查看: 1369|回復(fù): 0
基于51單片機(jī)的三角波信號發(fā)生器
ID:857562 發(fā)表于 2020-12-9 17:16 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
  1. #include<reg51.h>
  2. #include<absacc.h>
  3. #define DAC0832 XBYTE[0x7fff]
  4. sbit a=P3^0;
  5. sbit b=P3^1;
  6. sbit c=P3^2;
  7. sbit e=P3^3;
  8. unsigned char code juxing[64]={255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
  9.        255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
  10.        0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
  11.        };
  12. unsigned char code sanjiao[64]={0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,144,152,160,168,176,184,192,200,208,216,224,232,240,248,
  13.        248,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0,};
  14. void delay(unsigned int x)
  15. {
  16.         unsigned char i;
  17.         while(x--)
  18.         for(i=0;i<=140;i++);
  19. }
  20. void square(void)
  21. {
  22.         unsigned char i;
  23.         for(i=0;i<64;i++)
  24.         DAC0832=juxing[i];
  25. }
  26. void sanjiaobo()
  27. {
  28.         unsigned char i;
  29.         for(i=0;i<64;i++)
  30.         {
  31.         DAC0832=sanjiao[i];
  32.         }
  33. }
  34. void juchibo()
  35. {
  36.         int i;
  37.         unsigned char code sin[64]={135,145,158,167,176,188,199,209,218,226,234,240,245,249,252,254,
  38.        254,253,251,247,243,237,230,222,213,204,193,182,170,158,146,133,
  39.        121,108,96,84,72,61,50,41,32,24,17,11,7,3,1,0,0,2,5,9,14,20,28,
  40.        36,45,55,66,78,90,102,114,128
  41.                                     };
  42.         for(i=0;i<64;i++)
  43.         {
  44.                 DAC0832=sin[i];
  45.         }
  46. }
  47. void main(void)
  48. {
  49.         e=0;
  50.         while(1)
  51.         {
  52.                 switch(P1)
  53.                 {
  54.                         case 0xfe:
  55.        delay(10);
  56.        while(P1==0XFF)
  57.        {square();}break;
  58.                         case 0xfd:
  59.                                         delay(10);
  60.        while(P1==0XFF)
  61.        {sanjiaobo();} break;
  62.                         case 0xfb:
  63.                                         delay(10);
  64.        while(P1==0XFF)
  65.                                                           {juchibo();}break;
  66.                         default:break;
  67.                 }
  68.         }
  69. }
上個月課上做的實(shí)驗(yàn),想來分享一下
SY5.zip
26.06 KB, 下載次數(shù): 5, 下載積分: 黑幣 -5
