查看: 3869|回復(fù): 5
基于51單片機(jī)的智能空調(diào)程序
ID:813640 發(fā)表于 2020-12-21 21:41 | 顯示全部樓層 |閱讀模式
#include "reg52.h"
#include "lcd.h"
#include "temp.h"
#include "i2c.h"
sbit k3=P3^2;        //設(shè)置溫度上下限
sbit k1=P3^1;        //加
sbit k2=P3^0;        //減
sbit led=P2^4; //報(bào)警指示燈
sbit beep=P1^5;          //蜂鳴器報(bào)警
sbit relay=P1^1;  //  設(shè)備加熱和繼電器
sbit moto=P1^0;   //  電機(jī)散熱
char set_temph=0,a=0;//,set_templ=28;  //設(shè)定溫度限默認(rèn)值
u16 temp_val;  //檢測(cè)的實(shí)際溫度
u8 mode;  //溫度模式
void delay(u16 i)
        while(i--);
void Temp_DataPros()
        char set_temph=a;//,set_templ=28;  //設(shè)定溫度上下限默認(rèn)值
        short temp;
        u8 temp_buf[5];
        temp=Ds18b20ReadTemp();
        temp_val=temp;
        if(temp<0)
                temp=-temp;
                LCD_Dispstring(3+5,0,"-");
                LCD_Dispstring(3+5,0," ");
        temp_buf[0]=temp/100+0x30;
        temp_buf[1]=temp%100/10+0x30;
        temp_buf[2]='.';
        temp_buf[3]=temp%100%10+0x30;
        temp_buf[4]='\0';
        LCD_Dispstring(3+6,0,temp_buf);                 //顯示檢測(cè)的溫度xx.x
        set_temph=a;
        temp_buf[0]=set_temph/10+0x30;
           temp_buf[1]=set_temph%10+0x30;
        temp_buf[2]='\0';
        LCD_Dispstring(8,1,temp_buf);          //顯示設(shè)定的溫度值xx        */
#define  K1_MODE  1
#define  K2_ADD  2
#define  K3_DEC  3
//mode:  0-單次掃描   1-連續(xù)掃描
u8 KEY_Scan(u8 mode)
        static u8 key=1;
        if(key&&(k1==0||k2==0||k3==0))
                delay(1000);   //消抖
                key=0;
                if(k3==0)
                        return K1_MODE;
                else if(k1==0)
                        return K2_ADD;
                else if(k2==0)
                        return K3_DEC;
        else if(k1==1&&k2==1&&k3==1)
                key=1;
        if(mode)
                key=1;
        return 0;
void sound()
        u8 i=50;
        while(i--)
                beep=!beep;
                delay(10);
void KEY_Pros()
        u8 key;
        u8 temph_buf[3];
        key=KEY_Scan(0);
        if(key==K1_MODE)   //模式選擇
                mode++;
                LCD_Clear();
                if(mode==1)
                        LCD_Dispstring(4,0,"SET:   C");
                        mode=0;
                        LCD_Dispstring(3,0,"Temp:     C");
                        LCD_Dispstring(4,1,"SET:  C");
        if(mode==1)         //溫度上限設(shè)置
                switch(key)
                        case K2_ADD:            //加
                                                set_temph++;
                                                if(set_temph>=80)set_temph=80;
                                                break;
                        case K3_DEC:          //減
                                                set_temph--;
                                                if(set_temph<=0)set_temph=0;
                                                break;
                a=set_temph;
                temph_buf[0]=set_temph/10+0x30;
                temph_buf[1]=set_temph%10+0x30;
                temph_buf[2]='\0';
                   LCD_Dispstring(8,0,temph_buf);
                At24c02Write(0,set_temph);
void TempData_Compare()
        if(temp_val>(set_temph+1)*10)        //實(shí)際溫度高于上限值   報(bào)警  散熱
                led=1;
                moto=1;                  //1
                relay=0;
                sound();
        else if(temp_val<(set_temph-1)*10)         //實(shí)際溫度低于下限值   報(bào)警  加熱
                led=1;
                moto=0;          //0
                relay=1;
                sound();
        else                      //實(shí)際溫度在下限值和上限值之間   取消報(bào)警  取消加熱  取消散熱
                moto=1;
                led=0;
                relay=1;
void kai_display()
        if(At24c02Read(255)!=18)
                At24c02Write(255,18);
                set_temph=At24c02Read(0);
        moto=0;
        led=0;
        relay=0;
        LCD_Init();
        kai_display();
                TempData_Compare();
                if(mode==0)
                        Temp_DataPros();
                KEY_Pros();
ID:813640 發(fā)表于 2020-12-24 19:37 | 顯示全部樓層
Keil代碼文件:
智能空調(diào).rar
63.12 KB, 下載次數(shù): 65, 下載積分: 黑幣 -5
參與人數(shù) 1黑幣 +40 收起 理由
admin + 40 回帖助人的獎(jiǎng)勵(lì)!
ID:813640 發(fā)表于 2020-12-21 21:42 | 顯示全部樓層
有疑問的黑子們可以咨詢我,實(shí)物已經(jīng)做成功了。
ID:328014 發(fā)表于 2020-12-22 03:11 | 顯示全部樓層
能上傳下工程包嗎?缺少頭文件無(wú)法編譯
ID:22266 發(fā)表于 2021-9-23 21:47 | 顯示全部樓層
程序?qū)懙貌诲e(cuò),不過(guò)叫空調(diào)有點(diǎn)不妥,畢竟他沒有壓縮機(jī),應(yīng)該叫溫控烤箱
ID:987360 發(fā)表于 2021-12-10 16:52 | 顯示全部樓層
誰(shuí)能根據(jù)樓主的資料 制作一個(gè)仿真圖嗎?
