Altium Designer畫(huà)的原理圖和PCB圖如下:(51hei附件中可下載工程文件)
2020-11-24 17:09 上傳
2020-11-24 17:09 上傳
2020-11-24 17:09 上傳
- #include<reg52.h> //包含頭文件
- #define uint unsigned int //宏定義
- #define uchar unsigned char
- sbit led1=P1^2; //定義led控制端口
- sbit led2=P1^3;
- sbit led3=P1^4;
- sbit led4=P1^5;
- sbit led5=P1^6;
- sbit led6=P1^7;
- sbit led7=P1^1;
- sbit led8=P1^0;
- sbit beef=P2^7; //定義蜂鳴器
- sbit ww1=P2^6; //電機(jī)控制端口
- sbit ww2=P2^5;
- sbit floor1=P3^0; //樓層控制按鍵
- sbit floor2=P3^1;
- sbit floor3=P3^2;
- sbit floor4=P3^3;
- sbit floor5=P3^7;
- sbit floor6=P3^6;
- sbit shang=P3^5; //上下模式控制按鍵
- sbit xia =P3^4;
- //全局變量控制端口
- uint num,miao,ceng=1,moshi=0,a[6],b[6],jishu=0,shangorxia=0;
- uint floor=1,cishu=0,c[6]={0,4,8,12,16,20},i=0; //floor樓層,cishu鍵盤(pán)按鍵按下次數(shù)
- uint time1,time2,time3,miaoshu=0;
- uint s1=0,s2=0,s3=0,s4=0,s5=0,s6=0;
- //數(shù)碼管顯示
- uchar code table[]={0xf9,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,
- 0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E};
- void xianshifloor(); //樓層顯示函數(shù)聲明
- ====================延時(shí)函數(shù)函數(shù)===========================
- void delay(uint xms) //簡(jiǎn)單延時(shí)
- uint o,j;
- for(o=xms;o>0;o--) for(j=110;j>0;j--);
- ====================蜂鳴器控制函數(shù)===========================
- void beefring() //蜂鳴器控制函數(shù)
- beef=1; delay(500); beef=0;
- =================電機(jī)控制各子函數(shù)===========================
- void up() //電機(jī)上
- ww1=1; ww2=1;
- void down() //電機(jī)下
- ww1=1; ww2=1;
- void stop() //電機(jī)停止
- ww1=0; ww2=0;
- ====================定時(shí)器0,1初始化函數(shù)=====================
- void initclock() //定時(shí)器0/1控制初始化函數(shù)
- TMOD=0x11; //定義定時(shí)器0/1為定時(shí)器模式
- TH0=(65536-50000)/256;//50ms初值
- TL0=(65536-50000)%256;
- ET0=1; //開(kāi)定時(shí)器
- TR0=1; //啟動(dòng)定時(shí)器T0
- TH1=(65536-50000)/256;//50ms初值
- TL1=(65536-50000)%256;
- ET1=1; //開(kāi)T1中斷
- TR1=1; //啟動(dòng)T1
- EA=1; //開(kāi)中斷
- num=0; miao=0; floor=0;
- ====================用于控制模式選擇函數(shù)===========================
- void moshitest() //用于確定是上行還是下行
- if(shang==0) //上行鍵按下
- delay(5); //延時(shí)消抖
- if(shang==0) //再判
- while(!shang);//等待釋放
- initclock(); //初始化定時(shí)器
- P0=0xfe;
- moshi=1; //上行標(biāo)志
- //xianshifloor();
- TH0=(65536-50000)/256; TL0=(65536-50000)%256;
- time1=0; time2=0;
- led7=0; delay(2500); led7=1;
- led8=0; delay(1000); led8=1;
- while(time2!=1); ////不到4秒
- TR1=1;
- miao=0; miaoshu=0;
- initclock();
- if(xia==0) //下行鍵按下
- delay(5);
- if(xia==0)
- while(!xia);
- initclock();
- moshi=2; //下行標(biāo)志
- initclock();
- P0=0xf7;
- //xianshifloor();
- time1=0; time2=0;
- while(time2!=1);//不到4秒
- TR1=1;
- initclock();
- ====================鍵盤(pán)檢測(cè)函數(shù)===========================
- 在此函數(shù)中根據(jù)檢測(cè)的先后順序使其哪個(gè)鍵盤(pán)按下的先后順序存在數(shù)組a【】中
- void keyscan() //判斷哪個(gè)按鍵按下放在數(shù)組a[]中
- if(floor1==0) //1層按鈕按下
- delay(2);
- if(floor1==0){while(!floor1);
- led1=0; //1層指示燈亮
- if(s1==0)
- if(moshi==2)
- if((6-floor)>1){a[i++]=1;cishu++;}
- s1=2;
- if(floor2==0) //2層按鈕按下
- delay(2);
- if(floor2==0){ while(!floor2);
- led2=0; //2層指示燈亮
- if(s2==0)
- if(moshi==1)
- if(floor<2){a[i++]=2; cishu++; }
- if(moshi==2)
- if((6-floor)>2){a[i++]=2;cishu++;}
- s2=2;
- if(floor3==0)//3層按鈕按下
- delay(2);
- if(floor3==0){while(!floor3);
- led3=0; //3層指示燈亮
- if(s3==0)
- if(moshi==1)
- if(floor<3){a[i++]=3;cishu++;}
- if(moshi==2)
- if((6-floor)>3){a[i++]=3;cishu++;}
- s3=2;
- if(floor4==0)//4層按鈕按下
- delay(2);
- if(floor4==0){while(!floor4);
- led4=0; //4層指示燈亮
- if(s4==0)
- if(moshi==1)
- if(floor<4){a[i++]=4;cishu++;}
- if(moshi==2)
- if((6-floor)>4){a[i++]=4;cishu++;}
- s4=2;
- if(floor5==0)//5層按鈕按下
- delay(2);
- if(floor5==0){while(!floor5);
- led5=0; //5層指示燈亮
- if(s5==0)
- if(moshi==1)
- if(floor<5){a[i++]=5;cishu++;}
- if(moshi==2)
- if((6-floor)>5){a[i++]=5; cishu++;}
- s5=2;
- if(floor6==0)//6層按鈕按下
- delay(2);
- if(floor6==0){while(!floor6);
- led6=0; //6層指示燈亮
- if(s6==0)
- if(moshi==1)
- if(floor<6){a[i++]=6;cishu++;}
- /* if(moshi==2)
- if(6-floor>5)
- a[i++]=6;
- cishu++;
- s6=2;
- ====================對(duì)a[]函數(shù)進(jìn)行排序======================
- void paixu()
- uint u,k,p,m;
- if(moshi==1) //上行
- a:
- keyscan();
- up();
- for(u=0;u<cishu;u++) //使用冒泡法進(jìn)行排序
- if(floor1==0||floor2==0||floor3==0||floor4==0||floor5==0||floor6==0)
- goto a;
- up();
- // P0=table[a[u]];
- // delay(500);
- for(k=u;k<cishu;k++)
- if(a[u]>a[k])
- p=a[u];
- a[u]=a[k];
- a[k]=p;
- up();
- //P0=table[a[u]];
- // delay(500);
- { goto a;
- up();
- for(m=0;m<cishu;m++)
- up(); //上行
- if((a[m]*4)==miaoshu)
- // P0=table[a[m]];
- // delay(500);
- stop();
- goto a;
- xianshifloor(); //顯示樓層
- TR1=0;
- beefring(); //蜂鳴器響
- time1=0; time2=0;
- led8=0; delay(1500); led8=1;
- if(a[m]==1) { led1=1; }
- if(a[m]==2) { led2=1; }
- if(a[m]==3) { led3=1; }
- if(a[m]==4) { led4=1; }
- if(a[m]==5) { led5=1; }
- if(a[m]==6) { led6=1; }
- TR1=1;
- up(); //上行
- delay(1500);
- up();
- if(floor==6)
- led7=0; //下行燈亮
- stop(); //電機(jī)停轉(zhuǎn)
- while(1){ xianshifloor(); } //顯示樓層
- if(moshi==2)//下行
- b:
- keyscan(); //鍵掃描
- down(); //下行
- goto b;
- down();
- if(a[u]<a[k])
- p=a[u];
- a[u]=a[k];
- a[k]=p;
- down();
- goto b;
- down();//下行
- down();
- if((a[m]*4)==(24-miaoshu))
- goto b;down();
- down(); //下行
- stop(); //停轉(zhuǎn)
- xianshifloor();//顯示樓層
- TR1=0; beefring();
- time1=0; time2=0;
- if(a[m]==1){led1=1; } //到1層,指示燈滅
- if(a[m]==2){led2=1; } //到2層,指示燈滅
- if(a[m]==3){led3=1; } //到3層,指示燈滅
- if(a[m]==4){led4=1;} //到4層,指示燈滅
- if(a[m]==5){led5=1; } //到5層,指示燈滅
- if(a[m]==6){led6=1; } //到6層,指示燈滅
- while(time2!=1); //不到4秒
- down(); //下行
- delay(1300);//延時(shí)
- if(floor==6)
- led7=0; //下行燈亮
- ===========================顯示樓層函數(shù)=======================
- if(moshi==1){ P0=table[floor]; delay(5); } //顯示上行樓層
- if(moshi==2){P0=table[6-floor]; delay(5); } //顯示下行樓層
- =============================主函數(shù)=================================
- void main()
- P1=0xff; //所有樓層指示燈滅
- P2=0x00;
- P0=0x00; //數(shù)碼管全顯示
- while(1)
- moshitest();//模式測(cè)試
- keyscan(); //按鍵掃描
- paixu(); //排序
51電梯控制器.zip
(1.11 MB, 下載次數(shù): 58)
2020-11-24 09:10 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
