查看: 4076|回復(fù): 0
5G NR FR1 and FR2頻段
ID:844494 發(fā)表于 2020-11-16 17:24 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
Table 5.2-1: NR operating bands in FR1
NR operating band
Uplink (UL) operating band
BS receive / UE transmit
FUL_low   –  FUL_high
Downlink (DL) operating band
BS transmit / UE receive
FDL_low   –  FDL_high
Duplex Mode
n1
1920 MHz – 1980 MHz
2110 MHz – 2170 MHz
FDD
n2
1850 MHz – 1910 MHz
1930 MHz – 1990 MHz
FDD
n3
1710 MHz – 1785 MHz
1805 MHz – 1880 MHz
FDD
n5
824 MHz – 849 MHz
869 MHz – 894 MHz
FDD
n7
2500 MHz – 2570 MHz
2620 MHz – 2690 MHz
FDD
n8
880 MHz – 915 MHz
925 MHz – 960 MHz
FDD
n12
699 MHz – 716 MHz
729 MHz – 746 MHz
FDD
n14
788 MHz – 798 MHz
758 MHz – 768 MHz
FDD
n18
815 MHz – 830 MHz
860 MHz – 875 MHz
FDD
n20
832 MHz – 862 MHz
791 MHz – 821 MHz
FDD
n25
1850 MHz – 1915 MHz
1930 MHz – 1995 MHz
FDD
n28
703 MHz – 748 MHz
758 MHz – 803 MHz
FDD
n303
2305 Mhz – 2315 MHz
2350 MHz – 2360 MHz
FDD
n34
2010 MHz – 2025 MHz
2010 MHz – 2025 MHz
TDD
n38
2570 MHz – 2620 MHz
2570 MHz – 2620 MHz
TDD
n39
1880 MHz – 1920 MHz
1880 MHz – 1920 MHz
TDD
n40
2300 MHz – 2400 MHz
2300 MHz – 2400 MHz
TDD
n41
2496 MHz – 2690 MHz
2496 MHz – 2690 MHz
TDD
n48
3550 MHz – 3700 MHz
3550 MHz – 3700 MHz
TDD
n50
1432 MHz – 1517 MHz
1432 MHz – 1517 MHz
TDD1
n51
1427 MHz – 1432 MHz
1427 MHz – 1432 MHz
TDD
n65
1920 MHz – 2010 MHz
2110 MHz – 2200 MHz
FDD4
n66
1710 MHz – 1780 MHz
2110 MHz – 2200 MHz
FDD
n70
1695 MHz – 1710 MHz
1995 MHz – 2020 MHz
FDD
n71
663 MHz – 698 MHz
617 MHz – 652 MHz
FDD
n74
1427 MHz – 1470 MHz
1475 MHz – 1518 MHz
FDD
n75
N/A
1432 MHz – 1517 MHz
SDL
n76
N/A
1427 MHz – 1432 MHz
SDL
n77
3300 MHz – 4200 MHz
3300 MHz – 4200 MHz
TDD
n78
3300 MHz – 3800 MHz
3300 MHz – 3800 MHz
TDD
n79
4400 MHz – 5000 MHz
4400 MHz – 5000 MHz
TDD
n80
1710 MHz – 1785 MHz
N/A
SUL
n81
880 MHz – 915 MHz
N/A
SUL
n82
832 MHz – 862 MHz
N/A
SUL
n83
703 MHz – 748 MHz
N/A
SUL
n84
1920 MHz – 1980 MHz
N/A
SUL
n86
1710 MHz – 1780 MHz
N/A
SUL
[n90]
2496 MHz – 2690 MHz
2496 MHz – 2690 MHz
TDD5
NOTE 1:        UE that complies with the NR Band n50 minimum requirements in this specification         shall also comply with the NR Band n51 minimum requirements.
NOTE 2:        UE that complies with the NR Band n75 minimum requirements in this specification         shall also comply with the NR Band n76 minimum requirements.
NOTE 3:        Uplink transmission is not allowed at this band for UE with external vehicle-mounted antennas.
NOTE 4:        A UE that complies with the NR Band n65 minimum requirements in this specification shall also comply with the NR Band n1 minimum requirements.
NOTE 5:        Unless otherwise stated, the applicability of requirements for Band [n90] is in accordance with that for Band n41; a UE supporting Band [n90] shall meet the requirements for Band n41.
NR is designed to operate in the FR2 operating bands defined in Table 5.2-1.
Table 5.2-1: NR operating bands in FR2
Operating Band
BS receive
UE transmit
BS transmit
UE receive
Duplex Mode
FUL_low   –   FUL_high
FDL_low   –   FDL_high
n257
26500 MHz
29500 MHz
26500 MHz
29500 MHz
TDD
n258
24250 MHz
27500 MHz
24250 MHz
27500 MHz
TDD
n260
37000 MHz
40000 MHz
37000 MHz
40000 MHz
TDD
n261
27500 MHz
28350 MHz
27500 MHz
28350 MHz
TDD
