本帖最后由 jinglixixi 于 2020-10-23 10:10 編輯
有了程序下載和點亮LED燈的基礎,我們就可以利用I/O口來嘗試驅動OLED屏了,這里選的是I2C接口的OLED屏,只需占用2個I/O口,故十分節(jié)省資源,對于像HC32L110這樣原本就引腳不多的芯片更是如此。 那么選哪個引腳來連接OLED屏呢? 這里選取的是P35和P36,其中P35--- CLK,P36--- DIN。 配置這2個引腳為輸出功能的函數(shù)為: - void App_OledInit(void)
- Gpio_InitIOExt(3, 5, GpioDirOut, TRUE, FALSE, TRUE, FALSE);
- Gpio_InitIOExt(3, 6, GpioDirOut, TRUE, FALSE, TRUE, FALSE);
復制代碼
是這2個引腳輸出高低電平的語句為:#define OLED_SCLK_Set() Gpio_SetIO(3, 5, TRUE) #define OLED_SCLK_Clr() Gpio_SetIO(3, 5, FALSE) #define OLED_SDIN_Set() Gpio_SetIO(3, 6, TRUE) #define OLED_SDIN_Clr() Gpio_SetIO(3, 6, FALSE) 該顯示屏的初始化函數(shù)為: - void OLED_Init(void)
- OLED_SCLK_Set();
- OLED_SDIN_Set();
- delay1ms(800);
- OLED_WR_Byte(0xAE,OLED_CMD);//--display off
- OLED_WR_Byte(0x40,OLED_CMD);//--set start line address
- OLED_WR_Byte(0xB0,OLED_CMD);//--set page address
- OLED_WR_Byte(0xC8,OLED_CMD);//Com scan direction
- OLED_WR_Byte(0x81,OLED_CMD); // contract control
- OLED_WR_Byte(0xFF,OLED_CMD);//--128
- OLED_WR_Byte(0xA1,OLED_CMD);//set segment remap
- OLED_WR_Byte(0xA6,OLED_CMD);//--normal / reverse
- OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
- OLED_WR_Byte(0x1F,OLED_CMD);//--1/32 duty
- OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset
- OLED_WR_Byte(0x00,OLED_CMD);//
- OLED_WR_Byte(0xD5,OLED_CMD);//set osc division
- OLED_WR_Byte(0xf0,OLED_CMD);//
- OLED_WR_Byte(0xD9,OLED_CMD);//Set Pre-Charge Period
- OLED_WR_Byte(0x22,OLED_CMD);//
- OLED_WR_Byte(0xDA,OLED_CMD);//set com pin configuartion
- OLED_WR_Byte(0x02,OLED_CMD);//
- OLED_WR_Byte(0xDB,OLED_CMD);//set Vcomh
- OLED_WR_Byte(0x49,OLED_CMD);//
- OLED_WR_Byte(0x8D,OLED_CMD);//set charge pump enable
- OLED_WR_Byte(0x14,OLED_CMD);//
- OLED_WR_Byte(0xAF,OLED_CMD);//--turn on oled panel
- OLED_Clear();
復制代碼
實現(xiàn)圖1和圖2顯示效果的主程序為:- int32_t main(void)
- delay1ms(100);
- OLED_Init();
- OLED_Clear();
- OLED_ShowString(0,0,"HC32L110 TEST",16);
- OLED_ShowString(0,2,"OLED DISPLAY",16);
- delay1ms(2000);
- OLED_Clear();
- OLED_ShowCHinese(0, 0, 3);
- OLED_ShowCHinese(16, 0, 4);
- OLED_ShowCHinese(32, 0, 5);
- OLED_ShowCHinese(48, 0, 6);
- OLED_ShowCHinese(64, 0, 7);
- OLED_ShowCHinese(0, 2, 8);
- OLED_ShowCHinese(16, 2, 9);
- OLED_ShowCHinese(32, 2, 10);
- OLED_ShowCHinese(48, 2, 11);
- OLED_ShowCHinese(64, 2, 12);
- while (1);
復制代碼
2020-10-23 10:09 上傳
圖1 顯示字符串
2020-10-23 10:09 上傳
圖2 顯示漢字
