查看: 5556|回復(fù): 0
簡易51單片機(jī)跑馬燈,含源碼、仿真原理圖
ID:835221 發(fā)表于 2020-10-27 15:59 | 顯示全部樓層 |閱讀模式
可供初學(xué)者學(xué)習(xí),代碼清晰易懂,八個按鈕,四個不同跑馬燈形式,四個調(diào)節(jié)頻率。
  1. #include"reg51.h"
  2. code unsigned char leddat1[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
  3. code unsigned char leddat2[]={0x01,0x80,0x02,0x40,0x04,0x20,0x08,0x10};
  4. code unsigned char leddat3[]={0x01,0x02,0x04,0x08,0x80,0x40,0x20,0x10};
  5. code unsigned char leddat4[50]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,0x81,0x82,
  6.                                             0x84,0x88,0x90,0xA0,0xC0,0xC1,0xC2,0xC4,0xC8,0xD0,
  7.                                                          0xE0,0xE1,0xE2,0xE4,0xE8,0xF0,0xF1,0xF2,0xF4,0xF8,
  8.                                                         0xF9,0xFA,0xFC,0xFD,0xFE,0xFF,0xFF,0x00,0xFF,0x00};
  9. void delay(unsigned int n)
  10. {
  11.     unsigned int i=0,j=0;
  12.     for(i=0;i<n;i++)
  13.     {
  14.          for(j=0;j<120;j++);
  15.     }
  16. }
  17. void led1()
  18. {
  19. int i=0;
  20. for(i=0;i<8;i++)
  21. {
  22. P2=~leddat1[i];
  23. delay(400);
  24. }
  25. }
  26. void led2()
  27. {
  28. int i=0;
  29. for(i=0;i<8;i++)
  30. {
  31. P2=~leddat2[i];
  32. delay(400);
  33. }
  34. }
  35. void led3()
  36. {
  37. int i=0;
  38. for(i=0;i<8;i++)
  39. {
  40. P2=~leddat3[i];
  41. delay(400);
  42. }
  43. }
  44. void led4()
  45. {
  46. int i=0;
  47. for(i=0;i<50;i++)
  48. {
  49. P2=~leddat4[i];
  50. delay(400);
  51. }
  52. }
  53. void ledF1()
  54. {
  55. int i=0;
  56. for(i=0;i<8;i++)
  57. {
  58. P2=~leddat1[i];
  59. delay(100);
  60. }
  61. }
  62. void ledF2()
  63. {
  64. int i=0;
  65. for(i=0;i<8;i++)
  66. {
  67. P2=~leddat1[i];
  68. delay(400);
  69. }
  70. }
  71. void ledF3()
  72. {
  73. int i=0;
  74. for(i=0;i<8;i++)
  75. {
  76. P2=~leddat1[i];
  77. delay(1000);
  78. }
  79. }
  80. void ledF4()
  81. {
  82. int i=0;
  83. for(i=0;i<8;i++)
  84. {
  85. P2=~leddat1[i];
  86. delay(2000);
  87. }
  88. }
  89. void main()
  90. {
  91. while(1)
  92. {
  93. if(P1==~0x01)
  94. {led1();}
  95. if(P1==~0x02)
  96. {led2();}
  97. if(P1==~0x04)
  98. {led3();}
  99. if(P1==~0x08)
  100. {led4();}
  101. if(P1==~0x10)
  102. {ledF1();}
  103. if(P1==~0x20)
  104. {ledF2();}
  105. if(P1==~0x40)
  106. {ledF3();}
  107. if(P1==~0x80)
  108. {ledF4();}
  109. }
  110. }
MCS-51單片機(jī)完成頻率、花色可調(diào)的跑馬燈.zip (51.08 KB, 下載次數(shù): 41)
admin + 50 共享資料的黑幣獎勵!
無效樓層,該帖已經(jīng)被刪除
