第一次發(fā)帖,難免有錯請指出
由STC89C52單片機(jī)系統(tǒng)(主要是STC89C52單片機(jī)最小系統(tǒng))、4×4矩陣鍵盤、LCD1602顯示和報警系統(tǒng)等組成一個密碼鎖,具有設(shè)置、修改六位用戶密碼、超次報警、超次鎖定、密碼錯誤報警等功能。
密碼正確顯示OPEN! 密碼錯誤顯示error!超過三次輸入錯誤自動鎖定。
輸入密碼時在LCD屏幕上顯示*號,若密碼輸入錯誤次數(shù)超過3次,蜂
鳴器報警并且鎖定鍵盤。
對輸入的6位密碼進(jìn)行隱藏;通過發(fā)光二極管和蜂鳴器,對解密正確或者錯誤進(jìn)行聲光報警;
- //<font style="background-color:rgb(255, 255, 255)">
- #include <reg51.h>
- #include<intrins.h>
- #define LCM_Data P0
- #define uchar unsigned char
- #define uint unsigned int
- #define w 6 //定義密碼位數(shù)
- sbit lcd1602_rs=P2^7;
- sbit lcd1602_rw=P2^6;
- sbit lcd1602_en=P2^5;
- sbit Scl=P3^4; //24C02串行時鐘
- sbit Sda=P3^5; //24C02串行數(shù)據(jù)
- sbit ALAM = P2^1; //報警
- sbit KEY = P3^6; //開鎖
- sbit open_led=P2^2; //開鎖指示燈
- bit operation=0; //操作標(biāo)志位
- bit pass=0; //密碼正確標(biāo)志
- bit ReInputEn=0; //重置輸入充許標(biāo)志
- bit s3_keydown=0; //3秒按鍵標(biāo)志位
- bit key_disable=0; //鎖定鍵盤標(biāo)志
- unsigned char countt0,second; //t0中斷計數(shù)器,秒計數(shù)器
- void Delay5Ms(void);
- unsigned char code a[]={0xFE,0xFD,0xFB,0xF7}; //控盤掃描控制表
- unsigned char code start_line[] = {"password: "};
- unsigned char code name[] = {"===Coded Lock==="}; //顯示名稱
- unsigned char code Correct[] = {" correct "}; //輸入正確
- unsigned char code Error[] = {" error "}; //輸入錯誤
- unsigned char code codepass[] = {" pass "};
- unsigned char code LockOpen[] = {" open "}; //OPEN
- unsigned char code SetNew[] = {"SetNewWordEnable"};
- unsigned char code Input[] = {"input: "}; //INPUT
- unsigned char code ResetOK[] = {"ResetPasswordOK "};
- unsigned char code initword[] = {"Init password..."};
- unsigned char code Er_try[] = {"error,try again!"};
- unsigned char code again[] = {"input again "};
- unsigned char InputData[6]; //輸入密碼暫存區(qū)
- unsigned char CurrentPassword[6]={1,3,1,4,2,0}; //當(dāng)前密碼值
- unsigned char TempPassword[6];
- unsigned char N=0; //密碼輸入位數(shù)記數(shù)
- unsigned char ErrorCont; //錯誤次數(shù)計數(shù)
- unsigned char CorrectCont; //正確輸入計數(shù)
- unsigned char ReInputCont; //重新輸入計數(shù)
- unsigned char code initpassword[6]={0,0,0,0,0,0};
- //=====================5ms延時==============================
- unsigned int TempCyc = 5552;
- while(TempCyc--);
- //===================400ms延時==============================
- void Delay400Ms(void)
- unsigned char TempCycA = 5;
- unsigned int TempCycB;
- while(TempCycA--)
- TempCycB=7269;
- while(TempCycB--);
- //================================24C02========================================================
- void mDelay(uint t) //延時
- uchar i;
- while(t--)
- for(i=0;i<125;i++)
- void Nop(void) //空操作
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- /*起始條件*/
- void Start(void)
- Sda=1;
- Scl=1;
- Nop();
- Sda=0;
- Nop();
- /*停止條件*/
- void Stop(void)
- Sda=0;
- Scl=1;
- Nop();
- Sda=1;
- Nop();
- /*應(yīng)答位*/
- void Ack(void)
- Sda=0;
- Nop();
- Scl=1;
- Nop();
- Scl=0;
- /*反向應(yīng)答位*/
- void NoAck(void)
- Sda=1;
- Nop();
- Scl=1;
- Nop();
- Scl=0;
- /*發(fā)送數(shù)據(jù)子程序,Data為要求發(fā)送的數(shù)據(jù)*/
- void Send(uchar Data)
- uchar BitCounter=8;
- uchar temp;
- do
- temp=Data;
- Scl=0;
- Nop();
- if((temp&0x80)==0x80)
- Sda=1;
- else
- Sda=0;
- Scl=1;
- temp=Data<<1;
- Data=temp;
- BitCounter--;
- while(BitCounter);
- Scl=0;
- /*讀一字節(jié)的數(shù)據(jù),并返回該字節(jié)值*/
- uchar Read(void)
- uchar temp=0;
- uchar temp1=0;
- Sda=1;
- do{
- Scl=0;
- Nop();
- Scl=1;
- Nop();
- if(Sda)
- temp=temp|0x01;
- else
- temp=temp&0xfe;
- if(BitCounter-1)
- temp1=temp<<1;
- temp=temp1;
- BitCounter--;
- return(temp);
- void WrToROM(uchar Data[],uchar Address,uchar Num)
- uchar i;
- uchar *PData;
- PData=Data;
- for(i=0;i<Num;i++)
- Start();
- Send(0xa0);
- Ack();
- Send(Address+i);
- Ack();
- Send(*(PData+i));
- Ack();
- Stop();
- mDelay(20);
- void RdFromROM(uchar Data[],uchar Address,uchar Num)
- uchar i;
- uchar *PData;
- PData=Data;
- Start();
- Send(0xa0);
- Ack();
- Send(Address+i);
- Ack();
- Start();
- Send(0xa1);
- Ack();
- *(PData+i)=Read();
- Scl=0;
- NoAck();
- Stop();
- //=======================================LCD1602====================================================
- #define yi 0x80 //LCD第一行的初始位置,因為LCD1602字符地址首位D7恒定為1(100000000=80)
- #define er 0x80+0x40 //LCD第二行初始位置(因為第二行第一個字符位置地址是0x40)
- //----------------延時函數(shù),后面經(jīng)常調(diào)用----------------------
- void delay(uint xms)//延時函數(shù),有參函數(shù)
- uint x,y;
- for(x=xms;x>0;x--)
- for(y=110;y>0;y--);
- //--------------------------寫指令---------------------------
- write_1602com(uchar com)//****液晶寫入指令函數(shù)****
- lcd1602_rs=0;//數(shù)據(jù)/指令選擇置為指令
- lcd1602_rw=0; //讀寫選擇置為寫
- P0=com;//送入數(shù)據(jù)
- delay(1);
- lcd1602_en=1;//拉高使能端,為制造有效的下降沿做準(zhǔn)備
- delay(1);
- lcd1602_en=0;//en由高變低,產(chǎn)生下降沿,液晶執(zhí)行命令
- //-------------------------寫數(shù)據(jù)-----------------------------
- write_1602dat(uchar dat)//***液晶寫入數(shù)據(jù)函數(shù)****
- lcd1602_rs=1;//數(shù)據(jù)/指令選擇置為數(shù)據(jù)
- P0=dat;//送入數(shù)據(jù)
- delay(1);
- lcd1602_en=1; //en置高電平,為制造下降沿做準(zhǔn)備
- delay(1);
- lcd1602_en=0; //en由高變低,產(chǎn)生下降沿,液晶執(zhí)行命令
- //-------------------------初始化-------------------------
- void lcd_init(void)
- write_1602com(0x38);//設(shè)置液晶工作模式,意思:16*2行顯示,5*7點陣,8位數(shù)據(jù)
- write_1602com(0x0c);//開顯示不顯示光標(biāo)
- write_1602com(0x06);//整屏不移動,光標(biāo)自動右移
- write_1602com(0x01);//清顯示
- //==============將按鍵值編碼為數(shù)值=========================
- unsigned char coding(unsigned char m)
- unsigned char k;
- switch(m)
- case (0x11): k=1;break;
- case (0x21): k=2;break;
- case (0x41): k=3;break;
- case (0x81): k='A';break;
- case (0x12): k=4;break;
- case (0x22): k=5;break;
- case (0x42): k=6;break;
- case (0x82): k='B';break;
- case (0x14): k=7;break;
- case (0x24): k=8;break;
- case (0x44): k=9;break;
- case (0x84): k='C';break;
- case (0x18): k='*';break;
- case (0x28): k=0;break;
- case (0x48): k='#';break;
- case (0x88): k='D';break;
- return(k);
- //=====================按鍵檢測并返回按鍵值===============================
- unsigned char keynum(void)
- unsigned char row,col,i;
- P1=0xf0;
- if((P1&0xf0)!=0xf0)
- Delay5Ms();
- Delay5Ms();
- row=P1^0xf0; //確定行線
- i=0;
- P1=a[i]; //精確定位
- while(i<4)
- col=~(P1&0xff); //確定列線
- break; //已定位后提前退出
- else
- i++;
- P1=a[i];
- else
- return 0;
- while((P1&0xf0)!=0xf0);
- return (row|col); //行線與列線組合后返回
- else return 0; //無鍵按下時返回0
- //=======================一聲提示音,表示有效輸入========================
- void OneAlam(void)
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- //========================二聲提示音,表示操作成功========================
- void TwoAlam(void)
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- //========================三聲提示音,表示錯誤========================
- void ThreeAlam(void)
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- //=====================顯示輸入的N個數(shù)字,用H代替以便隱藏============================
- void DisplayOne(void)
- // DisplayOneChar(9+N,1,'*');
- write_1602com(yi+5+N);
- write_1602dat('*');
- //=======================顯示提示輸入=========================
- void DisplayChar(void)
- unsigned char i;
- if(pass==1)
- //DisplayListChar(0,1,LockOpen);
- write_1602com(er);
- for(i=0;i<16;i++)
- write_1602dat(LockOpen[i]);
- else
- if(N==0)
- //DisplayListChar(0,1,Error);
- for(i=0;i<16;i++)
- write_1602dat(Error[i]);
- else
- //DisplayListChar(0,1,start_line);
- for(i=0;i<16;i++)
- write_1602dat(start_line[i]);
- void DisplayInput(void)
- unsigned char i;
- if(CorrectCont==1)
- //DisplayListChar(0,0,Input);
- for(i=0;i<16;i++)
- write_1602dat(Input[i]);
- //========================重置密碼==================================================
- void ResetPassword(void)
- unsigned char i;
- unsigned char j;
- if(pass==0)
- pass=0;
- DisplayChar();
- ThreeAlam();
- else
- if(ReInputEn==1)
- if(N==6)
- ReInputCont++;
- if(ReInputCont==2)
- for(i=0;i<6;)
- if(TempPassword[i]==InputData[i]) //將兩次輸入的新密碼作對比
- i++;
- else
- for(j=0;j<16;j++)
- write_1602dat(Error[j]);
- ThreeAlam(); //錯誤提示
- pass=0;
- ReInputEn=0; //關(guān)閉重置功能,
- ReInputCont=0;
- DisplayChar();
- break;
- if(i==6)
- //DisplayListChar(0,1,ResetOK);
- for(j=0;j<16;j++)
- write_1602dat(ResetOK[j]);
- TwoAlam(); //操作成功提示
- WrToROM(TempPassword,0,6); //將新密碼寫入24C02存儲
- ReInputEn=0;
- ReInputCont=0;
- CorrectCont=0;
- else
- OneAlam();
- //DisplayListChar(0, 1, again); //顯示再次輸入一次
- for(j=0;j<16;j++)
- write_1602dat(again[j]);
- for(i=0;i<6;i++)
- TempPassword[i]=InputData[i]; //將第一次輸入的數(shù)據(jù)暫存起來
- N=0; //輸入數(shù)據(jù)位數(shù)計數(shù)器清零
- //=======================輸入密碼錯誤超過三過,報警并鎖死鍵盤======================
- void Alam_KeyUnable(void)
- P1=0x00;
- ALAM=~ALAM;
- Delay5Ms();
- //=======================取消所有操作============================================
- void Cancel(void)
- unsigned char i;
- unsigned char j;
- //DisplayListChar(0, 1, start_line);
- for(j=0;j<16;j++)
- write_1602dat(start_line[j]);
- TwoAlam(); //提示音
- for(i=0;i<6;i++)
- InputData[i]=0;
- KEY=1; //關(guān)閉鎖
- ALAM=1; //報警關(guān)
- operation=0; //操作標(biāo)志位清零
- pass=0; //密碼正確標(biāo)志清零
- ReInputEn=0; //重置輸入充許標(biāo)志清零
- ErrorCont=0; //密碼錯誤輸入次數(shù)清零
- CorrectCont=0; //密碼正確輸入次數(shù)清零
- ReInputCont=0; //重置密碼輸入次數(shù)清零
- open_led=1;
- s3_keydown=0;
- key_disable=0;
- N=0; //輸入位數(shù)計數(shù)器清零
- //==========================確認(rèn)鍵,并通過相應(yīng)標(biāo)志位執(zhí)行相應(yīng)功能===============================
- void Ensure(void)
- unsigned char i,j;
- RdFromROM(CurrentPassword,0,6); //從24C02里讀出存儲密碼
- if(N==6)
- if(ReInputEn==0) //重置密碼功能未開啟
- for(i=0;i<6;)
- if(CurrentPassword[i]==InputData[i])
- i++;
- else
- ErrorCont++;
- if(ErrorCont==3) //錯誤輸入計數(shù)達(dá)三次時,報警并鎖定鍵盤
- for(i=0;i<16;i++)
- do
- Alam_KeyUnable();
- while(1);
- else
- TR0=1; //開啟定時
- key_disable=1; //鎖定鍵盤
- pass=0;
- break;
- if(i==6)
- CorrectCont++;
- if(CorrectCont==1) //正確輸入計數(shù),當(dāng)只有一次正確輸入時,開鎖,
- for(j=0;j<16;j++)
- write_1602dat(LockOpen[j]);
- TwoAlam(); //操作成功提示音
- KEY=0; //開鎖
- pass=1; //置正確標(biāo)志位
- TR0=1; //開啟定時
- open_led=0; //開鎖指示燈亮
- for(j=0;j<6;j++) //將輸入清除
- InputData[i]=0;
- else //當(dāng)兩次正確輸入時,開啟重置密碼功能
- //DisplayListChar(0,1,SetNew);
- for(j=0;j<16;j++)
- write_1602dat(SetNew[j]);
- ReInputEn=1; //允許重置密碼輸入
- CorrectCont=0; //正確計數(shù)器清零
- else //=========================當(dāng)?shù)谝淮问褂没蛲浢艽a時可以用131420對其密碼初始化============
- if((InputData[0]==1)&&(InputData[1]==3)&&(InputData[2]==1)&&(InputData[3]==4)&&(InputData[4]==2)&&(InputData[5]==0))
- WrToROM(initpassword,0,6); //強制將初始密碼寫入24C02存儲
- //DisplayListChar(0,1,initword); //顯示初始化密碼
- for(j=0;j<16;j++)
- write_1602dat(initword[j]);
- TwoAlam();
- Delay400Ms();
- TwoAlam();
- N=0;
- else
- for(j=0;j<16;j++)
- ThreeAlam(); //錯誤提示音
- pass=0;
- else //當(dāng)已經(jīng)開啟重置密碼功能時,而按下開鎖鍵,
- //DisplayListChar(0,1,Er_try);
- for(j=0;j<16;j++)
- write_1602dat(Er_try[j]);
- ThreeAlam();
- else
- for(j=0;j<16;j++)
- pass=0;
- N=0; //將輸入數(shù)據(jù)計數(shù)器清零,為下一次輸入作準(zhǔn)備
- operation=1;
- //==============================主函數(shù)===============================
- void main(void)
- unsigned char KEY,num;
- P1=0xF0;
- TMOD=0x11;
- TL0=0xB0;
- TH0=0x3C;
- EA=1;
- ET0=1;
- TR0=0;
- Delay400Ms(); //啟動等待,等LCM講入工作狀態(tài)
- lcd_init(); //LCD初始化
- write_1602com(yi);//日歷顯示固定符號從第一行第0個位置之后開始顯示
- for(i=0;i<16;i++)
- write_1602dat(name[i]);//向液晶屏寫日歷顯示的固定符號部分
- write_1602com(er);//時間顯示固定符號寫入位置,從第2個位置后開始顯示
- for(i=0;i<16;i++)
- write_1602dat(start_line[i]);//寫顯示時間固定符號,兩個冒號
- write_1602com(er+9); //設(shè)置光標(biāo)位置
- write_1602com(0x0f); //設(shè)置光標(biāo)為閃爍
- Delay5Ms(); //延時片刻(可不要)
- N=0; //初始化數(shù)據(jù)輸入位數(shù)
- while(1)
- if(key_disable==1)
- Alam_KeyUnable();
- else
- ALAM=1;
- num++;
- if(num>20)
- num=0;
- KEY=keynum();
- if(KEY!=0)
- second=0;
- else
密碼鎖.zip
(29.3 KB, 下載次數(shù): 141)
2020-11-13 23:21 上傳
點擊文件名下載附件
程序
密碼鎖。DSN.zip
(21.03 KB, 下載次數(shù): 113)
2020-11-13 23:21 上傳
點擊文件名下載附件
仿真
