1,使用FreeRTOS
2,最大任務(wù)32個(gè),可在FreeRTOSConfig中修改
3,默認(rèn)創(chuàng)建兩個(gè)任務(wù)
4,串口FIFO,任務(wù)1默認(rèn)功能為打印串口1接收到的數(shù)據(jù)
5,頻率180M,頻率不同可能造成無(wú)法下載的問(wèn)題
由于文件大小限制,通用庫(kù)函數(shù)需要自行添加
- #include "includes.h"
- #include "bsp.h"
- void SystemClock_Config(void);
- //任務(wù)函數(shù)
- void start_task(void *pvParameters);
- void task1_task(void *pvParameters);
- void task2_task(void *pvParameters);
- void task3_task(void *pvParameters);
- void task4_task(void *pvParameters);
- void task5_task(void *pvParameters);
- void task6_task(void *pvParameters);
- void task7_task(void *pvParameters);
- void task8_task(void *pvParameters);
- //任務(wù)句柄
- TaskHandle_t StartTask_Handler = NULL;
- TaskHandle_t Task1Task_Handler = NULL;
- TaskHandle_t Task2Task_Handler = NULL;
- TaskHandle_t Task3Task_Handler = NULL;
- TaskHandle_t Task4Task_Handler = NULL;
- TaskHandle_t Task5Task_Handler = NULL;
- TaskHandle_t Task6Task_Handler = NULL;
- TaskHandle_t Task7Task_Handler = NULL;
- TaskHandle_t Task8Task_Handler = NULL;
- //任務(wù)優(yōu)先級(jí),最大32個(gè)優(yōu)先級(jí),最多32個(gè)認(rèn)為
- #define StartTask_PRO 1
- #define Task1_PRO 2
- #define Task2_PRO 3
- #define Task3_PRO 4
- #define Task4_PRO 5
- #define Task5_PRO 6
- #define Task6_PRO 7
- #define Task7_PRO 8
- #define Task8_PRO 9
- //任務(wù)延遲
- #define TASK1_DELAY 50
- #define TASK2_DELAY 100
- #define TASK3_DELAY 50
- #define TASK4_DELAY 50
- #define TASK5_DELAY 50
- #define TASK6_DELAY 50
- #define TASK7_DELAY 50
- #define TASK8_DELAY 5000
- //任務(wù)堆棧大小,默認(rèn)為512
- #define TASK_STACK_SIZE 64*8
- int main(void)
- HAL_Init();
- SystemClock_Config();
- delay_init(SystemCoreClock/100000);
- BSP_Init();
- //創(chuàng)建開(kāi)始任務(wù)
- xTaskCreate((TaskFunction_t )start_task, //任務(wù)函數(shù)
- (const char* )"start_task", //任務(wù)名稱
- (uint16_t )TASK_STACK_SIZE, //任務(wù)堆棧大小
- (void* )NULL, //傳遞給任務(wù)函數(shù)的參數(shù)
- (UBaseType_t )StartTask_PRO, //任務(wù)優(yōu)先級(jí)
- (TaskHandle_t* )&StartTask_Handler); //任務(wù)句柄
- vTaskStartScheduler(); //開(kāi)啟任務(wù)調(diào)度
- //task1任務(wù)函數(shù)
- uint8_t buflen;
- uint8_t buf[64];
- while(1)
- HAL_GPIO_WritePin(GPIOB,GPIO_PIN_7,GPIO_PIN_SET);
- #if SYS_DEBUG
- printf("F429-1\r\n");
- printf(" \r\n");
- #endif
- buflen=comReadBuf(COM1,buf);
- if(buflen>0)
- printf("BUFLEN:%d\r\n",buflen);
- comSendBuf(COM1,buf,buflen);
- printf("\r\n");
- buflen=0;
- comClearRxFifo(COM1);
- vTaskDelay(TASK1_DELAY);
- while(1)
- //進(jìn)入臨界區(qū)
- taskENTER_CRITICAL();
- //創(chuàng)建TASK1任務(wù)
- xTaskCreate((TaskFunction_t ) task1_task,
- (const char* ) "task1_task",
- (uint16_t ) TASK_STACK_SIZE,
- (void* ) NULL,
- (UBaseType_t ) Task1_PRO,
- (TaskHandle_t* ) &Task1Task_Handler);
- vTaskDelete(StartTask_Handler); //刪除開(kāi)始任務(wù)
- taskEXIT_CRITICAL(); //退出臨界區(qū)
- RCC_OscInitTypeDef RCC_OscInitStruct = {0};
- RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
- __HAL_RCC_PWR_CLK_ENABLE();
- __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
- /** Initializes the CPU, AHB and APB busses clocks
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStruct.HSEState = RCC_HSE_ON;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
- RCC_OscInitStruct.PLL.PLLM = 25;
- RCC_OscInitStruct.PLL.PLLN = 360;
- RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
- RCC_OscInitStruct.PLL.PLLQ = 4;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- /** Activate the Over-Drive mode
- if (HAL_PWREx_EnableOverDrive() != HAL_OK)
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t *file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* USER CODE END 6 */
- #endif /* USE_FULL_ASSERT */
F429_RTOS.zip
(43.62 KB, 下載次數(shù): 39)
2020-10-16 14:24 上傳
點(diǎn)擊文件名下載附件
