查看: 3849|回復(fù): 3
STC15F2K60S2單片機(jī)8x8x8光立方原理圖程序,元件清單
ID:674815 發(fā)表于 2020-11-28 10:32 | 顯示全部樓層 |閱讀模式
電路原理圖如下:
元件清單:
名稱    數(shù)量    規(guī)格/型號(hào)    備注
萬(wàn)能板    3    18*30cm
單片機(jī)STC15F2K60S2    1    DIP40    除非你會(huì)改程序,否則請(qǐng)勿擅自更換
74hc154    4        寬窄兩種封裝均可
40P  IC座    1
24P  IC座    4
電解電容47uF    1
104電容    1
撥動(dòng)開關(guān)    1
銅柱(含螺母)    4    M3*100mm
燈珠    540    2*5*7mm霧狀    顏色自選
彎排針    1    每組40P
直排針    8    每組40P
白色飛線    2    若干
USB轉(zhuǎn)TTL下載器    1        PL2303系列或CH340系列
母對(duì)母杜邦線    3    每組40P
母對(duì)公杜邦線    1    每組40P
微動(dòng)開關(guān)    1
  1. /*作者:風(fēng)鈴  */
  2. #include"STC15F2K60S2.h"
  3. #include"intrins.h"
  4. #include"basic.h"
  5. #define SET  0x00
  6. #define CLR  0x00
  7. #define Segs  P0
  8. #define Out   P1
  9. sbit Rest=P3^0;
  10. void IO_int();
  11. void Timer1Init(void);
  12. Byte code table[]={
  13. 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  14. 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  15. 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  16. 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  17. 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  18. 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  19. 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  20. 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  21. };
  22. Byte code Segs_tab[]={
  23. 0xe0,0xe1,0xe2,0xe3,0xe4,0xe5,0xe6,0xe7,0xe8,0xe9,0xea,0xeb,0xec,0xed,0xee,0xef,
  24. 0xd0,0xd1,0xd2,0xd3,0xd4,0xd5,0xd6,0xd7,0xd8,0xd9,0xda,0xdb,0xdc,0xdd,0xde,0xdf,
  25. 0xb0,0xb1,0xb2,0xb3,0xb4,0xb5,0xb6,0xb7,0xb8,0xb9,0xba,0xbb,0xbc,0xbd,0xbe,0xbf,
  26. 0x70,0x71,0x72,0x73,0x74,0x75,0x76,0x77,0x78,0x79,0x7a,0x7b,0x7c,0x7d,0x7e,0x7f,
  27. };
  28. void Timer0Init(void);
  29. unsigned char  Anm1=0;
  30. unsigned int End,Anm=0;
  31. void main()
  32. {
  33.         EA=1;
  34.         End=sizeof(table);
  35.         IO_int();
  36.         Timer0Init();
  37.   while(1)
  38.   {
  39.    if(Rest==0)IAP_CONTR=0x60;
  40.    if(Anm>End)Anm=0;
  41.
  42.         Segs=Segs_tab[Anm1];
  43.         Out=table[Anm1+Anm];
  44.   }
  45. }
  46. void IO_int()
  47. {
  48.         P0M1=0x00;
  49.         P0M0=0x00;
  50.         P1M1=0x00;
  51.         P1M0=0xff;
  52. }
  53. void Timer0Init(void)                //100微秒@22.1184MHz
  54. {
  55.         AUXR |= 0x80;                //定時(shí)器時(shí)鐘1T模式
  56.         TMOD &= 0xF0;                //設(shè)置定時(shí)器模式
  57.         TL0 = 0x5C;                //設(shè)置定時(shí)初值
  58.         TH0 = 0xF7;                //設(shè)置定時(shí)初值
  59.         TF0 = 0;                //清除TF0標(biāo)志
  60.         ET0=1;
  61.         TR0 = 1;                //定時(shí)器0開始計(jì)時(shí)
  62. }
  63. void delay() interrupt 1
  64. {
  65.         TR0=0;
  66.           Anm1=Anm1+1;
  67.           if(Anm1>63)Anm1=0;
  68.           Out=CLR;
  69.           Segs=0xff;
  70.         TR0=1;
  71. }
8x8x8光立方.7z (315.52 KB, 下載次數(shù): 38)
ID:230742 發(fā)表于 2020-11-28 23:50 | 顯示全部樓層
沙發(fā)。不容易啊。感謝分享。正想做一個(gè)呢。太感謝了。
ID:674815 發(fā)表于 2023-6-7 19:02 | 顯示全部樓層
啤酒瓶子老大 發(fā)表于 2020-11-28 23:50
不客氣
ID:1112819 發(fā)表于 2024-3-12 20:50 | 顯示全部樓層
博主博主,我之前有搜索過(guò)STC15f2k60s2單片機(jī)的引腳圖,是個(gè)正方形,有44個(gè)口子,每側(cè)11個(gè),為什么這個(gè)原理圖和那個(gè)不一樣呢?急需回復(fù),感謝博主!。
