查看: 3794|回復(fù): 1
單片機(jī)4位數(shù)碼管時(shí)鐘程序設(shè)計(jì)
ID:868515 發(fā)表于 2020-12-26 22:05 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
采用4位數(shù)碼管制作一個(gè)時(shí)鐘,
要求:左側(cè)2位顯示:小時(shí),
右側(cè)2位顯示“分鐘”,中間的點(diǎn)(第2位數(shù)碼管右下方)
秒閃爍(1秒亮、1秒滅),且時(shí)間從“12.00”開始。
電路原理圖:
  1.    #include "reg52.h"
  2.    typedef unsigned int uint;
  3.    typedef unsigned char uchar;
  4.          sbit keymode=P2^4;
  5.          sbit  keyadd=P2^5;
  6.          sbit  keysub=P2^6;
  7.          uchar code segcode[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  8.          uchar code digcode[]={0xfe,0xfd,0xfb,0xf7};
  9.          uchar ms=0,s=0,min=0,hour=12;
  10.          uchar mode=0;// 0:time 1:hour 2min
  11.    void delayms(unsigned char s)
  12.    {
  13.       uchar i;
  14.             do
  15.             {
  16.                for(i=0;i<250;i++);
  17.                         }while(s--);
  18.    }
  19.          void display(uchar dat,uchar dig)
  20.          {
  21.                            P0=segcode[dat/10];
  22.                      P2=digcode[dig];
  23.                            delayms(5);
  24.                            P0=0;
  25.                      if(s%2==1 && dig==0)
  26.                              P0=segcode[dat%10]|0x80;
  27.                            else
  28.                                    P0=segcode[dat%10];
  29.                      P2=digcode[dig+1];
  30.                            delayms(5);
  31.                            P0=0;
  32.          }
  33.          void disoff(uchar dig)
  34.          {
  35.                             P0=0;
  36.                      P2=digcode[dig];
  37.                            delayms(5);
  38.                            P0=0;
  39.                      P2=digcode[dig+1];
  40.                            delayms(5);
  41.                 }
  42.    void timecounter()
  43.    {
  44.             ms++;
  45.                            if(ms==100)
  46.                            {
  47.                                          ms=0;
  48.                                    s++;
  49.                                          if(s==60)
  50.                                          {
  51.                                             s=0;
  52.                                                   min++;
  53.                                                   if(min==60)
  54.                                                         {
  55.                                                            min=0;
  56.        hour++;
  57.        if(hour==24)
  58.        hour=0;
  59.                                                         }
  60.                                          }
  61.                                  }
  62.
  63.          }
  64.          void main()
  65.          {
  66.                  while(1)
  67.                  {
  68.                          switch(mode)
  69.                          {
  70.                                  case 0:
  71.                                  {
  72.                                      display(hour,0);
  73.                                      display(min,2);
  74.                                            break;
  75.                                  }
  76.                                  case 1:
  77.                                  {
  78.                                      if(s%2==1)
  79.                                                          display(hour,0);
  80.              else
  81.                disoff(0);
  82.                                                  display(min,2);
  83.              break;
  84.                                  }
  85.                                  case 2:
  86.                                  {
  87.                                      display(hour,0);
  88.                                            if(s%2==1)
  89.                                                          display(min,2);
  90.              else
  91.                disoff(2);
  92.              break;
  93.                                  }
  94.                          }
  95.
  96.                          timecounter();
  97.                          if(keymode==0)
  98.        {
  99.                                  mode++;
  100.          if(mode==3)
  101.             mode=0;
  102.                                  while(~keymode);
  103.        }
  104.        if(keyadd==0)
  105.        {
  106.                                  switch(mode)
  107.                                  {
  108.                                          case 1:
  109.                                          {
  110.                                             hour++;
  111.                                                   if(hour==24)
  112.        hour=0;
  113.                                                         break;
  114.                                          }
  115.                                          case 2:
  116.                                          {
  117.                                             min++;
  118.                                                   if(min==60)
  119.        min=0;
  120.                                                         break;
  121.                                          }
  122.                                  }
  123.          while(~keyadd);
  124.        }
  125.        if(keysub==0)
  126.        {
  127.                                  switch(mode)
  128.                                  {
  129.                                          case 1:
  130.                                          {
  131.                                             hour--;
  132.                                                   if(hour==0xff)
  133.        hour=23;
  134.                                                         break;
  135.                                          }
  136.                                          case 2:
  137.                                          {
  138.                                             min--;
  139.                                                   if(min==0xff)
  140.        min=59;
  141.                                                         break;
  142.                                          }
  143.                                  }
  144.          while(~keysub);
  145.        }
  146.                  }
  147.
  148.          }
全部程序51hei下載地址:
C51.zip (22.21 KB, 下載次數(shù): 40)
ID:1 發(fā)表于 2020-12-26 22:34 | 只看該作者
本帖需要重新編輯補(bǔ)全電路原理圖,源碼,詳細(xì)說(shuō)明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
