#include <reg52.h>
#include "i2c.h"
#include "delay.h"
#include "display.h"
#include "math.h"
#define AddWr 0x90 //寫數(shù)據(jù)地址
#define AddRd 0x91 //讀數(shù)據(jù)地址
void timer0_init(); //定時器0初始化
void motor_run();
void control();
uchar time;
uint motor_pwm;
double count=0; //定義占空比,并初始占空比為26%
sbit PWM=P2^3;
sbit Motor_CW=P2^4;
sbit Motor_CCW=P2^5;
float angleset=50;
float angel;
uint nowerror;
long sumerror;
uint lasterror;
float output;
float kp=0.56,ki=0.008,kd=1;
extern bit ack;
bit flag;
//bit WriteDAC(unsigned char dat);
主程序
uchar ReadADC(uchar Chl)
uchar val;
Start_I2c();
SendByte(AddWr);
if(ack==0)return (0);
SendByte(Chl);
Start_I2c();
SendByte(AddRd);
val=RcvByte();
NoAck_I2c();
Stop_I2c();
return(val);
void motor_run(uint pwm)
if(time<pwm) //定義電機的轉(zhuǎn)速
PWM=1;
}else
PWM=0;
if(time>100)
time=0;
flag=1;
/****************************pid*****************************/
void timer0_init()
TMOD=0x01; //定時器0工作于方式1
TH0=(65536-100)/256;
TL0=(65536-100)%256;
TR0=1;
ET0=1;
EA=1;
/**************定時0中斷處理******************/
void timer0_int() interrupt 1
TR0=0; //設(shè)置定時器初值期間,關(guān)閉定時器
TR0=1;
time++;
motor_run(motor_pwm);
uint XIANFU_Pwm(uint pwm)
if ( pwm <0) pwm = 0;
if (pwm>=100) pwm= 100;
return pwm;
float PID_Control(float angleset,float angel)
angel=ReadADC(0x40);
nowerror=angleset-angel;//當前誤差
sumerror+=nowerror; //誤差求和
if(sumerror>2500)
sumerror=2500;//限幅
output = kp*nowerror+ki*sumerror+kd*(lasterror-nowerror);
lasterror=nowerror;
return output;//增量輸出
void control()
motor_pwm=(uint) PID_Control(angleset,angel);
motor_pwm= XIANFU_Pwm(motor_pwm);
//motor_run(motor_pwm);
main()
float angleAD;
Motor_CW=0; //電機正反轉(zhuǎn)
Motor_CCW=1;
timer0_init();
if(flag==1)
flag=0;
control();
angleAD = ReadADC(0x40); //絕對角度數(shù)字值A(chǔ)D值
display(angleAD);
//WriteDAC(angleAD);
程序.zip
2020-12-19 10:31 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
98.71 KB, 下載次數(shù): 17, 下載積分: 黑幣 -5
51程序
