int32_t lps22hh_read_reg(lps22hh_ctx_t* ctx, uint8_t reg, uint8_t* data,
uint16_t len)
int32_t ret;
ret = ctx->read_reg(ctx->handle, reg, data, len);
return ret;
* @brief Write generic device register
* @param ctx read / write interface definitions(ptr)
* @param reg register to write
* @param data pointer to data to write in register reg(ptr)
* @param len number of consecutive register to write
* @retval interface status (MANDATORY: return 0 -> no Error)
int32_t lps22hh_write_reg(lps22hh_ctx_t* ctx, uint8_t reg, uint8_t* data,
uint16_t len)
int32_t ret;
ret = ctx->write_reg(ctx->handle, reg, data, len);
return ret;
* @defgroup LPS22HH_Sensitivity
* @brief These functions convert raw-data into engineering units.
float_t lps22hh_from_lsb_to_hpa(int32_t lsb)
return ( (float_t) lsb / 4096.0f );
float_t lps22hh_from_lsb_to_celsius(int16_t lsb)
return ( (float_t) lsb / 100.0f );
* @defgroup LPS22HH_Data_Generation
* @brief This section groups all the functions concerning
* data generation.
* @brief Reset Autozero function.[set]
* @param val change the values of reset_az in reg INTERRUPT_CFG
int32_t lps22hh_autozero_rst_set(lps22hh_ctx_t *ctx, uint8_t val)
lps22hh_interrupt_cfg_t reg;
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_INTERRUPT_CFG, (uint8_t*) ®, 1);
if (ret == 0) {
reg.reset_az = val;
ret = lps22hh_write_reg(ctx, LPS22HH_INTERRUPT_CFG, (uint8_t*) ®, 1);
return ret;
* @brief Reset Autozero function.[get]
int32_t lps22hh_autozero_rst_get(lps22hh_ctx_t *ctx, uint8_t *val)
int32_t ret;
*val = reg.reset_az;
return ret;
* @brief Enable Autozero function.[set]
* @param val change the values of autozero in reg INTERRUPT_CFG
int32_t lps22hh_autozero_set(lps22hh_ctx_t *ctx, uint8_t val)
int32_t ret;
if (ret == 0) {
reg.autozero = val;
return ret;
* @brief Enable Autozero function.[get]
int32_t lps22hh_autozero_get(lps22hh_ctx_t *ctx, uint8_t *val)
int32_t ret;
*val = reg.autozero;
return ret;
* @brief Reset AutoRifP function.[set]
* @param val change the values of reset_arp in reg INTERRUPT_CFG
int32_t lps22hh_pressure_snap_rst_set(lps22hh_ctx_t *ctx, uint8_t val)
int32_t ret;
if (ret == 0) {
reg.reset_arp = val;
return ret;
* @brief Reset AutoRifP function.[get]
int32_t lps22hh_pressure_snap_rst_get(lps22hh_ctx_t *ctx, uint8_t *val)
int32_t ret;
*val = reg.reset_arp;
return ret;
* @brief Enable AutoRefP function.[set]
* @param val change the values of autorefp in reg INTERRUPT_CFG
int32_t lps22hh_pressure_snap_set(lps22hh_ctx_t *ctx, uint8_t val)
int32_t ret;
if (ret == 0) {
reg.autorefp = val;
return ret;
* @brief Enable AutoRefP function.[get]
int32_t lps22hh_pressure_snap_get(lps22hh_ctx_t *ctx, uint8_t *val)
int32_t ret;
*val = reg.autorefp;
return ret;
* @brief Block Data Update.[set]
* @param val change the values of bdu in reg CTRL_REG1
int32_t lps22hh_block_data_update_set(lps22hh_ctx_t *ctx, uint8_t val)
lps22hh_ctrl_reg1_t reg;
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_CTRL_REG1, (uint8_t*) ®, 1);
if (ret == 0) {
reg.bdu = val;
ret = lps22hh_write_reg(ctx, LPS22HH_CTRL_REG1, (uint8_t*) ®, 1);
return ret;
* @brief Block Data Update.[get]
int32_t lps22hh_block_data_update_get(lps22hh_ctx_t *ctx, uint8_t *val)
int32_t ret;
*val = reg.bdu;
return ret;
* @brief Output data rate selection.[set]
* @param val change the values of odr in reg CTRL_REG1
int32_t lps22hh_data_rate_set(lps22hh_ctx_t *ctx, lps22hh_odr_t val)
lps22hh_ctrl_reg1_t ctrl_reg1;
lps22hh_ctrl_reg2_t ctrl_reg2;
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_CTRL_REG1, (uint8_t*)&ctrl_reg1, 1);
if (ret == 0) {
ret = lps22hh_read_reg(ctx, LPS22HH_CTRL_REG2, (uint8_t*)&ctrl_reg2, 1);
if (ret == 0) {
ctrl_reg1.odr = (uint8_t)val & 0x07U;
ret = lps22hh_write_reg(ctx, LPS22HH_CTRL_REG1, (uint8_t*)&ctrl_reg1, 1);
if (ret == 0) {
ctrl_reg2.low_noise_en = ((uint8_t)val & 0x10U) >> 4;
ctrl_reg2.one_shot = ((uint8_t)val & 0x08U) >> 3;
ret = lps22hh_write_reg(ctx, LPS22HH_CTRL_REG2, (uint8_t*)&ctrl_reg2, 1);
return ret;
* @brief Output data rate selection.[get]
* @param val Get the values of odr in reg CTRL_REG1
int32_t lps22hh_data_rate_get(lps22hh_ctx_t *ctx, lps22hh_odr_t *val)
int32_t ret;
if (ret == 0) {
if (ret == 0) {
switch (((ctrl_reg2.low_noise_en << 4) + (ctrl_reg2.one_shot << 3) +
ctrl_reg1.odr )) {
case LPS22HH_POWER_DOWN:
*val = LPS22HH_POWER_DOWN;
break;
case LPS22HH_ONE_SHOOT:
*val = LPS22HH_ONE_SHOOT;
break;
case LPS22HH_1_Hz:
*val = LPS22HH_1_Hz;
break;
case LPS22HH_10_Hz:
*val = LPS22HH_10_Hz;
break;
case LPS22HH_25_Hz:
*val = LPS22HH_25_Hz;
break;
case LPS22HH_50_Hz:
*val = LPS22HH_50_Hz;
break;
case LPS22HH_75_Hz:
*val = LPS22HH_75_Hz;
break;
case LPS22HH_1_Hz_LOW_NOISE:
*val = LPS22HH_1_Hz_LOW_NOISE;
break;
case LPS22HH_10_Hz_LOW_NOISE:
*val = LPS22HH_10_Hz_LOW_NOISE;
break;
case LPS22HH_25_Hz_LOW_NOISE:
*val = LPS22HH_25_Hz_LOW_NOISE;
break;
case LPS22HH_50_Hz_LOW_NOISE:
*val = LPS22HH_50_Hz_LOW_NOISE;
break;
case LPS22HH_75_Hz_LOW_NOISE:
*val = LPS22HH_75_Hz_LOW_NOISE;
break;
case LPS22HH_100_Hz:
*val = LPS22HH_100_Hz;
break;
case LPS22HH_200_Hz:
*val = LPS22HH_200_Hz;
break;
default:
break;
return ret;
* @brief The Reference pressure value is a 16-bit data
* expressed as 2’s complement. The value is used
* when AUTOZERO or AUTORIFP function is enabled.[set]
* @param buff buffer that contains data to write
int32_t lps22hh_pressure_ref_set(lps22hh_ctx_t *ctx, uint8_t *buff)
int32_t ret;
ret = lps22hh_write_reg(ctx, LPS22HH_REF_P_L, buff, 2);
return ret;
* data expressed as 2’s complement.
* The value is used when AUTOZERO or AUTORIFP
* function is enabled.[get]
* @param buff buffer that stores data read
int32_t lps22hh_pressure_ref_get(lps22hh_ctx_t *ctx, uint8_t *buff)
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_REF_P_L, buff, 2);
return ret;
* @brief The pressure offset value is 16-bit data
* that can be used to implement one-point
* calibration (OPC) after soldering.[set]
int32_t lps22hh_pressure_offset_set(lps22hh_ctx_t *ctx, uint8_t *buff)
int32_t ret;
ret = lps22hh_write_reg(ctx, LPS22HH_RPDS_L, buff, 2);
return ret;
* data that can be used to implement
* one-point calibration (OPC) after
* soldering.[get]
int32_t lps22hh_pressure_offset_get(lps22hh_ctx_t *ctx, uint8_t *buff)
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_RPDS_L, buff, 2);
return ret;
* @brief Read all the interrupt/status flag of the device.[get]
* @param val registers STATUS,FIFO_STATUS2,INT_SOURCE
int32_t lps22hh_all_sources_get(lps22hh_ctx_t *ctx, lps22hh_all_sources_t *val)
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_INT_SOURCE,
(uint8_t*) &(val->int_source), 1);
if (ret == 0) {
ret = lps22hh_read_reg(ctx, LPS22HH_FIFO_STATUS2,
(uint8_t*) &(val->fifo_status2), 1);
if (ret == 0) {
ret = lps22hh_read_reg(ctx, LPS22HH_STATUS,
(uint8_t*) &(val->status), 1);
return ret;
* @brief The STATUS_REG register is read by the primary interface.[get]
* @param val structure of registers from STATUS to STATUS_REG
int32_t lps22hh_status_reg_get(lps22hh_ctx_t *ctx, lps22hh_status_t *val)
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_STATUS, (uint8_t*) val, 1);
return ret;
* @brief Pressure new data available.[get]
* @param val change the values of p_da in reg STATUS
int32_t lps22hh_press_flag_data_ready_get(lps22hh_ctx_t *ctx, uint8_t *val)
lps22hh_status_t reg;
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_STATUS, (uint8_t*) ®, 1);
*val = reg.p_da;
return ret;
* @brief Temperature data available.[get]
* @param val change the values of t_da in reg STATUS
int32_t lps22hh_temp_flag_data_ready_get(lps22hh_ctx_t *ctx, uint8_t *val)
int32_t ret;
*val = reg.t_da;
return ret;
* @defgroup LPS22HH_Data_Output
* @brief This section groups all the data output functions.
* @brief Pressure output value.[get]
int32_t lps22hh_pressure_raw_get(lps22hh_ctx_t *ctx, uint8_t *buff)
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_PRESS_OUT_XL, buff, 3);
return ret;
* @brief Temperature output value.[get]
int32_t lps22hh_temperature_raw_get(lps22hh_ctx_t *ctx, uint8_t *buff)
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_TEMP_OUT_L, buff, 2);
return ret;
* @brief Pressure output from FIFO value.[get]
int32_t lps22hh_fifo_pressure_raw_get(lps22hh_ctx_t *ctx, uint8_t *buff)
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_FIFO_DATA_OUT_PRESS_XL, buff, 3);
return ret;
* @brief Temperature output from FIFO value.[get]
int32_t lps22hh_fifo_temperature_raw_get(lps22hh_ctx_t *ctx, uint8_t *buff)
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_FIFO_DATA_OUT_TEMP_L, buff, 2);
return ret;
* @defgroup LPS22HH_Common
* @brief This section groups common useful functions.
* @brief DeviceWhoamI[get]
int32_t lps22hh_device_id_get(lps22hh_ctx_t *ctx, uint8_t *buff)
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_WHO_AM_I, buff, 1);
return ret;
* @brief Software reset. Restore the default values
* in user registers.[set]
* @param val change the values of swreset in reg CTRL_REG2
int32_t lps22hh_reset_set(lps22hh_ctx_t *ctx, uint8_t val)
lps22hh_ctrl_reg2_t reg;
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_CTRL_REG2, (uint8_t*) ®, 1);
if (ret == 0) {
reg.swreset = val;
ret = lps22hh_write_reg(ctx, LPS22HH_CTRL_REG2, (uint8_t*) ®, 1);
return ret;
* in user registers.[get]
int32_t lps22hh_reset_get(lps22hh_ctx_t *ctx, uint8_t *val)
int32_t ret;
*val = reg.swreset;
return ret;
* @brief Register address automatically
* incremented during a multiple byte access
* with a serial interface.[set]
* @param val change the values of if_add_inc in reg CTRL_REG2
int32_t lps22hh_auto_increment_set(lps22hh_ctx_t *ctx, uint8_t val)
int32_t ret;
if (ret == 0) {
reg.if_add_inc = val;
return ret;
* access with a serial interface.[get]
int32_t lps22hh_auto_increment_get(lps22hh_ctx_t *ctx, uint8_t *val)
int32_t ret;
*val = reg.if_add_inc;
return ret;
* @brief Reboot memory content. Reload the calibration
* parameters.[set]
* @param val change the values of boot in reg CTRL_REG2
int32_t lps22hh_boot_set(lps22hh_ctx_t *ctx, uint8_t val)
int32_t ret;
if (ret == 0) {
reg.boot = val;
return ret;
* parameters.[get]
int32_t lps22hh_boot_get(lps22hh_ctx_t *ctx, uint8_t *val)
int32_t ret;
*val = reg.boot;
return ret;
* @defgroup LPS22HH_Filters
* @brief This section group all the functions concerning the
* filters configuration.
* @brief Low-pass bandwidth selection.[set]
* @param val change the values of lpfp_cfg in reg CTRL_REG1
int32_t lps22hh_lp_bandwidth_set(lps22hh_ctx_t *ctx, lps22hh_lpfp_cfg_t val)
int32_t ret;
if (ret == 0) {
reg.lpfp_cfg = (uint8_t)val;
return ret;
* @brief Low-pass bandwidth selection.[get]
* @param val Get the values of lpfp_cfg in reg CTRL_REG1
int32_t lps22hh_lp_bandwidth_get(lps22hh_ctx_t *ctx, lps22hh_lpfp_cfg_t *val)
int32_t ret;
switch (reg.lpfp_cfg) {
case LPS22HH_LPF_ODR_DIV_2:
*val = LPS22HH_LPF_ODR_DIV_2;
break;
case LPS22HH_LPF_ODR_DIV_9:
*val = LPS22HH_LPF_ODR_DIV_9;
break;
case LPS22HH_LPF_ODR_DIV_20:
*val = LPS22HH_LPF_ODR_DIV_20;
break;
default:
break;
return ret;
* @defgroup LPS22HH_Serial_Interface
* @brief This section groups all the functions concerning serial
* interface management
* @brief Enable/Disable I2C interface.[set]
* @param val change the values of i2c_disable in reg IF_CTRL
int32_t lps22hh_i2c_interface_set(lps22hh_ctx_t *ctx,
lps22hh_i2c_disable_t val)
lps22hh_if_ctrl_t reg;
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_IF_CTRL, (uint8_t*) ®, 1);
if (ret == 0) {
reg.i2c_disable = (uint8_t)val;
ret = lps22hh_write_reg(ctx, LPS22HH_IF_CTRL, (uint8_t*) ®, 1);
return ret;
* @brief Enable/Disable I2C interface.[get]
* @param val Get the values of i2c_disable in reg IF_CTRL
int32_t lps22hh_i2c_interface_get(lps22hh_ctx_t *ctx,
lps22hh_i2c_disable_t *val)
int32_t ret;
switch (reg.i2c_disable) {
case LPS22HH_I2C_ENABLE:
*val = LPS22HH_I2C_ENABLE;
break;
case LPS22HH_I2C_DISABLE:
*val = LPS22HH_I2C_DISABLE;
break;
default:
break;
return ret;
* @brief I3C Enable/Disable communication protocol.[set]
* @param val change the values of int_en_i3c in reg IF_CTRL
int32_t lps22hh_i3c_interface_set(lps22hh_ctx_t *ctx,
lps22hh_i3c_disable_t val)
int32_t ret;
if (ret == 0) {
reg.i3c_disable = ((uint8_t)val & 0x01u);
reg.int_en_i3c = ((uint8_t)val & 0x10U) >> 4;
return ret;
* @brief I3C Enable/Disable communication protocol.[get]
int32_t lps22hh_i3c_interface_get(lps22hh_ctx_t *ctx,
lps22hh_i3c_disable_t *val)
int32_t ret;
switch ((reg.int_en_i3c << 4) + reg.int_en_i3c) {
case LPS22HH_I3C_ENABLE:
*val = LPS22HH_I3C_ENABLE;
break;
case LPS22HH_I3C_ENABLE_INT_PIN_ENABLE:
*val = LPS22HH_I3C_ENABLE_INT_PIN_ENABLE;
break;
case LPS22HH_I3C_DISABLE:
*val = LPS22HH_I3C_DISABLE;
break;
default:
break;
return ret;
* @brief Enable/Disable pull-up on SDO pin.[set]
* @param val change the values of sdo_pu_en in reg IF_CTRL
int32_t lps22hh_sdo_sa0_mode_set(lps22hh_ctx_t *ctx, lps22hh_pu_en_t val)
int32_t ret;
if (ret == 0) {
reg.sdo_pu_en = (uint8_t)val;
return ret;
* @brief Enable/Disable pull-up on SDO pin.[get]
* @param val Get the values of sdo_pu_en in reg IF_CTRL
int32_t lps22hh_sdo_sa0_mode_get(lps22hh_ctx_t *ctx, lps22hh_pu_en_t *val)
int32_t ret;
switch (reg.sdo_pu_en) {
case LPS22HH_PULL_UP_DISCONNECT:
*val = LPS22HH_PULL_UP_DISCONNECT;
break;
case LPS22HH_PULL_UP_CONNECT:
*val = LPS22HH_PULL_UP_CONNECT;
break;
default:
break;
return ret;
* @brief Connect/Disconnect SDO/SA0 internal pull-up.[set]
* @param val change the values of sda_pu_en in reg IF_CTRL
int32_t lps22hh_sda_mode_set(lps22hh_ctx_t *ctx, lps22hh_pu_en_t val)
int32_t ret;
if (ret == 0) {
reg.sda_pu_en = (uint8_t)val;
return ret;
* @brief Connect/Disconnect SDO/SA0 internal pull-up.[get]
* @param val Get the values of sda_pu_en in reg IF_CTRL
int32_t lps22hh_sda_mode_get(lps22hh_ctx_t *ctx, lps22hh_pu_en_t *val)
int32_t ret;
switch (reg.sda_pu_en) {
break;
break;
default:
break;
return ret;
* @brief SPI Serial Interface Mode selection.[set]
* @param val change the values of sim in reg CTRL_REG1
int32_t lps22hh_spi_mode_set(lps22hh_ctx_t *ctx, lps22hh_sim_t val)
int32_t ret;
if (ret == 0) {
reg.sim = (uint8_t)val;
return ret;
* @brief SPI Serial Interface Mode selection.[get]
* @param val Get the values of sim in reg CTRL_REG1
int32_t lps22hh_spi_mode_get(lps22hh_ctx_t *ctx, lps22hh_sim_t *val)
int32_t ret;
switch (reg.sim) {
case LPS22HH_SPI_4_WIRE:
*val = LPS22HH_SPI_4_WIRE;
break;
case LPS22HH_SPI_3_WIRE:
*val = LPS22HH_SPI_3_WIRE;
break;
default:
break;
return ret;
* @defgroup LPS22HH_Interrupt_Pins
* @brief This section groups all the functions that manage
* interrupt pins.
* @brief Latch interrupt request to the INT_SOURCE (24h) register.[set]
* @param val change the values of lir in reg INTERRUPT_CFG
int32_t lps22hh_int_notification_set(lps22hh_ctx_t *ctx, lps22hh_lir_t val)
int32_t ret;
if (ret == 0) {
reg.lir = (uint8_t)val;
return ret;
* @brief Latch interrupt request to the INT_SOURCE (24h) register.[get]
* @param val Get the values of lir in reg INTERRUPT_CFG
int32_t lps22hh_int_notification_get(lps22hh_ctx_t *ctx, lps22hh_lir_t *val)
int32_t ret;
switch (reg.lir) {
case LPS22HH_INT_PULSED:
*val = LPS22HH_INT_PULSED;
break;
case LPS22HH_INT_LATCHED:
*val = LPS22HH_INT_LATCHED;
break;
default:
break;
return ret;
* @brief Push-pull/open drain selection on interrupt pads.[set]
* @param val change the values of pp_od in reg CTRL_REG2
int32_t lps22hh_pin_mode_set(lps22hh_ctx_t *ctx, lps22hh_pp_od_t val)
int32_t ret;
if (ret == 0) {
reg.pp_od = (uint8_t)val;
return ret;
* @brief Push-pull/open drain selection on interrupt pads.[get]
* @param val Get the values of pp_od in reg CTRL_REG2
int32_t lps22hh_pin_mode_get(lps22hh_ctx_t *ctx, lps22hh_pp_od_t *val)
int32_t ret;
switch (reg.pp_od) {
case LPS22HH_PUSH_PULL:
*val = LPS22HH_PUSH_PULL;
break;
case LPS22HH_OPEN_DRAIN:
*val = LPS22HH_OPEN_DRAIN;
break;
default:
break;
return ret;
* @brief Interrupt active-high/low.[set]
* @param val change the values of int_h_l in reg CTRL_REG2
int32_t lps22hh_pin_polarity_set(lps22hh_ctx_t *ctx, lps22hh_int_h_l_t val)
int32_t ret;
if (ret == 0) {
reg.int_h_l = (uint8_t)val;
return ret;
* @brief Interrupt active-high/low.[get]
* @param val Get the values of int_h_l in reg CTRL_REG2
int32_t lps22hh_pin_polarity_get(lps22hh_ctx_t *ctx, lps22hh_int_h_l_t *val)
int32_t ret;
switch (reg.int_h_l) {
case LPS22HH_ACTIVE_HIGH:
*val = LPS22HH_ACTIVE_HIGH;
break;
case LPS22HH_ACTIVE_LOW:
*val = LPS22HH_ACTIVE_LOW;
break;
default:
break;
return ret;
* @brief Select the signal that need to route on int pad.[set]
* @param val registers CTRL_REG3
int32_t lps22hh_pin_int_route_set(lps22hh_ctx_t *ctx,
lps22hh_ctrl_reg3_t *val)
int32_t ret;
ret = lps22hh_write_reg(ctx, LPS22HH_CTRL_REG3, (uint8_t*) val, 1);
return ret;
* @brief Select the signal that need to route on int pad.[get]
int32_t lps22hh_pin_int_route_get(lps22hh_ctx_t *ctx,
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_CTRL_REG3, (uint8_t*) val, 1);
return ret;
* @defgroup LPS22HH_Interrupt_on_Threshold
* @brief This section groups all the functions that manage the
* interrupt on threshold event generation.
* @brief Enable interrupt generation on pressure low/high event.[set]
* @param val change the values of pe in reg INTERRUPT_CFG
int32_t lps22hh_int_on_threshold_set(lps22hh_ctx_t *ctx, lps22hh_pe_t val)
int32_t ret;
if (ret == 0) {
reg.pe = (uint8_t)val;
if (val == LPS22HH_NO_THRESHOLD){
reg.diff_en = PROPERTY_DISABLE;
else{
reg.diff_en = PROPERTY_ENABLE;
return ret;
* @brief Enable interrupt generation on pressure low/high event.[get]
* @param val Get the values of pe in reg INTERRUPT_CFG
int32_t lps22hh_int_on_threshold_get(lps22hh_ctx_t *ctx, lps22hh_pe_t *val)
int32_t ret;
switch (reg.pe) {
case LPS22HH_NO_THRESHOLD:
*val = LPS22HH_NO_THRESHOLD;
break;
case LPS22HH_POSITIVE:
*val = LPS22HH_POSITIVE;
break;
case LPS22HH_NEGATIVE:
*val = LPS22HH_NEGATIVE;
break;
case LPS22HH_BOTH:
*val = LPS22HH_BOTH;
break;
default:
break;
return ret;
* @brief User-defined threshold value for pressure interrupt event.[set]
int32_t lps22hh_int_treshold_set(lps22hh_ctx_t *ctx, uint16_t buff)
int32_t ret;
lps22hh_ths_p_l_t ths_p_l;
lps22hh_ths_p_h_t ths_p_h;
ths_p_l.ths = (uint8_t)(buff & 0x00FFU);
ths_p_h.ths = (uint8_t)((buff & 0x7F00U) >> 8);
ret = lps22hh_write_reg(ctx, LPS22HH_THS_P_L,
(uint8_t*)&ths_p_l, 1);
if (ret == 0) {
ret = lps22hh_write_reg(ctx, LPS22HH_THS_P_H,
(uint8_t*)&ths_p_h, 1);
return ret;
* @brief User-defined threshold value for pressure interrupt event.[get]
int32_t lps22hh_int_treshold_get(lps22hh_ctx_t *ctx, uint16_t *buff)
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_THS_P_L,
if (ret == 0) {
ret = lps22hh_read_reg(ctx, LPS22HH_THS_P_H,
*buff = (uint16_t)ths_p_h.ths << 8;
*buff |= (uint16_t)ths_p_l.ths;
return ret;
* @defgroup LPS22HH_Fifo
* @brief This section group all the functions concerning the fifo usage.
* @brief Fifo Mode selection.[set]
* @param val change the values of f_mode in reg FIFO_CTRL
int32_t lps22hh_fifo_mode_set(lps22hh_ctx_t *ctx, lps22hh_f_mode_t val)
lps22hh_fifo_ctrl_t reg;
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_FIFO_CTRL, (uint8_t*) ®, 1);
if (ret == 0) {
reg.f_mode = (uint8_t)val;
ret = lps22hh_write_reg(ctx, LPS22HH_FIFO_CTRL, (uint8_t*) ®, 1);
return ret;
* @brief Fifo Mode selection.[get]
* @param val Get the values of f_mode in reg FIFO_CTRL
int32_t lps22hh_fifo_mode_get(lps22hh_ctx_t *ctx, lps22hh_f_mode_t *val)
int32_t ret;
switch (reg.f_mode) {
case LPS22HH_BYPASS_MODE:
*val = LPS22HH_BYPASS_MODE;
break;
case LPS22HH_FIFO_MODE:
*val = LPS22HH_FIFO_MODE;
break;
case LPS22HH_STREAM_MODE:
*val = LPS22HH_STREAM_MODE;
break;
case LPS22HH_DYNAMIC_STREAM_MODE:
*val = LPS22HH_DYNAMIC_STREAM_MODE;
break;
case LPS22HH_BYPASS_TO_FIFO_MODE:
*val = LPS22HH_BYPASS_TO_FIFO_MODE;
break;
case LPS22HH_BYPASS_TO_STREAM_MODE:
*val = LPS22HH_BYPASS_TO_STREAM_MODE;
break;
case LPS22HH_STREAM_TO_FIFO_MODE:
*val = LPS22HH_STREAM_TO_FIFO_MODE;
break;
default:
break;
return ret;
* @brief Sensing chain FIFO stop values memorization at
* threshold level.[set]
* @param val change the values of stop_on_wtm in reg FIFO_CTRL
int32_t lps22hh_fifo_stop_on_wtm_set(lps22hh_ctx_t *ctx, uint8_t val)
int32_t ret;
if (ret == 0) {
reg.stop_on_wtm = val;
return ret;
* @brief Sensing chain FIFO stop values memorization at threshold
* level.[get]
int32_t lps22hh_fifo_stop_on_wtm_get(lps22hh_ctx_t *ctx, uint8_t *val)
int32_t ret;
*val = reg.stop_on_wtm;
return ret;
* @brief FIFO watermark level selection.[set]
* @param val change the values of wtm in reg FIFO_WTM
int32_t lps22hh_fifo_watermark_set(lps22hh_ctx_t *ctx, uint8_t val)
lps22hh_fifo_wtm_t reg;
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_FIFO_WTM, (uint8_t*) ®, 1);
if (ret == 0) {
reg.wtm = val;
ret = lps22hh_write_reg(ctx, LPS22HH_FIFO_WTM, (uint8_t*) ®, 1);
return ret;
* @brief FIFO watermark level selection.[get]
int32_t lps22hh_fifo_watermark_get(lps22hh_ctx_t *ctx, uint8_t *val)
int32_t ret;
*val = reg.wtm;
return ret;
* @brief FIFO stored data level.[get]
int32_t lps22hh_fifo_data_level_get(lps22hh_ctx_t *ctx, uint8_t *buff)
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_FIFO_STATUS1, buff, 1);
return ret;
* @brief Read all the FIFO status flag of the device.[get]
* @param val registers FIFO_STATUS2
int32_t lps22hh_fifo_src_get(lps22hh_ctx_t *ctx, lps22hh_fifo_status2_t *val)
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_FIFO_STATUS2, (uint8_t*) val, 1);
return ret;
* @brief Smart FIFO full status.[get]
* @param val change the values of fifo_full_ia in reg FIFO_STATUS2
int32_t lps22hh_fifo_full_flag_get(lps22hh_ctx_t *ctx, uint8_t *val)
lps22hh_fifo_status2_t reg;
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_FIFO_STATUS2, (uint8_t*) ®, 1);
*val = reg.fifo_full_ia;
return ret;
* @brief FIFO overrun status.[get]
* @param val change the values of fifo_ovr_ia in reg FIFO_STATUS2
int32_t lps22hh_fifo_ovr_flag_get(lps22hh_ctx_t *ctx, uint8_t *val)
int32_t ret;
*val = reg.fifo_ovr_ia;
return ret;
* @brief FIFO watermark status.[get]
* @param val change the values of fifo_wtm_ia in reg FIFO_STATUS2
int32_t lps22hh_fifo_wtm_flag_get(lps22hh_ctx_t *ctx, uint8_t *val)
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_FIFO_STATUS2, (uint8_t*)®, 1);
*val = reg.fifo_wtm_ia;
return ret;
* @brief FIFO overrun interrupt on INT_DRDY pin.[set]
* @param lps22hh_ctx_t *ctx: read / write interface definitions
* @param uint8_t val: change the values of f_ovr in reg CTRL_REG3
int32_t lps22hh_fifo_ovr_on_int_set(lps22hh_ctx_t *ctx, uint8_t val)
lps22hh_ctrl_reg3_t reg;
int32_t ret;
ret = lps22hh_read_reg(ctx, LPS22HH_CTRL_REG3, (uint8_t*)®, 1);
if (ret == 0) {
reg.int_f_ovr = val;
ret = lps22hh_write_reg(ctx, LPS22HH_CTRL_REG3, (uint8_t*)®, 1);
return ret;
* @brief FIFO overrun interrupt on INT_DRDY pin.[get]
* @param uint8_t: change the values of f_ovr in reg CTRL_REG3
int32_t lps22hh_fifo_ovr_on_int_get(lps22hh_ctx_t *ctx, uint8_t *val)
int32_t ret;
*val = reg.int_f_ovr;
return ret;
* @brief FIFO watermark status on INT_DRDY pin.[set]
* @param uint8_t val: change the values of f_fth in reg CTRL_REG3
int32_t lps22hh_fifo_threshold_on_int_set(lps22hh_ctx_t *ctx, uint8_t val)
int32_t ret;
if (ret == 0) {
reg.int_f_wtm = val;
return ret;
* @brief FIFO watermark status on INT_DRDY pin.[get]
* @param lps22hb_ctx_t *ctx: read / write interface definitions
* @param uint8_t: change the values of f_fth in reg CTRL_REG3
int32_t lps22hh_fifo_threshold_on_int_get(lps22hh_ctx_t *ctx, uint8_t *val)
int32_t ret;
*val = reg.int_f_wtm;
return ret;
* @brief FIFO full flag on INT_DRDY pin.[set]
* @param uint8_t val: change the values of f_fss5 in reg CTRL_REG3
int32_t lps22hh_fifo_full_on_int_set(lps22hh_ctx_t *ctx, uint8_t val)
int32_t ret;
if (ret == 0) {
reg.int_f_full = val;
return ret;
* @brief FIFO full flag on INT_DRDY pin.[get]
* @param uint8_t: change the values of f_fss5 in reg CTRL_REG3
int32_t lps22hh_fifo_full_on_int_get(lps22hh_ctx_t *ctx, uint8_t *val)
int32_t ret;
*val = reg.int_f_full;
return ret;
lps22hh_Device.zip
2020-12-25 14:18 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
13.16 KB, 下載次數(shù): 3, 下載積分: 黑幣 -5
lps22hh官方示例
