查看: 944|回復(fù): 0
請問大佬們這個Proteus仿真怎么畫?
ID:828304 發(fā)表于 2020-10-17 11:43 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
int local(unsigned int i);
unsigned int locals = 0;
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
sbit key1 = P2^4;
sbit key2 = P2^5;
sbit key3 = P2^6;
unsigned char leds[] = {0xC0,0xF9,0xA4,0xB0,0x99,
                                                0x92,0x82,0xF8,0x80,0x90 };
unsigned char ledss[10][8]={  {0xAA,0x55,0xAA,0x55,0xAA,0x55,0xAA,0x55},
                                                          {0xE7,0xE3,0xE7,0xE7,0xE7,0xE7,0xE7,0xC3},
                                                          {0x81,0x81,0x9F,0x81,0x81,0xF9,0x81,0x81},
                                                             {0x81,0x81,0x9F,0x81,0x81,0x9F,0x81,0x81},
                                                             {0x8F,0x87,0x93,0x99,0x9C,0x00,0x00,0x9F},
                                                          {0x81,0x81,0xF9,0x81,0x81,0x9F,0x81,0x81},
                                                          {0x81,0x81,0xF9,0x81,0x81,0x99,0x81,0x81},
                                                          {0x83,0x83,0x9F,0x9F,0x9F,0x9F,0x9F,0x9F},
                                                      {0x81,0x81,0x99,0x81,0x81,0x99,0x81,0x81},
                                                             {0x81,0x81,0x99,0x81,0x81,0x9F,0x81,0x81}, };
        ADDR3 = 0;
        ENLED = 0;
        EA = 1;
        TMOD = 0x01;
        ET0 = 1;
        TH0 = 0xFC;
        TL0 = 0x67;
        TR0 = 1;
        //開啟九位輸入鍵,其它鍵關(guān)閉
        P2 = 0xF1;
                //得到鍵位所在KeyIn1輸入列
                if(key1==0)
                        locals = local(1);
                        TR0 = 1;
                //得到鍵位所在KeyIn2輸入列
                else if(key2==0)
                        locals = local(2);
                        TR0 = 1;
                //得到鍵位所在KeyIn3輸入列
                else if(key3==0)
                        locals = local(3);
                        TR0 = 1;
         //對應(yīng)鍵位賦值數(shù)碼管
void InterruptTimer0() interrupt 1
        static unsigned char i = 0;
        TH0 = 0xFC;             // 1ms
        TL0 = 0x67;
        P0 = 0xFF;
        ADDR3 = 0;
        switch(i)
        {        case 0: ADDR0 = 0;ADDR1 = 0;ADDR2 = 0; P0 = ledss[locals][i];i++;break;
                case 1: ADDR0 = 1;ADDR1 = 0;ADDR2 = 0; P0 = ledss[locals][i];i++;break;
                case 2: ADDR0 = 0;ADDR1 = 1;ADDR2 = 0; P0 = ledss[locals][i];i++;break;
                case 3: ADDR0 = 1;ADDR1 = 1;ADDR2 = 0; P0 = ledss[locals][i];i++;break;
                case 4: ADDR0 = 0;ADDR1 = 0;ADDR2 = 1; P0 = ledss[locals][i];i++;break;
                case 5: ADDR0 = 1;ADDR1 = 0;ADDR2 = 1; P0 = ledss[locals][i];i++;break;
                case 6: ADDR0 = 0;ADDR1 = 1;ADDR2 = 1; P0 = ledss[locals][i];i++;break;
                case 7: ADDR0 = 1;ADDR1 = 1;ADDR2 = 1; P0 = ledss[locals][i];i++;break;
                case 8: ADDR3 = 1;ADDR0 = 0;ADDR1 = 0;ADDR2 = 0; P0 = leds[locals];i++;break;
                case 9: ADDR3 = 1;ADDR0 = 1;ADDR1 = 0;ADDR2 = 1; P0 = leds[locals];i=0;break;
                default: break; //代表無此類情況,跳出
        unsigned int b;
        //判斷當(dāng)前鍵位
        switch(i)
        //得到鍵位所在KeyIn1輸入列
        case 1: P2 = 0xF7;  //僅僅開啟out1
                        if(key1 == 0){      b = 1;     }
                        P2 = 0xFB;  //僅僅開啟out2
                        if(key1 == 0){      b = 4;     }
                        P2 = 0xFD;  //僅僅開啟out3
                        if(key1 == 0){      b = 7;     }
                        break;
        //得到鍵位所在KeyIn2輸入列
        case 2: P2 = 0xF7;  //僅僅開啟out1
                        if(key2 == 0){      b = 2;     }
                        if(key2 == 0){      b = 5;     }
                        if(key2 == 0){      b = 8;     }
                        break;
        //得到鍵位所在KeyIn3輸入列
        case 3: P2 = 0xF7;  //僅僅開啟out1
                        if(key3 == 0){      b = 3;     }
                        if(key3 == 0){      b = 6;        }
                        if(key3 == 0){      b = 9;     }
                        break;
        default: break;
        //重置開啟九位輸入鍵,其它鍵關(guān)閉
        P2 = 0xF1;
        return b;
