAP_TRIG = 0; //清除觸發(fā)寄存器
IAP_ADDRH = 0x80; //將地址設(shè)置到非IAP區(qū)域
IAP_ADDRL = 0;
從ISP/IAP/EEPROM區(qū)域讀取一字節(jié)
BYTE IapReadByte(WORD addr)
BYTE dat; //數(shù)據(jù)緩沖區(qū)
IAP_CONTR = ENABLE_IAP; //使能IAP
IAP_CMD = CMD_READ; //設(shè)置IAP命令
IAP_ADDRL = addr; //設(shè)置IAP低地址
IAP_ADDRH = addr >> 8; //設(shè)置IAP高地址
IAP_TRIG = 0x5a; //寫觸發(fā)命令(0x5a)
IAP_TRIG = 0xa5; //寫觸發(fā)命令(0xa5)
_nop_(); //等待ISP/IAP/EEPROM操作完成
dat = IAP_DATA; //讀ISP/IAP/EEPROM數(shù)據(jù)
IapIdle(); //關(guān)閉IAP功能
return dat; //返回
寫一字節(jié)數(shù)據(jù)到ISP/IAP/EEPROM區(qū)域
void IapProgramByte(WORD addr, BYTE dat)
IAP_CMD = CMD_PROGRAM; //設(shè)置IAP命令
IAP_DATA = dat; //寫ISP/IAP/EEPROM數(shù)據(jù)
IapIdle();
扇區(qū)擦除
void IapEraseSector(WORD addr)
IAP_CMD = CMD_ERASE; //設(shè)置IAP命令
IapIdle();
//------------以上是STC提供的,以下是自己的應(yīng)用
void Put_Val(int addr,unsigned char number,unsigned char *buf)
unsigned char i;
Delay10ms(); //延時
for (i=0; i<number; i++)
IapProgramByte(addr+i, *buf++);
void Get_Val(int addr,unsigned char number,unsigned char *buf)
unsigned char i;
for(i=0;i<number;i++)
*buf++ = IapReadByte(addr+i);
//--------------用法,如果只存單字節(jié)的數(shù)據(jù), 就用unsigned char 的數(shù)組,賦值數(shù)組,然后回傳數(shù)組地址就好了, 如果要存多字節(jié)數(shù)據(jù), 就定義一個結(jié)構(gòu)體,然后用結(jié)構(gòu)體的地址讀,寫。
Put_Val(IAP_ADDRESS,8,GearVal); // unsigned char GearVal[1]={0}
Put_Val(IAP_ADDRESS,sizeof(GearVal),(unsigned char *)&GearVal); // GearVal 是結(jié)構(gòu)體名 |
