- #include<reg51.h>
- sbit wr=P3^6;
- sbit rd=P3^2;
- sbit key0=P1^0;
- sbit key1=P1^1;
- sbit key2=P1^2;
- sbit key3=P1^3;
- sbit key4=P1^4;
- unsigned char flag;
- unsigned char const code
- SIN_code[256]={0x80, 0x83, 0x86, 0x89, 0x8c, 0x8f, 0x92, 0x95,
- 0x98, 0x9c, 0x9f, 0xa2, 0xa5, 0xa8, 0xab, 0xae,
- 0xb0, 0xb3, 0xb6, 0xb9, 0xbc, 0xbf, 0xc1, 0xc4,
- 0xc7, 0xc9, 0xcc, 0xce, 0xd1, 0xd3, 0xd5, 0xd8,
- 0xda, 0xdc, 0xde, 0xe0, 0xe2, 0xe4, 0xe6, 0xe8,
- 0xea, 0xec, 0xed, 0xef, 0xf0, 0xf2, 0xf3, 0xf4,
- 0xf6, 0xf7, 0xf8, 0xf9, 0xfa, 0xfb, 0xfc, 0xfc,
- 0xfd, 0xfe, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0xfe,
- 0xfd, 0xfc, 0xfc, 0xfb, 0xfa, 0xf9, 0xf8, 0xf7,
- 0xf6, 0xf5, 0xf3, 0xf2, 0xf0, 0xef, 0xed, 0xec,
- 0xea, 0xe8, 0xe6, 0xe4, 0xe3, 0xe1, 0xde, 0xdc,
- 0xda, 0xd8, 0xd6, 0xd3, 0xd1, 0xce, 0xcc, 0xc9,
- 0xc7, 0xc4, 0xc1, 0xbf, 0xbc, 0xb9, 0xb6, 0xb4,
- 0xb1, 0xae, 0xab, 0xa8, 0xa5, 0xa2, 0x9f, 0x9c,
- 0x99, 0x96, 0x92, 0x8f, 0x8c, 0x89, 0x86, 0x83,
- 0x80, 0x7d, 0x79, 0x76, 0x73, 0x70, 0x6d, 0x6a,
- 0x67, 0x64, 0x61, 0x5e, 0x5b, 0x58, 0x55, 0x52,
- 0x4f, 0x4c, 0x49, 0x46, 0x43, 0x41, 0x3e, 0x3b,
- 0x39, 0x36, 0x33, 0x31, 0x2e, 0x2c, 0x2a, 0x27,
- 0x25, 0x23, 0x21, 0x1f, 0x1d, 0x1b, 0x19, 0x17,
- 0x15, 0x14, 0x12, 0x10, 0x0f, 0x0d, 0x0c, 0x0b,
- 0x09, 0x08, 0x07, 0x06, 0x05, 0x04, 0x03, 0x03,
- 0x02, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x01,
- 0x02, 0x03, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
- 0x09, 0x0a, 0x0c, 0x0d, 0x0e, 0x10, 0x12, 0x13,
- 0x15, 0x17, 0x18, 0x1a, 0x1c, 0x1e, 0x20, 0x23,
- 0x25, 0x27, 0x29, 0x2c, 0x2e, 0x30, 0x33, 0x35,
- 0x38, 0x3b, 0x3d, 0x40, 0x43, 0x46, 0x48, 0x4b,
- 0x4e, 0x51, 0x54, 0x57, 0x5a, 0x5d, 0x60, 0x63,
- 0x66, 0x69, 0x6c, 0x6f, 0x73, 0x76, 0x79, 0x7c };
- unsigned char keyscan()
- unsigned char keyscan_num,temp;
- P1=0xff;
- temp=P1;
- if(~(temp&0xff))
- if(key0==0)
- keyscan_num=1;
- else if(key1==0)
- keyscan_num=2;
- else if(key3==0)
- keyscan_num=2;
- else if(key3==0)
- keyscan_num=4;
- else if(key4==0)
- keyscan_num=5;
- else
- keyscan_num=0;
- return keyscan_num;
- void init_DA0832()
- rd=0;
- wr=0;
- void SIN()
- unsigned int i;
- do{
- P2=SIN_code[i];
- i=i+1;
- }while(i<256);
- void Square()
- EA=1;
- ET0=1;
- TMOD=1;
- TH0=0xff;
- TL0=0x83;
- TR0=1;
- void Triangle()
- P2=0x00;
- do{
- P2=P2+1;
- }while(P2<0xff);
- P2=0xff;
- do{
- P2=P2-1;
- }while(P2>0x00);
- P2=0x00;
- void Sawtooth()
- P2=0x00;
- do{
- P2=P2+1;
- }while(P2<0xff);
- void Trapezoidal()
- unsigned char i;
- P2=0x00;
- do{
- P2=P2+1;
- }while(P2<0xff);
- P2=0xff;
- for(i=255;i>0;i--)
- P2=0xff;
- do{
- P2=P2-1;
- }while(P2>0x00);
- P2=0x00;
- void main()
- init_DA0832();
- do
- flag=keyscan();
- }while(!flag);
- while(1)
- switch(flag)
- case 1:
- do{
- flag=keyscan();
- SIN();
- }while(flag==1);
- break;
- case 2:
- Square();
- do{
- flag=keyscan();
- }while(flag==2);
- TR0=0;
- break;
- case 3:
- do{
- flag=keyscan();
- Triangle();
- }while(flag==3);
- break;
- case 4:
- do{
- flag=keyscan();
- Trapezoidal();
- }while(flag==4);
- break;
- case 5:
- do{
- flag=keyscan();
- Sawtooth();
- }while(flag==5);
- break;
- default:
- flag=keyscan();
- break;
- void timer0(void) interrupt 1
- P2=~P2;
- TH0=0xff;
- TL0=0x83;
- TR0=1;
復(fù)制代碼 |
