這個程序是實現(xiàn)泥頭車遠(yuǎn)程智能管理,遠(yuǎn)程平臺可以實時對車輛進行監(jiān)控。車載智能設(shè)備每隔3秒鐘就給平臺發(fā)送車輛位置,油剩余量,車速,揚塵量數(shù)據(jù)發(fā)送到平臺。
單片機源程序如下:
- #include "eeprom.h"
- #include "bianma.h"
- #include <reg52.h>
- #include <intrins.h>
- sbit AM=P3^2;
- sbit BM=P3^3;
- sbit k=P3^7;
- sbit s=P3^6;
- extern uint temp,temp2;
- extern uint AR,BR;
- extern uint date;
- extern uchar kc;
- extern uint AT,BT;
- uchar num_a=0;
- uchar num_b=0;
- uint dateA, dateB,numB;
- uchar cofig,key,a=0;
- uchar ok,u;
- uchar i,r;
- uint Compare[5]={0,0,0,0,0};
- uint Compare1[5]={0,0,0,0,0};
- void waiint()
- EX0=1;
- IT0=0;
- EA=1;
- void delayss(UINT16 z)
- UINT16 x,y;
- for(x=z;x>0;x--)
- for(y=120;y>0;y--);
- void main()
- waiint();
- intt();
- num_a=EEPROMReadByte(1);delayss(60);
- num_b=EEPROMReadByte(2);delayss(60);
- //date=num_a+(254*num_b);
- SBUF=num_a;while(TI==0);TI=0;
- TR1=1;
- SBUF=num_b;while(TI==0);TI=0;
- delay(100);
- date=num_a;
- date=(date<<8)&0xff00;
- date=date|num_b;
- key=2;
- kc=0;
- dateA=0;
- while(1)
- if(s==0)
- delay(10);
- if(s==0)
- { AR=0;}}
- while(k==0)
- { TR0=1;
- while(k==0)
- ok=1;
- if(Compare1[0]==0xff&&Compare1[1]==0xff&&Compare1
- [2]==0xff&&Compare1[3]==0xff&&Compare1[4]==0xff)
- {r++;}
- else
- if(Compare1[0]==0x00&&Compare1[1]==0x00&&Compare1
- [2]==0x00&&Compare1[3]==0x00&&Compare1[4]==0x00)
- {r++;}
- else
- { Compare[4]=0x00;}
- if(r==5&&Compare[0]<Compare[4])
- {dateA=Compare[4];r=0;}
- // dateA=Compare[9];
- TR1=1;
- if(dateA!=0)
- SBUF=num_a=dateA>>8;
- while(TI==0);TI=0;TR1=1;
- SBUF=num_b=dateA&0XFF;
- while(TI==0);TI=0; }}
- TR0=0;
- delay(1);
- EA=0;
- EEPROMSectorErase(1);
- EEPROMWriteByte(1,num_a);
- EEPROMWriteByte(2,num_b);
- delay(1000); EA=1; }
- // mm: dateA=caiji();
- // if(dateA==0xff)
- // {goto mm;}
- {r++;}
- else
- {r++;}
- else
- if(key==10)//順時針轉(zhuǎn)cofig=1;(關(guān)閉 )
- if(dateA>20)
- { TR2=1;
- if(temp>=1000)
- temp=0;
- if(date<=(dateA+5))// 車蓬閉合良好
- { SBUF=0xd2;while(TI==0);TI=0;dateA=0;
- key=2;AT=BT=0;TF2=0;TR2=0;delay(1000);}
- else
- {SBUF=0xd1;while(TI==0);TI=0;TF2=0; delay(100);}
- if(key==2) //逆時針轉(zhuǎn)cofig=0;( 打開 )
- if((dateA>=30)&&(dateA<=300))//車蓬沒關(guān)好
- TR2=1;
- if(temp>1000)
- {SBUF=0xd1;while(TI==0);TI=0;temp=0;}
- if(dateA>350)
- {temp=0;TR2=0;}
- if(date<=(dateA+30)) //車篷全開
- temp=0;
- TR2=0;SBUF=0xd3;while(TI==0);
- TI=0;dateA=0;key=1;AT=BT=0;TF2=0;delay(10);}
- void teim(void) interrupt 0
- { uchar h,l;
- while(AM==0);
- if(ok==1)
- if(BM==1)
- {h++;if(h==5){dateA++;cofig=0xff;h=0;u++;}}//順時針
- else
- if(BM==0)
- {l++;if(l==5){dateA++;cofig=0x00;l=0;u++;}}//逆時針
- Compare[u]=dateA;
- Compare1[u]=cofig;
- if(u==5){u=0;}
- ok=0; }TR0=0;TR1=1;}
- void time4(void) interrupt 4
- {TR1=0;}
- void time0(void) interrupt 1
- TH0=(65536-5000)/256;
- TL0=(65536-5000)%256;
- temp++; temp2++;
- if (temp2>5000)
- {temp2=0;}
- if(temp>2000)
- {temp=0;}
