材料清單:
1供電:12V航模電池,12V~5V轉(zhuǎn)電壓模塊,開關(guān)*1
2控制:STM32C8T6最小系統(tǒng)板,紅外避障模塊*2
3驅(qū)動(dòng):L298N驅(qū)動(dòng)模塊*2
4對(duì)象:電機(jī)*4的小車
注:紅色部分不可缺。
放實(shí)物圖
32避障小車實(shí)物圖
線路連接圖
線路原理圖
(避障模塊沒有放進(jìn)去因?yàn)槭堑碗娖接|發(fā),兩個(gè)避障模塊接B0,B1口)
STM32單片機(jī)源程序文件:
- #include "ALLhander.h"
- int main(void)
- LED_Config();
- Motor_enable_Init();
- Motor_PWM_control_GPIO_Config();
- Tim3_mode_Config(T_Period,T_PSC,200);
- Total_NVIC_interrupt_config();
- Obstacle_avoidance();
- while(1)
- straight();
- Systick_Delay_ms(1000);
復(fù)制代碼 L298N配置文件
- #include "L298N_GPIO.h"
- #include "systick.h"
- void LED_Config(void)
- GPIO_InitTypeDef GPIO_InitStruct;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);
- //LED指示燈
- GPIO_InitStruct.GPIO_Pin = GPIO_Pin_13;
- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOC, &GPIO_InitStruct);
- void Front_Motor_enzble_control(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
- GPIO_InitStructure.GPIO_Pin = Motor1_cw_Pin|Motor1_ccw_Pin|Motor2_cw_Pin|Motor2_ccw_Pin;
- GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA,&GPIO_InitStructure);
- void Back_Motor_enzble_control(void)
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
- GPIO_InitStructure.GPIO_Pin = Motor3_cw_Pin|Motor3_ccw_Pin|Motor4_cw_Pin|Motor4_ccw_Pin;
- GPIO_Init(GPIOB,&GPIO_InitStructure);
- void Motor_enable_Init(void)
- Front_Motor_enzble_control();
- Back_Motor_enzble_control();
- void Motor_PWM_control_GPIO_Config(void)
- //RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
- //GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3, ENABLE);
- GPIO_InitStructure.GPIO_Pin = Speed_control_Pin;
- GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AF_PP;
- GPIO_Init(Speed_control_Port,&GPIO_InitStructure);
- void Tim3_mode_Config(uint16_t period,uint16_t Prescaler,uint16_t Pulse)
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_OCInitTypeDef TIM_OCInitStructure;
- //開啟定時(shí)器3的時(shí)鐘
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
- //TIM3重映射
- GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3, ENABLE);
- // 自動(dòng)重裝載寄存器的值,累計(jì)TIM_Period+1個(gè)頻率后產(chǎn)生一個(gè)更新或者中斷
- TIM_TimeBaseStructure.TIM_Period = period;
- // 驅(qū)動(dòng)CNT計(jì)數(shù)器的時(shí)鐘 = Fck_int/(psc+1)
- TIM_TimeBaseStructure.TIM_Prescaler = Prescaler;
- //時(shí)鐘分割
- TIM_TimeBaseStructure.TIM_ClockDivision = 0;
- // // 時(shí)鐘分頻因子 ,配置死區(qū)時(shí)間時(shí)需要用到
- // TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
- // 計(jì)數(shù)器計(jì)數(shù)模式,設(shè)置為向上計(jì)數(shù)
- TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;
- // 重復(fù)計(jì)數(shù)器的值,沒用到不用管
- //TIM_TimeBaseStructure.TIM_RepetitionCounter=0;
- // 初始化定時(shí)器
- TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
- // 配置為PWM模式1
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
- // 輸出使能
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
- // 互補(bǔ)輸出使能
- //TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
- // 設(shè)置脈沖寬度 CRR的值,0-65535
- TIM_OCInitStructure.TIM_Pulse = Pulse;
- // 輸出通道電平極性配置
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
- // 互補(bǔ)輸出通道電平極性配置
- //TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
- // 輸出通道空閑電平極性配置
- //TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
- // 互補(bǔ)輸出通道空閑電平極性配置
- //TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset;
- // TIM_OC1Init(TIM3, &TIM_OCInitStructure);
- // TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable);
- TIM_OC1Init(TIM3, &TIM_OCInitStructure);
- TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
- // TIM_OC3Init(TIM2, &TIM_OCInitStructure);
- // TIM_OC3PreloadConfig(TIM2, TIM_OCPreload_Enable);
- // TIM_OC4Init(TIM2, &TIM_OCInitStructure);
- // TIM_OC4PreloadConfig(TIM2, TIM_OCPreload_Enable);
- TIM_Cmd(TIM3, ENABLE);
- // 主輸出使能,當(dāng)使用的是通用定時(shí)器時(shí),這句不需要
- //TIM_CtrlPWMOutputs(ADVANCE_TIM, ENABLE);
- //電機(jī)1
- void Motor1_CW(void)
- GPIO_ResetBits(GPIOA,Motor1_ccw_Pin);
- GPIO_SetBits(GPIOA,Motor1_cw_Pin);
- void Motor1_CCW(void)
- GPIO_ResetBits(GPIOA,Motor1_cw_Pin);
- GPIO_SetBits(GPIOA,Motor1_ccw_Pin);
- //電機(jī)2
- void Motor2_CW(void)
- GPIO_ResetBits(GPIOA,Motor2_ccw_Pin);
- GPIO_SetBits(GPIOA,Motor2_cw_Pin);
- void Motor2_CCW(void)
- GPIO_ResetBits(GPIOA,Motor2_cw_Pin);
- GPIO_SetBits(GPIOA,Motor2_ccw_Pin);
- //電機(jī)3
- void Motor3_CW(void)
- GPIO_ResetBits(GPIOB,Motor3_ccw_Pin);
- GPIO_SetBits(GPIOB,Motor3_cw_Pin);
- void Motor3_CCW(void)
- GPIO_ResetBits(GPIOB,Motor3_cw_Pin);
- GPIO_SetBits(GPIOB,Motor3_ccw_Pin);
- //電機(jī)4
- void Motor4_CW(void)
- GPIO_ResetBits(GPIOB,Motor4_ccw_Pin);
- GPIO_SetBits(GPIOB,Motor4_cw_Pin);
- void Motor4_CCW(void)
- GPIO_ResetBits(GPIOB,Motor4_cw_Pin);
- GPIO_SetBits(GPIOB,Motor4_ccw_Pin);
- void straight(void)
- Motor1_CW();
- Motor2_CW();
- Motor3_CW();
- Motor4_CW();
- void Turn_left(void)
- Motor1_CCW();
- Motor2_CW();
- Motor3_CCW();
- Motor4_CW();
- void Turn_left_move(void)
- Motor1_CCW();
- Motor2_CW();
- Motor3_CW();
- Motor4_CCW();
- void Turn_right(void)
- Motor1_CW();
- Motor2_CCW();
- Motor3_CW();
- Motor4_CCW();
- void Turn_right_move(void)
- Motor1_CW();
- Motor2_CCW();
- Motor3_CCW();
- Motor4_CW();
- void Back(void)
- Motor1_CCW();
- Motor2_CCW();
- Motor3_CCW();
- Motor4_CCW();
- void Stop_motor1(void)
- void Stop_motor2(void)
- void Stop_motor3(void)
- Systick_Delay_ms(300);
- void Stop_motor4(void)
復(fù)制代碼 中斷服務(wù)函數(shù)
- void Left_spinner_IRQHandler(void)
- if(EXTI_GetITStatus(EXTI_Line1) !=RESET)
- Back();
- Turn_right();
- Systick_Delay_ms(200);
- straight();
- EXTI_ClearITPendingBit(EXTI_Line1);
- void right_spinner_IRQHandler(void)
- if(EXTI_GetITStatus(EXTI_Line0) !=RESET)
- Back();
- Turn_left();
- straight();
- EXTI_ClearITPendingBit(EXTI_Line0);
復(fù)制代碼 帖主的水平可能并沒有那么高,但是我愿與大家共同分享,一起進(jìn)步,歡迎吐槽打擾
下面包含所有文件:
基于STM32的雙路避障小車仿真圖源程序.7z
(328.65 KB, 下載次數(shù): 151)
2020-11-18 05:03 上傳
點(diǎn)擊文件名下載附件
