查看: 3921|回復(fù): 2
基于 CH32V103開(kāi)發(fā)板的彩色OLED屏顯示驅(qū)動(dòng)
ID:776997 發(fā)表于 2020-11-21 11:16 | 顯示全部樓層 |閱讀模式
OLED屏有多種類(lèi)型,其中的參數(shù)屏要比單色屏和雙色屏更具色彩表現(xiàn)力,在設(shè)計(jì)小游戲時(shí),彩色屏將是不錯(cuò)的下載,假如用單色屏來(lái)完成俄羅斯方塊的話,那就只剩下方塊了,相對(duì)來(lái)講彩色屏?xí)邇?yōu)勢(shì)。
目前來(lái)看,似乎還沒(méi)見(jiàn)到有I2C接口的彩色屏,因此就只有多犧牲幾個(gè)I/O口來(lái)驅(qū)動(dòng)彩色屏了!
在彩色屏與U CH32V103連接上,其關(guān)系如下:
CLK--PA2
DIN--PA3
RST--PB3
DC --PB4
CS --PB5
BLK--PB6
定義引腳輸出高低電平的語(yǔ)句為:
#define OLED_SCLK_Set()  GPIO_WriteBit(GPIOA, GPIO_Pin_2,Bit_SET)
#define OLED_SCLK_Clr()  GPIO_WriteBit(GPIOA, GPIO_Pin_2,Bit_RESET)
#define OLED_SDIN_Set()  GPIO_WriteBit(GPIOA, GPIO_Pin_3,Bit_SET)
#define OLED_SDIN_Clr()  GPIO_WriteBit(GPIOA, GPIO_Pin_3,Bit_RESET)
#define OLED_RST_Set()  GPIO_WriteBit(GPIOB, GPIO_Pin_3,Bit_SET)
#define OLED_RST_Clr()  GPIO_WriteBit(GPIOB, GPIO_Pin_3,Bit_RESET)
#define OLED_DC_Set()   GPIO_WriteBit(GPIOB, GPIO_Pin_4,Bit_SET)
#define OLED_DC_Clr()   GPIO_WriteBit(GPIOB, GPIO_Pin_4,Bit_RESET)
#define OLED_CS_Set()   GPIO_WriteBit(GPIOB, GPIO_Pin_5,Bit_SET)
#define OLED_CS_Clr()   GPIO_WriteBit(GPIOB, GPIO_Pin_5,Bit_RESET)
#define OLED_BLK_Set()  GPIO_WriteBit(GPIOB, GPIO_Pin_6,Bit_SET)
#define OLED_BLK_Clr()  GPIO_WriteBit(GPIOB, GPIO_Pin_6,Bit_RESET)
相關(guān)引腳輸出功能的配置函數(shù)為:
  1. void App_OledInit(void)
  2. {
  3. GPIO_InitTypeDef  GPIO_InitStructure;                //定義一個(gè)GPIO_InitTypeDef類(lèi)型的結(jié)構(gòu)體
  4. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);//使能與LED相關(guān)的GPIO端口時(shí)鐘
  5. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6; //配置GPIO引腳
  6. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;     //設(shè)置GPIO模式為推挽輸出
  7. GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;    //設(shè)置GPIO口輸出速度
  8. GPIO_Init(GPIOB, &GPIO_InitStructure);               //調(diào)用庫(kù)函數(shù),初始化GPIOA
  9. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);//使能與LED相關(guān)的GPIO端口時(shí)鐘
  10. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_3; //配置GPIO引腳
  11. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;     //設(shè)置GPIO模式為推挽輸出
  12. GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;    //設(shè)置GPIO口輸出速度
  13. GPIO_Init(GPIOA, &GPIO_InitStructure);               //調(diào)用庫(kù)函數(shù),初始化GPIOA
  14. GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_3);           //設(shè)置引腳輸出高電平
  15. }
圖片顯示的函數(shù)為:
  1. void LCD_ShowPicturea(u16 x1,u16 y1,u16 x2,u16 y2)
  2. {
  3. int i;
  4. LCD_Address_Set(x1,y1,x2,y2);
  5. for(i=0;i<12800;i++)
  6. {
  7. LCD_WR_DATA8(gImage_moled[i*2]);
  8. LCD_WR_DATA8(gImage_moled[i*2+1]);
  9. }
  10. }
實(shí)現(xiàn)顯示效果的主程序?yàn)椋?/div>
  1. int main(void)
  2. {
  3. u8 i=0;
  4. u8 j=0;
  5. Delay_Init();   //延時(shí)函數(shù)初始化
  6. LED_Init();     //LED初始化
  7. App_OledInit();
  8. OLED_Init();
  9. Delay_Ms(200);
  10. LCD_Clear(BLACK);
  11. BACK_COLOR=BLACK;
  12. LCD_ShowString(10,0,"CH32V103 TEST",RED);
  13. LCD_ShowString(10,20,"OLED Display",RED);
  14. LCD_ShowString(10,40,"jinglixixi",RED);
  15. LCD_ShowString(10,60,"2020.10.28",RED);
  16. Delay_Ms(2000);
  17. LCD_Clear(BLACK);
  18. LCD_ShowChinese(28,0,0,32,YELLOW);
  19. LCD_ShowChinese(60,0,1,32,YELLOW);
  20. LCD_ShowChinese(92,0,2,32,YELLOW);
  21. LCD_ShowChinese(20,40,0,16,YELLOW);
  22. LCD_ShowChinese(36,40,1,16,YELLOW);
  23. LCD_ShowChinese(52,40,2,16,YELLOW);
  24. LCD_ShowChinese(68,40,3,16,YELLOW);
  25. LCD_ShowChinese(84,40,4,16,YELLOW);
  26. LCD_ShowChinese(100,40,5,16,YELLOW);
  27. LCD_ShowChinese(116,40,6,16,YELLOW);
  28. LCD_ShowString(20,60,"0.96 TFT SPI",YELLOW);
  29. Delay_Ms(2000);
  30. LCD_Clear(BLACK);
  31. LCD_ShowString(10,0,"LCD_W:",RED);
  32. LCD_ShowNum(70,0,LCD_W,3,RED);
  33. LCD_ShowString(10,20,"LCD_H:",RED);
  34. LCD_ShowNum(70,20,LCD_H,2,RED);
  35. for(i=0;i<4;i++)
  36. {
  37. LCD_ShowPicture(i*40,40,39+i*40,79);
  38. }
  39. Delay_Ms(2000);
  40. LCD_ShowPicturea(0,0,159,79);
  41. }
經(jīng)編譯,程序?qū)ο到y(tǒng)資源的占用情況如圖1所示。
圖1
程序下載后的運(yùn)行效果見(jiàn)圖2~圖4所示。
圖2~圖4
若單顯示圖片,則系統(tǒng)資源資源情況為:
圖5
程序下載后面,其運(yùn)行效果如圖所示。
圖6
ID:647586 發(fā)表于 2021-3-8 10:10 | 顯示全部樓層
OLED怎么點(diǎn)亮
ID:297828 發(fā)表于 2021-12-5 21:54 | 顯示全部樓層
中景園的這個(gè)IIC的屏,實(shí)在是一言難盡
