STM32 SRAM 配置控制方法,簡(jiǎn)單易用的的- #include "sram.h"
- #include "usart.h"
- //使用NOR/SRAM的 Bank1.sector3,地址位HADDR[27,26]=10
- //對(duì)IS61LV25616/IS62WV25616,地址線范圍為A0~A17
- //對(duì)IS61LV51216/IS62WV51216,地址線范圍為A0~A18
- #define Bank1_SRAM3_ADDR ((u32)(0x68000000))
- #define Bank1_SRAM4_ADDR ((u32)(0x6C000000))
- //初始化外部SRAM
- void FSMC_SRAM_Init(void)
- FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure;
- FSMC_NORSRAMTimingInitTypeDef readWriteTiming;
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOE|RCC_APB2Periph_GPIOF|RCC_APB2Periph_GPIOG,ENABLE);
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC,ENABLE);
- GPIO_InitStructure.GPIO_Pin = 0xFF33; //PORTD復(fù)用推挽輸出
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //復(fù)用推挽輸出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = 0xFF83; //PORTE復(fù)用推挽輸出
- GPIO_Init(GPIOE, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = 0xF03F; //PORTD復(fù)用推挽輸出
- GPIO_Init(GPIOF, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = 0x043F; //PORTD復(fù)用推挽輸出
- GPIO_Init(GPIOG, &GPIO_InitStructure);
- readWriteTiming.FSMC_AddressSetupTime = 0x00; //地址建立時(shí)間(ADDSET)為1個(gè)HCLK 1/36M=27ns
- readWriteTiming.FSMC_AddressHoldTime = 0x00; //地址保持時(shí)間(ADDHLD)模式A未用到
- readWriteTiming.FSMC_DataSetupTime = 0x03; //數(shù)據(jù)保持時(shí)間(DATAST)為3個(gè)HCLK 4/72M=55ns(對(duì)EM的SRAM芯片)
- readWriteTiming.FSMC_BusTurnAroundDuration = 0x00;
- readWriteTiming.FSMC_CLKDivision = 0x00;
- readWriteTiming.FSMC_DataLatency = 0x00;
- readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_A; //模式A
- FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM3;// 這里我們使用NE3 ,也就對(duì)應(yīng)BTCR[4],[5]。
- FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
- FSMC_NORSRAMInitStructure.FSMC_MemoryType =FSMC_MemoryType_SRAM;// FSMC_MemoryType_SRAM; //SRAM
- FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;//存儲(chǔ)器數(shù)據(jù)寬度為16bit
- FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode =FSMC_BurstAccessMode_Disable;// FSMC_BurstAccessMode_Disable;
- FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
- FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait=FSMC_AsynchronousWait_Disable;
- FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
- FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
- FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable; //存儲(chǔ)器寫使能
- FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
- FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable; // 讀寫使用相同的時(shí)序
- FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
- FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming;
- FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &readWriteTiming; //讀寫同樣時(shí)序
- FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure); //初始化FSMC配置
- FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM3, ENABLE); // 使能BANK3
- //在指定地址開始,連續(xù)寫入n個(gè)字節(jié).
- //pBuffer:字節(jié)指針
- //WriteAddr:要寫入的地址
- //n:要寫入的字節(jié)數(shù)
- void FSMC_SRAM_WriteBuffer(u8* pBuffer,u32 WriteAddr,u32 n) ///void FSMC_SRAM_WriteBuffer(u16* pBuffer,u32 WriteAddr,u32 n)
- for(;n!=0;n--)
- *(vu8*)(Bank1_SRAM3_ADDR+WriteAddr)=*pBuffer; // *(vu16*)(Bank1_SRAM3_ADDR+WriteAddr)=*pBuffer;
- WriteAddr+=1;//這里需要加2,是因?yàn)镾TM32的FSMC地址右移一位對(duì)其.加2相當(dāng)于加1.
- pBuffer++;
- //在指定地址開始,連續(xù)讀出n個(gè)字節(jié).
- //ReadAddr:要讀出的起始地址
- void FSMC_SRAM_ReadBuffer(u8* pBuffer,u32 ReadAddr,u32 n) ///void FSMC_SRAM_ReadBuffer(u16* pBuffer,u32 ReadAddr,u32 n)
- for(;n!=0;n--)
- *pBuffer++=*(vu8*)(Bank1_SRAM3_ADDR+ReadAddr); // *pBuffer++=*(vu16*)(Bank1_SRAM3_ADDR+ReadAddr);
- ReadAddr+=1;//這里需要加2,是因?yàn)镾TM32的FSMC地址右移一位對(duì)其.加2相當(dāng)于加1.
- //測(cè)試函數(shù)
- //在指定地址寫入1個(gè)字節(jié)
- //addr:地址
- //data:要寫入的數(shù)據(jù)
- void fsmc_sram_test_write(u8 *data,u32 addr)//void fsmc_sram_test_write(u16 data,u32 addr)
- FSMC_SRAM_WriteBuffer(data,addr,250);//寫入1個(gè)字節(jié)
- //讀取1個(gè)字節(jié)
- //addr:要讀取的地址
- //返回值:讀取到的數(shù)據(jù)
- u8 fsmc_sram_test_read(u32 addr) //u16 fsmc_sram_test_read(u32 addr)
- u8 data; //u16 data;
- FSMC_SRAM_ReadBuffer(&data,addr,1);
- return data;
- void FSMC_FPGA_Init(void)
- GPIO_InitStructure.GPIO_Pin = 0x143F; //PORTD復(fù)用推挽輸出
- readWriteTiming.FSMC_AddressSetupTime = 0x0f; //地址建立時(shí)間(ADDSET)為1個(gè)HCLK 1/36M=27ns
- readWriteTiming.FSMC_AddressHoldTime = 0x0f; //地址保持時(shí)間(ADDHLD)模式A未用到
- readWriteTiming.FSMC_DataSetupTime = 0xff; //數(shù)據(jù)保持時(shí)間(DATAST)為3個(gè)HCLK 4/72M=55ns(對(duì)EM的SRAM芯片) //0x03;
- FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM4;// 這里我們使用NE3 ,也就對(duì)應(yīng)BTCR[4],[5]。
- FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_8b;//存儲(chǔ)器數(shù)據(jù)寬度為16bit
- FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM4, ENABLE); // 使能BANK3
- void FSMC_FPGA_WriteBuffer(u8* pBuffer,u32 WriteAddr,u32 n) ///void FSMC_SRAM_WriteBuffer(u16* pBuffer,u32 WriteAddr,u32 n)
- for(;n!=0;n--)
- *(vu8*)(Bank1_SRAM4_ADDR+WriteAddr)=*pBuffer; // *(vu16*)(Bank1_SRAM3_ADDR+WriteAddr)=*pBuffer;
- pBuffer++;
- void FSMC_FPGA_ReadBuffer(u8* pBuffer,u32 ReadAddr,u32 n) ///void FSMC_SRAM_ReadBuffer(u16* pBuffer,u32 ReadAddr,u32 n)
- for(;n!=0;n--)
- *pBuffer++=*(vu8*)(Bank1_SRAM4_ADDR+ReadAddr); // *pBuffer++=*(vu16*)(Bank1_SRAM3_ADDR+ReadAddr);
- //測(cè)試函數(shù)
- //addr:地址
- void fsmc_fpga_test_write(u8 data,u32 addr)//void fsmc_sram_test_write(u16 data,u32 addr)
- FSMC_FPGA_WriteBuffer(&data,addr,1);//寫入1個(gè)字節(jié)
- //讀取1個(gè)字節(jié)
- //addr:要讀取的地址
- u8 fsmc_fpga_test_read(u32 addr) //u16 fsmc_sram_test_read(u32 addr)
- FSMC_FPGA_ReadBuffer(&data,addr,1);
- return data;
