查看: 3155|回復(fù): 0
android SharedPreferences存儲(chǔ)數(shù)據(jù)
ID:435645 發(fā)表于 2020-12-17 21:09 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
MainActivity.java:
package com.example.android9;
import androidx.appcompat.app.AppCompatActivity;
import android.content.Context;
import android.content.Intent;
import android.content.SharedPreferences;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
import android.widget.TextView;
public class MainActivity extends AppCompatActivity {
    private SharedPreferences preferences = null;
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);//加載布局文件
        //獲取ui控件
        Button btn_set=findViewById(R.id.btn_set);
        //按鈕點(diǎn)擊事件
        btn_set.setOnClickListener(new View.OnClickListener() {
            @Override
            public void onClick(View v) {
                //創(chuàng)建意圖
                Intent intent = new Intent(MainActivity.this, MainActivity2.class);
                startActivity(intent);//開(kāi)啟意圖
    //重寫onStart()函數(shù)
    @Override
    protected void onStart() {
        super.onStart();//繼承
        //指定該SharedPreferences數(shù)據(jù)只能被本應(yīng)用程序讀寫
        preferences = getSharedPreferences("crazyit", Context.MODE_PRIVATE);
        //讀取字符數(shù)據(jù)
        String user = preferences.getString("user", "");
        //獲取textview控件
        TextView tx = findViewById(R.id.tx);
        //設(shè)置顯示內(nèi)容
        tx.setText("歡迎 " + user + " 來(lái)到我的家園");
}package com.example.android9;
    @Override
        //獲取ui控件
        //按鈕點(diǎn)擊事件
            @Override
                //創(chuàng)建意圖
    @Override
        //讀取字符數(shù)據(jù)
        //獲取textview控件
        //設(shè)置顯示內(nèi)容
MainActivity2.java:
import android.widget.EditText;
public class MainActivity2 extends AppCompatActivity {
    private SharedPreferences.Editor editor = null;
    @Override
        //加載布局文件
        setContentView(R.layout.activity_main2);
        //利用SharedPreferences讀取數(shù)據(jù)并顯示
        //獲取haredPreferences.Editor對(duì)象,嘗試寫數(shù)據(jù)
        editor = preferences.edit();
        //為“確定”按鈕綁定監(jiān)聽(tīng)器
        Button btn_ok = findViewById(R.id.btn);
        final EditText tv = findViewById(R.id.tv);
        btn_ok.setOnClickListener(new View.OnClickListener() {
            @Override
                String user = tv.getText().toString();
                editor.putString("user", user);
                editor.apply();
                finish();
activity_main.xml:
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:app="http://schemas.android.com/apk/res-auto"
    xmlns:tools="http://schemas.android.com/tools"
    android:layout_width="match_parent"
    android:layout_height="match_parent"
    tools:context=".MainActivity" >
    <TextView
        android:id="@+id/tx"
        android:layout_width="wrap_content"
        android:layout_height="wrap_content"
        android:layout_marginStart="43dp"
        android:layout_marginLeft="43dp"
        android:layout_marginTop="31dp"
        android:textSize="22dp"
        android:text="歡迎  來(lái)到我的家園" />
    <Button
        android:id="@+id/btn_set"
        android:layout_below="@id/tx"
        android:layout_marginLeft="130dp"
        android:text="參數(shù)設(shè)置"/>
</RelativeLayout>
activity_main2.xml:
    tools:context=".MainActivity2">
    <TextView
        android:id="@+id/tx2"
        android:text="請(qǐng)輸入用戶名:"
        android:textSize="28dp" />
    <EditText
        android:id="@+id/tv"
        android:layout_below="@+id/tx2"
        android:inputType="text"
        android:ems="9"
        android:textColorHighlight="@color/colorAccent"
    <Button
        android:id="@+id/btn"
        android:layout_below="@id/tv"
        android:layout_marginLeft="100dp"
        android:text="確定"/>
</RelativeLayout>
