查看: 1865|回復(fù): 2
12864帶字庫(kù)測(cè)試程序
ID:865659 發(fā)表于 2020-12-23 16:22 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <reg51.h>
#include <intrins.h>
#define uint  unsigned int
/*TS12864A-3 端口定義*/
#define LCD_data  P0             //數(shù)據(jù)口
sbit LCD_RS  =  P3^5;            //寄存器選擇輸入
sbit LCD_RW  =  P3^6;            //液晶讀/寫控制
sbit LCD_EN  =  P3^4;            //液晶使能控制
sbit LCD_PSB =  P3^7;            //串/并方式控制
sbit wela    =  P2^6;
sbit dula    =  P2^7;
uchar code dis1[] = {"a"};
uchar code dis2[] = {"b"};
uchar code dis3[] = {"c "};
uchar code dis4[] = {"d "};
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
uchar IRDIS[2];
uchar IRCOM[4];
void delay0(uchar x);  //x*0.14MS
void beep();
void  dataconv();
void lcd_pos(uchar X,uchar Y);  //確定顯示位置/*        */
/*  延時(shí)函數(shù)
void delay(int ms)
    while(ms--)
      uchar i;
          for(i=0;i<250;i++)
            _nop_();
                _nop_();
                _nop_();
                _nop_();
/*檢查L(zhǎng)CD忙狀態(tài)                                                    */
/*lcd_busy為1時(shí),忙,等待。lcd-busy為0時(shí),閑,可寫指令與數(shù)據(jù)。
bit lcd_busy()
    bit result;
    LCD_RS = 0;
    LCD_RW = 1;
    LCD_EN = 1;
    delayNOP();
    result = (bit)(P0&0x80);
    LCD_EN = 0;
    return(result);
}                                                          寫指令數(shù)據(jù)到LCD
RS=L,RW=L,E=高脈沖,D0-D7=指令碼。
void lcd_wcmd(uchar cmd)
   while(lcd_busy());
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_EN = 0;
    _nop_();
    _nop_();
    P0 = cmd;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
寫顯示數(shù)據(jù)到LCD
RS=H,RW=L,E=高脈沖,D0-D7=數(shù)據(jù)。
void lcd_wdat(uchar dat)
   while(lcd_busy());
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_EN = 0;
    P0 = dat;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
LCD初始化設(shè)定
void lcd_init()
    LCD_PSB = 1;         //并口方式
    lcd_wcmd(0x34);      //擴(kuò)充指令操作
    delay(5);
    lcd_wcmd(0x30);      //基本指令操作
    delay(5);
    lcd_wcmd(0x0C);      //顯示開,關(guān)光標(biāo)
    delay(5);
    lcd_wcmd(0x01);      //清除LCD的顯示內(nèi)容
    delay(5);
main()
    uchar i;
    delay(10);                 //延時(shí)
    wela=0;
        dula=0;
    lcd_init();                //初始化LCD
    lcd_pos(0,0);             //設(shè)置顯示位置為第一行的第1個(gè)字符
     i = 0;
    while(dis1[i] != '\0')
     {                         //顯示字符
       lcd_wdat(dis1[i]);
       i++;
    lcd_pos(1,0);             //設(shè)置顯示位置為第二行的第1個(gè)字符
     i = 0;
    while(dis2[i] != '\0')
       lcd_wdat(dis2[i]);      //顯示字符
       i++;
         lcd_pos(2,0);             //設(shè)置顯示位置為第三行的第1個(gè)字符
     i = 0;
    while(dis3[i] != '\0')
       lcd_wdat(dis3[i]);      //顯示字符
       i++;
         lcd_pos(3,0);             //設(shè)置顯示位置為第四行的第1個(gè)字符
     i = 0;
    while(dis4[i] != '\0')
       lcd_wdat(dis4[i]);      //顯示字符
       i++;
     while(1);
void delay0(uchar x)    //x*0.14MS
  uchar i;
  while(x--)
  for (i = 0; i<13; i++) {}
   uchar  pos;
   if (X==0)
     {X=0x80;}
   else if (X==1)
     {X=0x90;}
   else if (X==2)
     {X=0x88;}
   else if (X==3)
     {X=0x98;}
   pos = X+Y ;
   lcd_wcmd(pos);     //顯示地址
ID:815949 發(fā)表于 2021-4-17 22:49 | 只看該作者
樓主有KS0108系列的液晶(不帶字庫(kù))的測(cè)試程序嗎
ID:896773 發(fā)表于 2021-4-21 10:19 | 只看該作者
請(qǐng)問(wèn)有仿真原理圖嗎?
