2020-12-6 22:22 上傳
2020-12-6 22:23 上傳
1、下行控制報站:首先按下(下行設置按鍵),(下行指示燈)亮,然后按下(手動播報)按鍵控制播報下一站
2、上行控制報站:首先按上(上行設置按鍵),(上行指示燈)亮,然后按下(手動播報)按鍵控制播報下一站
3、按下關閉播報按鍵,則關閉播報功能和清除顯示
單片機源程序如下:
#include <reg51.h>
#include "value.h"
sbit x_key=P1^3;
sbit s_key=P1^4;
sbit bz_key=P1^5;
sbit gb_key=P1^6;
sbit x_LED=P2^6;
sbit s_LED=P2^7;
uchar x_mode,s_mode;
uchar x_num,s_num;
bit flag_200ms = 1;
uchar flag_c_en;
bit flag_100ms;
sbit dq=P3^2; //18b20 IO口的定義
uint temperature ; //溫度變量
/************ 延時函數(shù) *****************/
void delay_uint(uint z)
while(z--);
* 名稱 : delay_1ms()
* 功能 : 延時1ms函數(shù)
* 輸入 : q
* 輸出 : 無
void delay_1ms(uint q)
uint i,j;
for(i=0;i<q;i++)
for(j=0;j<115;j++);
uchar dis_lcd[10];
#include "lcd12864bu.h"
/******************顯示時間函數(shù)***************************/
void dis_shijian() //顯示時間
write_shu16(0,0*8,shi,0);
write_shuzi(1,0*2,2*8,fuhao[1],0);
write_shu16(0,3*8,fen,0);
write_shuzi(1,0*2,5*8,fuhao[1],0);
write_shu16(0,6*8,miao,0);
write_yhanzi(2,0,5*16,qita[6]); //星期
//write_shu16(0,14*8,week,0);
if(week==0)
write_yhanzi(1,0,7*16,xingqi[6]);
if(week==1)
write_yhanzi(1,0,7*16,xingqi[1]);
if(week==2)
write_yhanzi(1,0,7*16,xingqi[2]);
if(week==3)
write_yhanzi(1,0,7*16,xingqi[3]);
if(week==4)
write_yhanzi(1,0,7*16,xingqi[4]);
if(week==5)
write_yhanzi(1,0,7*16,xingqi[5]);
if(week==6)
write_shu16(1*2,0*8,0x20,0);
write_shu16(1*2,2*8,nian,0);
write_shuzi(1,1*2,4*8,fuhao[0],0);
write_shu16(1*2,5*8,yue,0);
write_shuzi(1,1*2,7*8,fuhao[0],0);
write_shu16(1*2,8*8,ri,0);
write_shu18b20(1*2,12*8,temperature,0);
write_shuzi(1,1*2,14*8,dian,0);
/************初始化顯示*****************/
void init_12864_dis() //初始化顯示
cs1=1; //左屏開顯示
cs2=0;
dis_shijian(); //顯示時間
全部資料51hei下載地址:
公交站播報.zip
(190.49 KB, 下載次數(shù): 156)
2020-12-6 13:23 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
