我在網(wǎng)上找的這個(gè)程序,但是不會(huì)改
#include<stc15.h>
#include<intrins.h>
sbit RS = P1^2; //定義端口
sbit RW = P1^1;
sbit EN = P1^0;
#define RS_CLR RS=0 //選擇命令
#define RS_SET RS=1 //選擇數(shù)據(jù)
#define RW_CLR RW=0 //寫
#define RW_SET RW=1 //讀
#define EN_CLR EN=0 //使能位
#define EN_SET EN=1
#define DataPort P0
uS延時(shí)函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
unsigned char 是定義無符號(hào)字符變量,其值的范圍是
0~255 這里使用晶振12M,精確延時(shí)請(qǐng)使用匯編,大致延時(shí)
長度如下 T=tx2+5 uS
void DelayUs2x(unsigned char t)
while(--t);
mS延時(shí)函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
void DelayMs(unsigned char t)
while(t--)
//大致延時(shí)1mS
DelayUs2x(245);
DelayUs2x(245);
判忙函數(shù)
bit LCD_Check_Busy(void)
RS_CLR;
RW_SET;
EN_CLR;
_nop_(); //延時(shí)一個(gè)指令周期,一個(gè)指令周期為12MHZ
EN_SET;
return (bit)(DataPort & 0x80);//返回值強(qiáng)制轉(zhuǎn)換成位的形式,dataport與0x80得出的結(jié)果1ture,0false
} //讀LCD數(shù)據(jù)口,只要最高位bit7,為1忙,為0不忙
寫入命令函數(shù)
void LCD_Write_Com(unsigned char com)
while(LCD_Check_Busy()); //忙則等待,忙返回1,那么while(1)一直循環(huán)下去
RS_CLR;
RW_CLR;
EN_SET;
//P03= com&0x80;
//P02= com&0x40;
//P01= com&0x20;
//P00= com&0x10;
//P27= com&0x08;
//P26= com&0x04;
//P25= com&0x02;
//P24= com&0x01;
DataPort=com;
_nop_();
EN_CLR;
寫入數(shù)據(jù)函數(shù)
void LCD_Write_Data(unsigned char Data)
while(LCD_Check_Busy()); //忙則等待 (判忙)
RS_SET;
RW_CLR;
EN_SET;
//P03= Data&0x80;
//P02= Data&0x40;
//P01= Data&0x20;
//P00= Data&0x10;
//P27= Data&0x08;
//P26= Data&0x04;
//P25= Data&0x02;
//P24= Data&0x01;
DataPort=Data;
_nop_();
EN_CLR;
清屏函數(shù)
void LCD_Clear(void)
LCD_Write_Com(0x01);
DelayMs(5);
寫入字符串函數(shù)
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
LCD_Write_Com(0x80 + x); //表示第一行
LCD_Write_Com(0xC0 + x); //表示第二行
while (*s)
LCD_Write_Data( *s); //通過指針形式,依次寫入字符串
s ++;
寫入字符函數(shù)
void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data)
if (y == 0) //設(shè)置坐標(biāo),若y!=0則第一行寫滿
LCD_Write_Com(0x80 + x); //第一排以0x80起始,以寫命令的方式寫入,寫之前判忙
LCD_Write_Com(0xC0 + x); //第二排以0xc0起始,以寫命令的方式寫入,寫之前判忙
LCD_Write_Data( Data);
初始化函數(shù)
void LCD_Init(void)
LCD_Write_Com(0x38); /*顯示模式設(shè)置*/
DelayMs(5);
DelayMs(5);
DelayMs(5);
LCD_Write_Com(0x08); /*顯示關(guān)閉*/
LCD_Write_Com(0x01); /*顯示清屏*/
LCD_Write_Com(0x06); /*顯示光標(biāo)移動(dòng)設(shè)置*/
DelayMs(5);
LCD_Write_Com(0x0C); /*顯示開及光標(biāo)設(shè)置*/
主函數(shù)
void main(void)
LCD_Init(); //對(duì)光標(biāo)設(shè)置,以及屏幕清屏
LCD_Clear();//清屏
while (1)
LCD_Write_Char(7,0,'o');
LCD_Write_Char(8,0,'k');
LCD_Write_String(1,1,"hello world");
while(1);
