查看: 10349|回復(fù): 9
proteus8.10仿真stm32控制舵機(jī)程序(pwm舵機(jī))
ID:721056 發(fā)表于 2020-11-6 21:38 | 顯示全部樓層 |閱讀模式
       本貼使用Proteus8.10,如低版本打不開(kāi)可自行根據(jù)原理圖繪制(很簡(jiǎn)單)
單片機(jī)型號(hào)為:stm32f103系列
運(yùn)行穩(wěn)定,舵機(jī)角度自行更改程序中的pwm輸出函數(shù)值即可。
   案例中只做了一個(gè),按鍵按下舵機(jī)轉(zhuǎn)動(dòng),實(shí)際測(cè)試過(guò)timer2-4的通道0-3,共12路pwm。
       如有問(wèn)題,評(píng)論區(qū)留言,看到回~
  1. #include "stm32f10x.h"
  2. #include "bsp-lcd1602.h"
  3. #include "delay.h"
  4. #include "sys.h"
  5. #include "adc.h"
  6. #define LED0 PCout(2)
  7. #define KEY0  GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_5)                                                 //讀取按鍵0
  8. #define KEY1  GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_15)                                               //讀取按鍵1
  9. #define WK_UP GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)
  10. void KEY_Init(void)
  11. {
  12.
  13.         GPIO_InitTypeDef GPIO_InitStructure;
  14.          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC,ENABLE);  //使能PORTA,PORTC時(shí)鐘
  15.         GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);                               //關(guān)閉jtag使能SWD,可以用SWD模式調(diào)試
  16.         GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_15;
  17.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;                                                    //設(shè)置成上拉輸入
  18.          GPIO_Init(GPIOA, &GPIO_InitStructure);        //初始化GPIOA15
  19.
  20.         GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_5;
  21.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;                                                   //設(shè)置成上拉輸入
  22.          GPIO_Init(GPIOC, &GPIO_InitStructure);        //初始化GPIOC5
  23.                 GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_0;
  24.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
  25.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  26.
  27. }
  28. void LED_Init(void)
  29. {
  30. GPIO_InitTypeDef  GPIO_InitStructure;
  31. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);          //使能PA,PD端口時(shí)鐘
  32. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;                                   //LED0-->PA.8 端口配置
  33. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                   //推挽輸出
  34. GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                  //IO口速度為50MHz
  35. GPIO_Init(GPIOC, &GPIO_InitStructure);                                        //根據(jù)設(shè)定參數(shù)初始化GPIOA.8
  36. GPIO_SetBits(GPIOC,GPIO_Pin_2);                                                //PA.8 輸出高
  37. }
  38. void TIM1_PWM_Init(u16 arr,u16 psc)
  39. {
  40.          GPIO_InitTypeDef GPIO_InitStructure;
  41.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  42.         TIM_OCInitTypeDef  TIM_OCInitStructure;
  43.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
  44.          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE);             //使能GPIO外設(shè)時(shí)鐘使能
  45.
  46.    //設(shè)置該引腳為復(fù)用輸出功能,輸出TIM1 CH1的PWM脈沖波形
  47.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;                                      //TIM_CH1
  48.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                        //復(fù)用推挽輸出
  49.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  50.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  51.
  52.         TIM_TimeBaseStructure.TIM_Period = arr; //設(shè)置在下一個(gè)更新事件裝入活動(dòng)的自動(dòng)重裝載寄存器周期的值         80K
  53.         TIM_TimeBaseStructure.TIM_Prescaler =psc; //設(shè)置用來(lái)作為T(mén)IMx時(shí)鐘頻率除數(shù)的預(yù)分頻值  不分頻
  54.         TIM_TimeBaseStructure.TIM_ClockDivision = 0; //設(shè)置時(shí)鐘分割:TDTS = Tck_tim
  55.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上計(jì)數(shù)模式
  56.         TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); //根據(jù)TIM_TimeBaseInitStruct中指定的參數(shù)初始化TIMx的時(shí)間基數(shù)單位
  57.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //選擇定時(shí)器模式:TIM脈沖寬度調(diào)制模式2
  58.         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比較輸出使能
  59.         TIM_OCInitStructure.TIM_Pulse = 0; //設(shè)置待裝入捕獲比較寄存器的脈沖值
  60.         TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //輸出極性:TIM輸出比較極性高
  61.         TIM_OC1Init(TIM1, &TIM_OCInitStructure);  //根據(jù)TIM_OCInitStruct中指定的參數(shù)初始化外設(shè)TIMx
  62.   TIM_CtrlPWMOutputs(TIM1,ENABLE);        //MOE 主輸出使能
  63.         TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);  //CH1預(yù)裝載使能
  64.
  65.         TIM_ARRPreloadConfig(TIM1, ENABLE); //使能TIMx在ARR上的預(yù)裝載寄存器
  66.
  67.         TIM_Cmd(TIM1, ENABLE);  //使能TIM1
  68.
  69. }
  70. int main(void)
  71. {
  72.         delay_init();
  73.         LED_Init();
  74.         KEY_Init();
  75.         TIM1_PWM_Init(1999,72);
  76.         TIM_SetCompare1(TIM1,1899);
  77.         while(1)
  78.         {
  79.                 if(WK_UP==1)
  80.                 {
  81.                         LED0=0;
  82.                         TIM_SetCompare1(TIM1,1899);
  83.                 }
  84.                 else
  85.                 {
  86.                         LED0=1;
  87.                         TIM_SetCompare1(TIM1,699);
  88.                 }
  89.         }
  90. }
[ stm32控制舵機(jī).7z (196.33 KB, 下載次數(shù): 389)
本貼為原創(chuàng),轉(zhuǎn)載請(qǐng)注明出處!
時(shí)間:2020/11/
祝好!
ID:917281 發(fā)表于 2021-5-7 22:11 | 顯示全部樓層
想問(wèn)一下 如果弄4個(gè)舵機(jī)的話(huà) 程序要怎么改
ID:242753 發(fā)表于 2021-5-9 10:15 | 顯示全部樓層
最近正在研究舵機(jī),正好可以好好分析了
ID:841381 發(fā)表于 2021-5-13 19:27 | 顯示全部樓層
樓主你好,如果拖動(dòng)4個(gè)電機(jī),然后發(fā)現(xiàn)功率不夠該怎么辦?
ID:985711 發(fā)表于 2021-11-28 21:13 | 顯示全部樓層
感謝樓主的分享,下來(lái)研究下
ID:1013164 發(fā)表于 2022-5-8 20:13 | 顯示全部樓層
為啥我就改了PWM頻率,他就生成不了.hex文件了,顯示有一個(gè)fatal error
ID:1024276 發(fā)表于 2022-5-10 23:28 | 顯示全部樓層
樓主你好 為啥我按照你的方法配置 配置的PWM  PA8 電平只是在跳動(dòng) 舵機(jī)卻沒(méi)有反應(yīng) ,代碼也一樣 用的正點(diǎn)原子的模板
ID:1024276 發(fā)表于 2022-5-10 23:29 | 顯示全部樓層
為啥我按照樓主的配置 PA8  只是電平再跳 ,而舵機(jī)沒(méi)有反應(yīng),模板用的正點(diǎn)原子的
ID:1060890 發(fā)表于 2023-3-6 13:25 | 顯示全部樓層
試一下能不能用,自己配置的總有問(wèn)題
ID:316613 發(fā)表于 2023-5-21 10:56 | 顯示全部樓層
只能轉(zhuǎn)動(dòng)一下,813版本,不知道為啥
