求大佬幫看看這個程序怎么改嗎?謝謝各位了!
報錯的內(nèi)容是:011.c(99): error C141: syntax error near 'unsigned'
代碼如下:
- #include<reg51.h>
- sbit A1=P1^0;
- sbit B1=P1^1;
- sbit C1=P1^2;
- sbit D1=P1^3;
- #define WDM P0
- #define KeyP3 P3
- sbit DuanSuo=P2^2;
- sbit WeiSuo=P2^3;
- unsigned char Speed=1;
- bit StopFlag=1;
- unsigned char code DWtable[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
- unsigned char code WMtable[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
- unsigned char TData[8];
- #define A_ON {A1=1;B1=0;C1=0;D1=0;}
- #define B_ON {A1=0;B1=1;C1=0;D1=0;}
- #define C_ON {A1=0;B1=0;C1=1;D1=0;}
- #define D_ON {A1=0;B1=0;C1=0;D1=1;}
- #define AB_ON {A1=1;B1=1;C1=0;D1=0;}
- #define BC_ON {A1=0;B1=1;C1=1;D1=0;}
- #define CD_ON {A1=0;B1=0;C1=1;D1=1;}
- #define DA-ON {A1=1;B1=0;C1=0;D1=1;}
- #define ABCD_OFF {A1=0;B1=0;C1=0;D1=0;}
- void DelayUs(unsigned char tu)
- while(--tu);
- void DelayMs(unsigned char tm)
- while(tm--);
- DelayUs (248);
- DelayUs (248);
- void Display(unsigned char ShiWei,unsigned char WeiShu)
- static unsigned char i;
- WDM=WMtable[i+ShiWei];
- WeiSuo=1;
- WeiSuo=0;
- WDM=TData[i];
- DuanSuo=1;
- DuanSuo=0;
- i++;
- if(i==WeiShu)
- i=0;
- void T0Int_S (void)
- TMOD=0X01;
- TH0=0;
- TL0=0;
- EA=1;
- ET0=1;
- TR0=1;
- void T0Int_Z (void) interrupt 1
- static unsigned char times,i;
- TH0=(65536-2000)/256;
- TL0=(65536-2000)%256;
- Display(0,8);
- if(StopFlag==0)
- if(times==(20-Speed))
- times=0;
- switch(i)
- case 0:A_ON;i++;break;
- case 1:B_ON;i++;break;
- case 2:C_ON;i++;break;
- case 3:D_ON;i++;break;
- case 4:i=0;break;
- default:break;
- times++;
- unsigned char KeyS(void)//報錯的是這行,應該怎么改,謝謝�。�
- unsigned char keyZ;
- if(KeyP3!=0xff)
- DelayMs(10);
- if(KeyP3!=0Xff)
- keyZ=KeyP3;
- while(KeyP3!=0xff);
- switch(keyZ)
- case 0xfe:return 1;break;
- case 0xfd:return 2;break;
- case 0xfb:return 3;break;
- case 0xf7:return 4;break;
- case 0xef:return 5;break;
- case 0xdf:return 6;break;
- case 0xbf:return 7;break;
- case 0x7f:return 8;break;
- default:return 0;break;
- return 0;
- void main()
- unsigned char num;
- T0Int_S();
- ABCD_OFF
- while(1)
- num=KeyS();
- if(num==1)
- if(Speed<18)
- Speed++;
- else if(num==2)
- if(Speed>1)
- Speed--;
- else if(num==3)
- ABCD_OFF
- StopFlag=1;
- else if(num==4)
- StopFlag=0;
- TData[0]=DMtable[Speed/10];
- TData[1]=DMtable[Speed%10];
復制代碼
