- #include <reg52.h>
- #include<intrins.h>
- //#define _nop() _asm nop _endasm
- typedef unsigned char uchar;
- typedef unsigned int uint;
- sbit RX = P2^0;//接收
- sbit TX = P2^1;//發(fā)射
- uchar flag;
- uchar date_distance[5];//距離
- uchar kk;
- sbit duan = P2^6;//段選
- sbit wei = P2^7;//位選
- uchar duan1[] = {0X3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00};
- uchar wei1 [] = {0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
- // void delay_10us(uchar i)
- // while(i--);
- void delay_ms(uint c)
- uint a,b;
- for(;c>0;c--)
- for(b=102;b>0;b--)
- for(a=3;a>0;a--);
- void init_wei(uchar i)
- P0 = 0xff;
- wei = 1;
- P0 = wei1[i] ;
- wei = 0;
- void init_timer()// 定時器初始化
- TMOD = 0X11;// 定義定時器定時類型
- TH0 = 0x00;// 定時器0高位
- TL0 = 0x00;// 定時器0低位
- EA = 1;// 單片機中斷總開關(guān)
- ET0 = 1;// 允許T0溢出中斷
- TH1 = 0xf8;// 定時器1高位
- TL1 = 0xCD;// 定時器1低位
- ET1 = 1;// 允許T1溢出中斷
- TR1 = 1;// 定時器1的運行控制位
- void count_distance()// 距離數(shù)
- uint distance = (TH0*256+TL0*1)*0.18;// 通過時間算距離
- TH0 = 0;
- TL0 = 0;
- // 計時器歸零
- if(distance>=4000||distance < 20)
- flag = 1;
- else
- date_distance[1] = distance%10000/1000;
- date_distance[2] = distance%1000/100;
- date_distance[3] = distance%100/10;
- date_distance[4] = distance%10/1;
- void display()// 顯示
- uchar i;
- if(flag==1)
- flag = 0;
- date_distance[1] = 14;
- date_distance[2] = 14;
- date_distance[3] = 14;
- date_distance[4] = 14;
- count_distance();
- for(i = 1;i<=4;i++)
- init_wei(i);
- duan = 1;
- if(i==1)
- P0 = duan1[date_distance[i]]|0x80;
- else
- P0 =duan1[date_distance[i]];
- delay_ms(1);
- duan = 0;
- P0 = 0x00;
- void main()
- RX = 0;
- TX=0;
- init_timer();//定時器初始化
- while(1)
- TR1=1;
- while(!RX);// 收到信號RX為零
- TR0 = 1;
- while(RX);
- TR0 = 0;
- count_distance();
- void timer0() interrupt 1
- flag = 1;
- void timer1() interrupt 3
- TR1 = 0;
- TH1 = 0xf8;
- // 0xf8;
- TL1 = 0xcd;
- // 0xcd;
- kk ++;
- display();
- if(kk>100)
- kk = 0;
- TX = 1;
- _nop_();_nop_();_nop_();_nop_();
- TX = 0;
- TR1 = 1;
